Question about HP Office Equipment & Supplies
My hp printer connection is sending print requests to file rather than directly to the computer .
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Printers
Right-mouse click on the HP icon
Click Properties
Disable the print-to-file option.
Posted on Sep 30, 2010
Printer is paused wont restart
it may be that you have a corrupt file in the print queue, a quick fix is possible - switch the power socket OFF, disconnect the PC/Network connections.
power on the printer, it should have had time to clear the memory now, see if the machine is able to print a menu page or config sheet ( open menu enter the information menu- print config sheet:)
if the printeris able to do thiswith no network connections you have eliminated the printer from the problem. next switch on and log into your PC, still disconnected from printer, open print queue and delete all documents from the queue ( your not deleting the files ( just the print requests)) once this is done then reconnect the printer and send first a windows test page ( confirm working connections first ) then attempt to print the failed file - if it fails in the same manner - the file was your problem.
Mar 16, 2014 | HP OfficeJet V40xi InkJet Printer
Sometimes when I print .pdf file the computer request me put the file name instead of printing
this happens when you have selected a PDF printer instead of the real Physical Printer for printing
a PDF printer is a software which converts any thing sent out like a document or file for printing into a PDF file tis is useful for saving data from files or majorly from websites and emails as a softcopy on your system.
next time on, when printing check to see that the selected printer on default is a Physical Printer (like HP or Cannon etc.) connected to your computer and you'll have your hard copies
hope could be of help, cheers
Mar 28, 2011 | Computers & Internet
Will not print photo. Asks for card. Need to print from computer, not from photo card. It has worked in the past.
You just have to send the print request from the computer, if you press the photo button on the printer it will always tell you to insert the card. It knows how to print when it's sent a print request.
Jan 18, 2010 | HP Photosmart A610 InkJet Printer
When i send a file to print from my mac (OSX 10.4.11) i get the error message in the printer box ''Printer not responding''I am using the HP 2500 Color LaserJet printer. It was working fine and just...
Connect the computer via fire wire to another working one.. and remove the two sleep files. Start your MBP holding down the T key The issue is a corrupt sleep file. once deleted your computer will work perfectly
Nov 11, 2009 | HP Color LaserJet 2500L Laser Printer, up...
I have attached the HP 4255 officejet with my computer and want to send the file directly from my computer via fax. how i can send directly without geting print . mubashir@ellahifabrics.com
Well, you'll need a modem to send a fax. Either that, or an online faxing service. Your printer / scanner is only intended to either print files, or scan hard copies into files that can then be printed (or faxed). The printer itself does not fax.
Might I suggest the following online fax service, free of charge:
http://faxzero.com/
There are plenty of others.
-Jon
Oct 21, 2009 | HP OfficeJet 4255 All-In-One InkJet...
I have reconnected my HP PSC 1315 to my printer, however, I cannot get the printer to work. Can you please help me? The printer will not do anything. I have received a print test after I installed the...
Hi melovesjags:
Try these steps.
Does the product
print from the
computer?
Connect the parallel
cable or USB cable to the
product and the
computer. Use a wordprocessing
application to
send a print job to the
printer.
The cable is not
connected correctly.
Reconnect the cable.
An incorrect printer driver
is selected.
Select the correct printer driver.
Other devices are
connected to the parallel
or USB port.
Disconnect the other devices and try again
to print.
There is an LPT port
driver problem.
Reset the computer port settings. See your
computer user guide for instructions.
The formatter has failed. Replace the formatter.
Hope these help
Jul 06, 2009 | HP PSC 1315 All-In-One InkJet Printer
Print Job enter's queue, but doesn't actually print.
hi thanks for using fixya!
Do you have 32bit or 64bit system?
Mar 24, 2009 | HP LaserJet 4250n Printer
Hp officeject 6210 all in one printer
Sorry these printers has capability to send faxes from the computer only but not receive.
But your idea is right on wasting paper on printing incoming faxes, These days HP has launched a new model which can receive fax to your computer without wasting paper See the link bellow:
http://www.shopping.hp.com/webapp/shopping/store_access.do?template_type=product_detail&product_code=CB029A%23ABA&jumpid=oc_R1002_USENC-001_HP%20Officejet%20J6480%20All-in-One%20Printer&lang=en&cc=us
Take a look
Sep 26, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Phaser 8500 color printing issue - pdf file
Try setting up PDF direct printing..
> Support & Drivers > Phaser 8500/8550 Support > Search Results Solution: Perform PDF Direct Printing From Microsoft Windows 2000 / XP / Server 2003 OS and Apple Macintosh OS X (10.x) bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif PDF direct printing can be used to send a PDF file to the printer without having to open and view the file on a computer.
NOTE: PDF Direct Printing may not be successful if the printer does not contain a hard drive.
Depending on the OS being used, click on one of the following links:
Macintosh OS X
To download a PDF file directly to the printer from Windows 2000 / XP / Server 2003:
To download a file to a printer that is connected using an Ethernet (network) cable, use the FTP command or CentreWare Internet Services (CWIS). To download a file to the printer that is connected directly to the computer with a USB cable, use the Xerox File Downloader Utility.
To download a file to the printer using the FTP command:
NOTE: To perform this solution, the printer must be connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
Not all web browsers can be used to perform this solution. If problems occur when performing this solution, download the file using CWIS. See the To download a file to the printer using CWIS section below.
  1. From the computer, open an Internet browser window.
  2. Type: ftp://xxx.xxx.xxx.xxx, where the x characters represent the IP address of the printer, in the Address field.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below for additional information.
  3. Press [Enter] on the keyboard. A blank FTP connection window with a [.] icon will be displayed.
  4. Drag and drop the file to be sent to the printer into the blank FTP connection window. The file will be sent to the printer.
To download a file to the printer using CWIS:
  1. From a computer, open an Internet browser window.
  2. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below.
  3. Click on the [Print] button.
  4. Click on the [File Download] link in the list of options on the left side of the window.
  5. Depending on the browser being used, click on the [Browse] or [Choose File] button, and then browse to and select the file to be downloaded to the printer.
  6. Click on the blue, square button to send the file to the printer.
To download a file to the printer using the Xerox File Downloader Utility:
NOTE: This solution assumes the Xerox File Downloader Utility has already been installed on the computer. If necessary, click on the [Drivers and Downloads] link under the Product Resources menu on this window to download and install the utility.
  1. From the computer, open the Xerox File Downloader Utility. By default, the utility is installed in the following location on the computer's hard drive: C:\File Downloader.
  2. Select the required printer from the Select the printer to spool the file to from the list below pull-down menu.
  3. Click on the [Browse] button, and then browse to and select the file to be downloaded to the printer from the Select the file to sent to the printer section.
  4. Click on the [Send] button to send the file to the printer.
To download a PDF file directly to the printer from Macintosh OS X:
Files can be downloaded to the printer using the Print Center or Printer Setup Utility, or by using CentreWare Internet Services (CWIS).
To download a file to the printer using the Print Center or Printer Setup Utility:
NOTE: This method can be used for Ethernet (network) and USB connections.
  1. Open the Print Center (for Mac OS 10.1 - 10.2.x), or the Printer Setup Utility (for Mac OS 10.3.x and 10.4.x):
    1. Double-click on the [Hard Drive].
    2. Double-click on the [Applications] folder.
    3. Double-click on the [Utilities] folder.
    4. Double-click on the [Print Center] or [Printer Setup Utility].
  2. Double-click on the printer that needs the file sent to it. The print queue window will be displayed.
  3. Drag and drop the file to be sent to the printer in the print queue window below the Name column. The file will be sent to the printer.
To download a file to the printer using CentreWare Internet Services (CWIS):
NOTE: CWIS can only be accessed if the printer is connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
  2. Enter the printer's IP address in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
Feb 29, 2008 | Xerox Phaser 8500/DN Printer
A new router, recognizes the printer (HP Photosmart) and still won?t print from a distant location on the network.
I?m not sure about this one, but I think you should make sure there?s permission to access (share) the printer in the router and/or printer settings. If the printer is connected directly to the router, check if it?s in the right port and you?re not sending a print request to a different port. If that doesn?t help try to set it to another port in the router.
Feb 22, 2006 | ASUS WL-500B Wireless Router
13 people viewed this question
Seeker5211
Seeker5211
