Question about Xerox Phaser 3500/DN Laser Printer
Pcl6b error -sb_count != -128 - Xerox Phaser 3500/DN Laser Printer
Construct both an ungrouped and a grouped frequency distribution for the data given below: 139 130 128 134 140 139 136 130 136 128 138 137 134 128 127 136 140 132 141
Sorry to disappoint you but I will just give you directions to do it yourself.
Ungrouped
First sort the data in ascending order (from lowest to highest value)
Create a two-column table
In the first column enter a data value.
In the second column enter the frequency of a data item
Count how many times one particular data value appears in the set (how many repetitions). If it appears only once, its frequency is 1; twice, frequency 2, etc.
For each single (different) data value complete the frequency column.
Grouped
For grouped data representations you create classes: A class is just an interval of values, for example between [125, 130[
For each class interval you create, count how many data values fall within the interval. For the class given as example it will encompass all values between 125 and 129, It I counted correctly its frequency is 4.
Complete the frequency table for the class.
How many classes should you create? Usually this information is given to you. If not, create a moderate number of classes (4,5) It depends on the span of the distribution (highest value- lowest value). The intervals should have equal length. Read your instructions.
Sep 02, 2012 | Office Equipment & Supplies
Control panel shows an error message 128 MB. No buttons ie menu, tick will do anything. Have turned the printer off, unplugged it, removed the internet cable!!
Its not error message, its hanging at memory count. Remove memories clean the contacts insert once again check if its not resolved primary inspection memory/DIMM, secondary formatter..
Sep 29, 2011 | HP LaserJet 4700 Printer
Creative audio pci es 1370, sb pci 64/ 128 (wdm)
What exactly is the problem? Could you please explain so that we may help you.
Aug 08, 2009 | Creative Labs Computers & Internet
I have a IBM machine. I want to install vga dirver for o/s vist.Pls Guide me now
here is the link but i dont think u will be able to run vista successfully on this chipset pls install and check bcoz vista needs atleast 128 ram of vga
http://www.intel.com/support/chipsets/sb/CS-009236.htm
Dec 13, 2008 | Intel 845GE Motherboard
MANUAL FOR PCI128
The soundblaster PCI 128 is past it's end of service life, and as such, support is no longer available for it. You can try searching the creative web site at www.creative.com, they are the actual manufacturer of the product.
Feb 14, 2008 | Creative Labs Sound Blaster PCI128 Sound...
Casio FA-128
how to upgrade Casio FA-128.
Dec 17, 2007 | Casio Boss Business Organizer
PCI sound card not working
Do you have WIN XP installed?
What speakers are you using?
are they surround sound or regular
Nov 21, 2007 | Asrock K7S41GX Motherboard
Xerox Phaser 3500/DN Laser Printer Logo
224 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
