Question about Dell Inspiron 1000 Notebook
I have a dell inspiron 1000. Had to just put in a new hard drive. I used all the disks that came with the computer to restore everything. I have no sound except for an annoying "error" beep. Help!!!
    President:
  • 1,566 Answers
Hello there,
You need to install the drivers. Please click on this link to start downloading now:
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs&~ck=anavml
Select the MODEL, and then what type, in your case it is laptop. And then the operating system.
It will then present you links where you can download the files.
Posted on Sep 30, 2010
I have a dell inspiron 1318. whenever i turn the laptop on, there is a black screen with a "read disk error has occured" message...it keeps bringing me back to the same screen...what should i do?
Disk read error is indicative of a hard disk drive failure. If under warranty, call Dell for a replacement drive. If not you can buy drives at places like Newegg.com or EBay
Sep 20, 2010 | Dell Inspiron 1318 Notebook
Keeps disk checking and cant get into anything . Runs disk checker and then nothing. Goes to blue scrren. Bought new one yesterday 1545 model in red , Would like to get old one working for grandson.
From you're description it sounds like the hard disk drive is defective. Suggest you replace it with a new drive, choose from the list provided; http://www.google.com/products?hl=en&q=Dell+Inspiron+1520+new+hard+disk+drive&um=1&ie=UTF-8&ei=QertS-P-NYP48AaSy8z9Cg&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CDEQrQQwAA
There is another option. Restore a DELL Inspiron 1525 laptop to factory settings.
You have to do it BEFORE Windows loads...
1. Reboot, and press Ctrl + F11 at the Dell logo.
2. The Dell PC Restore by Symantec screen will come up.
3. Select "Restore" or use the Tab key to highlight it and press Enter.
4. if you wish to continue, click "Confirm", or use the Tab key to highlight it and press Enter.
5. When the utility is finished, click "Finish", or use the Tab key to highlight it and press Enter.
***This will erase all your unsaved data!***
Use you're recover CD to reinstall Windows.
Mike
May 14, 2010 | Dell Inspiron 1520 Motherboard
My Dell Inspiron 6000 won't boot up. It keeps
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
May 02, 2010 | Dell Inspiron 6000 Notebook
DELL Inspiron disk failure how to recover OS in new hard disk?
Unfortunately you will need the restore disk to correct this problem. Even if you copy the old disk to the new, chances are you will copy the corrupt files and have TWO bad copies of xp. You can order the restore disk from Dell on average about $30.
Good Luck
C2Solutions
Jan 28, 2010 | Dell Inspiron 6000 Notebook
I want to restore my computer--what cds do I need to use
when you mean restore your computer you mean reinstall windows onto it i presume. if you bought it from new you can restore from the hidden partition on the hard drive now i was told you either hold down ctrl and f11 or f12 not too sure now and it will ask you if you want to restore this but id it has had another drive installed by someone else then you need your dell xp disk and the drives disk which is normally a blue one which says drivers and utilities on it. good luck with that
Sep 02, 2009 | Dell Inspiron 531s Desktop Computer
How do you format the hard drive on Dell Inspiron 1000. I have the restore system disk and don't have anything on it worried about losing...just need to format and start fresh..it's got too many issues and...
I'd put ubuntu on it, if it's a inspiron 1000, should run ok. If you have the restore disks from dell, just turn it on, pop in the cd, then reboot, the pc should boot from cd, then just follow the promps, make sure you delete all partitions, format thorough (not quick NTFS), use the whole disk for windows
Apr 06, 2009 | Dell Inspiron 1000 Notebook
No bootable device--strike f1(please help)bios wont read cd or hd
I think your lap top fails to detect your hard disk. Enter Bios settings and confirm that the hard disk is detected.
Mar 25, 2009 | Dell Inspiron 2200 Notebook
Vertical Fold over or rolling on Dell Inspiron 1000
Get a new hard drive put into the system, with the cd's that came with the system, restore the laptop back to factory defaults and then after that the F12 function should work and windows will go back to working as well.
Feb 13, 2009 | Dell Inspiron 1000 Notebook
Dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Jan 06, 2009 | Dell Inspiron 1000 Notebook
My dell inspiron 1000
Can you see the Dell splash screen after turning it on at least? Check first your hard drive by doing diagnostics. Hit F12 for the diagnostics options to test its functionality. If everything passes, then there is still a way to recover the files. Are there any files on your computer that needs to be backed up? You need to consider this before doing the restoration options.
Sep 26, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 1000 Notebook Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
