Question about Philips Pocket Memo 9300 Handheld Digital Voice Recorder
I have just bought a second hand Philips Pocket Memo 9300, all boxed with memory cards etc but it won't work with our machines as it doesn't contain the software cd that should come within the box. Is there anything you can suggest I buy and if so where from? Thanks, Colleen.
DDMaster
  • 10 Answers
SOURCE: I have lost my user guide manual for my Philips
Go to http://www.dictation.philips.com/index.php?id=71&CC=UK#result and you will find you manuals under Mobile Dictation section.
I hope this helps...
Posted on Jun 11, 2009
  • 61 Answers
SOURCE: I have an old Philips Professional Pocket Memo 398
At the end of the recorded part of the tape, hold in the RECORD button and pull the 4-way slider down into
REWIND position. Hold both until tape is fully re-wound.
Posted on Apr 25, 2010
  • 61 Answers
SOURCE: Philips Pocket Memo 398 dictation machine - spindles not turning
Most likely cause here is a broken drive belt. This machine is at least ten years old. The belts for the latest model (381) will fit, but it's a tricky job to fit.
Posted on May 17, 2010
  • 61 Answers
SOURCE: can't get a playback of dictation
Download it from www.dictation.philips.com.
  • 61 Answers
SOURCE: I have a Philips pocket memo 381 that lets out a
This is the end-of-tape signal. Try turning the cassette over. If this does'nt work then there is no tape drive due to the belt coming loose or breaking.
Posted on May 20, 2010
WHY WONT IT RECORD OR REPLAY - THE MACHINE RECORDS TIME BUT THERE IS NO SOUND
try plugging in an external microphone, if that works and it records then the microphone element in your machine is bad or a wire has broken off of the microphone
Apr 13, 2015 | Philips Pocket Memo LFH9370 Handheld...
Where to send pocket mmo recorder for repair?
Roach Reid Office Systems 2737 Gilchrist rd Akron Ohio 44305 ATTN Mark
Aug 23, 2014 | Philips LFH9500 Pocket Memo Digital...
Function locked
You may have a SD card with a lock switch in the lock position. If not, the internal sensor that detects the position of that switch may be bad. It could also be corrupted memory so try reformatting the memory from the menu. Scroll thru the menu until you see the memory icon.
Dec 18, 2013 | Philips Pocket Memo 9360 Handheld Digital...
Driver for Philips Pocket Memo 9300
Hi, fortunatley I found the old setup/installation-disk! Download and enjoy!!! Gunter
https://dl.dropboxusercontent.com/u/6605634/philipsLFH9300.zip
Nov 26, 2011 | Philips Pocket Memo 9300 Handheld Digital...
Our 9500 series Philips digital pocket memo will not clear the old files when complete. As a result, we are unable to download new files. Any help would be appreciated. Thanks! Jill
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
Apr 05, 2011 | Philips Pocket Memo 9500 (256 MB 1 Hours)...
LFH 720 - Does it record?
This machine is a playback-only model. You will need a hand-held recorder using Philips mini-cassettes.
Oct 13, 2009 | Philips LFH-720
Mar 25, 2009 | Philips Audio Players & Recorders
Phillips 281 pocket memo
Go to www.dicatation.philips.com and download manual for model 381. It works exactly the same.
Mar 02, 2009 | Philips Pocket Memo 281 Handheld Cassette...
Philips Pocket Memo 9300 Handheld Digital Voice Recorder Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
