Question about HP Audio Players & Recorders
Toolbar The touch bar at the top of my keyboard with quickplay and volume controls seems to be locked and I do not know how to unlock it. (when I touch is nothing happens, so I cannot take my computer off of mute).
  • Brian Canute May 11, 2010
    does it work normally untill you mote it if so lok at your sound icon on your task bar and un tick mute nthere
    Genius:
  • 1,847 Answers
Go to control panel> sound speech....>sound and aud...> uncheck mute.
to activate the soft keys on ur keyboard, install the keyboard drives which came with the the computer.
Hope it will help :)
Posted on May 30, 2008
Download driver sd ms pro mmc xd
If you have a hardware mute button on the keyboard, try pressing that. They usually look like a speaker with either an x beside it or a speaker that has a circle with a slash beside it. It may even be colored red.
The following answer assumes you're using XP, Vista, or Win 7.
If there is no mute button, click the speaker icon on the toolbar and see if the 'mute' box is checked. If it isn't, also use your mouse or touchpad to work the slider on the screen to try and turn up the volume.
Lastly, some Toshiba laptops have a separate hardware volume control on the front, like you'd find on portable radios.
Dec 11, 2013 | Computers & Internet
I would like to increase my volume
on the keyboard you will see Fn key and up top of the keyboard you will see the volume up and down on different keys their usually a different colour than the rest of keys like red or blue... hold down the Fn key and press the volume up on the top of keyboard. If that doesnt work down on the right side where the clock is on your toolbar youll see an icon like a speaker click on that then drag the volume bar up or down this is another option
Oct 15, 2013 | Acer C7 Chromebook
My tools had a lock the toolbar option and I want to unlock the toolbar
When you Right click on the Tool bar you'll see the option called Lock Tool bar, so click it once and you are free from it.
Aug 02, 2012 | Toshiba 156 Satellite L755S5214 Intel Core...
I can't locate the volume control button
what is the operating system you are using ?
Mar 01, 2011 | Computers & Internet
Computer compaq nc 6000 power off during working
If you feel the power adapter working fine with the diff unit its not an issue with the adapter,
Now, if the unit is not powering on.just perform this:
Take out the batter, adapter and make the unit stand alone and press and hold the Power button with out any power to the unit(Without battery , adapter) by doing that we can take the static charge which might be causing the issue,
If that does not fix the issue, try reseating the RM if you are comfortable, here is the steps:
Primary memory board removal Before you begin: Remove the battery and keyboard.
  1. Push both arms outward simultaneously to release the primary memory board to the spring tension position.
    Caution! When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  2. Grasp the primary memory board by the edges and pull gently to remove it.
  3. Place the primary memory board in a static dissipative bag.
Primary memory board replacement
  1. Remove the primary memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the primary memory board by the edges and push gently to replace it.
  4. Press the primary memory board down to latch the arms.
Steps to remove Keyboard:
eyboard removal Before you begin: Remove the battery.
  1. Loosen the captive P1 Phillips-head screw that secures the memory/Mini PCI cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the outside edge of the memory/Mini PCI cover and remove it.
  3. Remove the two T8-9 mm screws that secure the keyboard to the base enclosure.
  4. Turn the notebook right side up and open the display panel fully.
  5. Slide the four plastic locking tabs toward the bottom edge of the keyboard to unlock the keyboard from the LED switch cover.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  7. Using minimal force, lift the locking bar to unlock the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. After ensuring that the locking bar on the keyboard ZIF connector is unlocked, place the keyboard right side up on the top cover.
  2. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the keyboard ribbon cable.
  3. Push the locking bar down to lock the keyboard ZIF connector on the system board.
  4. Toe the tabs on the bottom edge of the keyboard into the top cover.
  5. Press the keyboard flat and slide the four plastic locking tabs toward the rear of the notebook to lock the keyboard to the LED switch cover.
  6. Close the display panel and turn the notebook upside down.
  7. Replace the two T8-9 mm screws that secure the keyboard to the base enclosure.
  8. Toe the memory/Mini PCI cover into the enclosure.
  9. Tighten the captive P1 Phillips-head screw.
Jul 06, 2009 | HP Compaq nc6000 Notebook
Shortage?
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
Mar 25, 2009 | Gateway Computers & Internet
Unlock volume console
I had this issue too, there's a couple of threads on this site - seems to be a common issue.
Turn of your machine (and remove from charger if this is the case), remove battery & wait for a little over 10 seconds... then replace the battery and boot as normal.
This seemed to rectify the problem with my machine, but some people weren't as fortunate. Hope all goes well for you!
Feb 23, 2009 | Acer Aspire 6920 Notebook PC
Volume bar won't go away
Open Task Manager
Find "Volume Control"
End Task
Jan 07, 2009 | IBM ThinkPad R50e Notebook
Light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased  using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
Dec 20, 2008 | HP Pavilion dv4000 Notebook
71 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
