Question about JVC HX-D77 Shelf System
JVC HX-D77 I can not get proper connection from the USB Audio
  • vtwin88cube Sep 15, 2008
    Vista doesn't recognize the USB. Is there a driver?
Cant programm remote to TV
Posted on Aug 12, 2008
  • matthew19992 Jul 03, 2011
    I cant get my optical digital to work on it
Audio connection
go to device manager (Right click on My Computer,Properties,Hardware tab,Device manager) and look for Universal Serial Bus Controller and see if there's any USB device with '?' on it
and make sure that you've installed the sound driver properly
Aug 26, 2012 | Sony VAIO EA Series Notebook Computer
My windows xp wont detect my m-audio..im trying to connect my mobilepre usb can someone please help me solve this?
First ensure you have any software installed the the M-Audio needs My Oxygen keyboard needed the software to work properly.
Also do not extend the USB cable and make sure you use the proper power supply my Oxygen would not work 100% until I got a power supply for it
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 15, 2009 | M-Audio MobilePre (US41401) Audio Input
Usb
If you have installed the drivers etc. then see if any of the help below applies to you.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
Aug 30, 2009 | Creative Labs WebCam Live!
LifeCam VX-5000 not recognized by USB Port
You are not suppose to connect the camera to the USB port untill the installing software asks you to DO SO. Then connect it and when the installation is complete it will work.
Follow the instructions below.
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Mar 13, 2009 | Computers & Internet
Playing Creative Zen music through a vehicles usb or audio port
first try update then try the audio jack if not then well just wait for an update allowing support
Or
find a exploit or hack for your zen to allow connection between your car and your zen
hope that helped
Feb 18, 2009 | Creative Labs ZEN Vision:M Digital Media...
Hello. I can't install my Labtec Webcam. I have Windows Vista and the latest driver from Labtec Website. After installation the software tries to find my Webcam and asks for connection. I connect webcam...
Disconnect the camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, thendo so and it should work okay. You will need to use Skype or other messenger to use on line. Here is info for you to use. Bud
Normal 0 Web Camera’s have to be setup on the program they areto be used with. Just installing thecamera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see andtalk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger setit up as follows:
When done both the Audio and Video will function properly soyou can chat and see family or friends you are connected to.
Jan 10, 2009 | Logitech Webcam
None of my usb ports are working andi have no sound.says no audio output device is connected
There's a big possibility that the driver for your USB and audio device is not installed properly, it will be better if you can run again the setup CD for your motherboard so all software will be reloaded again for it like the driver for your USB and audio device...
Dec 03, 2008 | Acer Computers & Internet
Please help me
If after connect your usb speaker cable the system it is asking for software (drivers) you have to install them to get your audio working properly. Check it out the box of your new speakers for a installation CD.
You can also verify:
Check if your audio es working properly (start >> control panel >> sound and audio devices)
Check if your sound card is properly installed (My pc >> Properties >> Hardware >> Device Manager >> Audio)
Oct 05, 2008 | Audio Players & Recorders
QuickCam USB Problem
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
A. Skype Setup:
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
NOTE: You audio and video shoud work. Enjoy.
Oct 25, 2007 | Logitech QuickCam Express Web Camera
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
JVC HX-D77 Shelf System Logo
189 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
