Question about Nokia 5610 Blue Quadband 3.15MP A2DP + Gift + WTY Cellular Phone
There four pin but one is loose - Nokia 5610 Blue Quadband 3.15MP A2DP + Gift + WTY Cellular Phone
  • 56 Answers
If your phone is still covered under warranty get that key repaired or get the keypad replaced in the nokia repair centre. if its out of warranty i prefer you replace the keypad with a duplicate one in the nokia care itself by paying some money..
Posted on Sep 30, 2010
HOW TO GET UNLOCK CODE ?UNLOCK TV TOSHIBA
"If you cannot remember your PIN code
While the PIN code entering screen is displayed, press [RECALL] four times within five seconds. The PIN code will be cleared and you can enter a new PIN code."
Or you can trye this:
Step3Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Aug 07, 2014 | Toshiba REGZA Televison & Video
Tilt steering wheel loose 1989 chev truck
Not a fun job sorry!
1) Remove horn button. 2) Remove steering wheel. 3) Remove turn signal/cruise lever and cancel cam. 4) Remove tilt pins with a pin puller(about $10) 5) Tighten the four loose screws that hold tilt mechanism to the column.
Be happy you do not have airbags.
Mar 08, 2011 | 1989 Chevrolet K1500
The wires on the timer of my cooker have been disconnected now my son can not remember which way they go back on there are two pins on the timer N7 and L8 and four wires one orange and spare pin one blue...
Sounds like the orange and blue wires are attached to the spare pins. If so that leaves the brown and the white. The L in the L8 probably stands for line. Line is active and the brown wire is always the active. The N in the N7 would normally mean neutral. Neutral is normally blue but if there is only one wire left that must be where the white goes.
Feb 08, 2011 | Stoves 600SiDOm Gas Kitchen Range
Hp48gx four pin connector is loose. Any way to fix it?
The only way is to open the calc seperate the main circuit and sodered the pins back
its a bit complicate because when you seperate the main circuit you also seperate the lcs and it need to go back to the same place otherwise you will have a missing lines on the screen
Jan 26, 2010 | HP 19BII Calculator
I am having problems getting the power brake booster installed on my 2000 dodge grand caravan. Are they any online instructions for this?
I doubt it,
You need to take the two nuts that hold the master cylinder to the booster off,pull out on the master cylinder until it clears the booster,but don't take any lines loose!
Now go inside your van and remove the knee panel below the steering column,And then a metal plate behind that comes down next,After that reove the brake light switch connected to the brake pedal,it is held in place with a push pin and hair pin clip,remove the clip and then the pin,now you can remove the push rod that was connected to the pedal,Now look at the fire wall where you took the rod out ,you will see four nuts that make a square,two on the left and two on the right,straight up and down from each other,Remove these four nuts and go back out under hood and pull the booster out towards you.
Jan 18, 2010 | 2000 Dodge Grand Caravan
Convert three pin plug to four pin
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My camera has a loose pressure plate
Most pressure plates have four flat metal springs connecting them to the back. Two springs on one side are usually anchored to the back and two have a slot that stradles a pin on the back. This allows fore and aft movement of the plate relative to the back. Lift the slotted side away from the back while pushing the end of the springs to the back aligning them with the pins. Ease the spring slots under the pin heads. Take care to not over-bend the springs.
Aug 14, 2009 | Phoenix Gold P1 35mm SLR Camera
Can't get on the internet after installing memory--Did I uplug?
- I would think so that the network cable is unplugged to your computer. Just like a telephone cord,
Mar 09, 2009 | Dell Dimension 8300 PC Desktop
Nokia 5610 Blue Quadband 3.15MP A2DP + Gift + WTY Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
