Question about Keurig B60 Coffee Maker
Coffee is barely dripping out, not running as it used to. I checked the "needles" in the drip cup and they seem to be clear. Is there a water filter or something that may need to be cleaned?
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
SOURCE: Coffee drip seems to be clogged?
changer de sorte de café le noir semble colmater les ouverture
Posted on Dec 14, 2008
  • 19 Answers
SOURCE: our machine is not dripping the coffee into the
you need a tune -up estimated costs about 175.00 contact me www.lavazzarepair.com
Posted on Dec 11, 2009
tgmusicgirl
  • 91 Answers
SOURCE: something is blocking coffee from coming out!!
run it without a k-cup... Keurig will tell you to check for blockage at the upper needle with a paperclip... someone tried blowing into it with a straw to free the obstruction... which Keurig assumes is coffee/Tea grounds... or caked up cocoa mix, if you use that product...
Posted on May 06, 2010
  • 128 Answers
SOURCE: I have a three month old Miele CVA 4066. I have
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Posted on Feb 24, 2011
Why is my delonghi ec702 brewing slowly even after regular descaling? The water barely drips out even with no coffee in the filter.
I had same problem, now gone. Check your water Intake filter in the water reservoir. If it looks discolored, it may be clogged. I used a brush and plain water to clean it off, and now machine works like brand new!
Jul 28, 2014 | DeLonghi EC702
How does the drip method work to produce a cup of coffee?
Hot water is poured over ground coffee, which is contained within a filter. The water then steeps and drips through, producing coffee. This method of making coffee is also referred to as filtered coffee.
Feb 07, 2013 | Wine & Spirits
Drips only a little bit of water tried viniger thru did not help.. 2 bottles
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 28, 2011 | Keurig B70 Coffee Maker
WATER WON'T COME THRU TO THE CUP
It could be your needle (the one on the top of the machine). Try using a pin to clean out the top needle.
Jul 10, 2010 | Keurig B60 Coffee Maker
Something is blocking coffee from coming out!!
May 06, 2010 | Keurig Elite B40 Coffee Maker
Mar 25, 2010 | Keurig B60 Coffee Maker
Clear coffee?
Hello, After many years in the coffee game there are only 3 possible reasons for this, either the water is not heating, this would cause the water to not extract the coffee from the grounds. Or your filter is folding over and the water is running down past the filter....Lastly and the most probable is the spay head is blocked and the water is coming out the over flow if there is one, which is then bypassing the filter. Things to check would be heat, spray head and filter. Hope this helps...Mike
Aug 14, 2009 | Krups XP 1500 Espresso Machine & Coffee...
Water overflows from filter basket
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Dec 25, 2008 | Mr. Coffee ISTX95
Nov 21, 2008 | Saeco Odea Go
Significant leak into drip tray when brewing and using steam/hot water
run a 50/50 mixture of white vinegar and water thru your system.may have to run it twice,should clear it up if its a mineral clog. be sure to run a few cycles of clean water afterwards to clear the system
Dec 01, 2007 | Saeco Vienna De Luxe Espresso Machine
Keurig B60 Coffee Maker Logo
590 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
