Question about Toshiba E-Studio 3511 Color Copier
Do all color toners need be replaced at the same time?
  • 1,110 Answers
NO. They should or at least NEED to only be replaced when called for by the machine. For example you would only need to install the Cyan toner cartridge if the machine was saying to replace the Cyan toner.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Sep 30, 2010
White lines when printing
Usualy white lines are a signal for you that is time to replace a toner cartirdge.
Your machine may inform you that you need to replace a toner cartridge, but sometimes the toner levels are low and the machine doesn't indicate that.
Another thing that you may try is to clean all toner cartridges using each corona wire.
If you need to replace your toner cartridge check this easy and helpful way to replace toner cartridge.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
Just wondering: my printer's yellow and black toner are both empty and need replacing. Would this cause the printer to calibrate for minutes at a time? After calibrating, I tried printing a document with...
If your going to print in color may it be just red or blue. You really need all of the cartridges for it to work. Because for the printer to come up with those colors. It would need all three colors Cyan, Magenta and Yellow to come up with the any color, in your problem, Blue and Red.
Feb 04, 2011 | Dell 3100cn Laser Printer
Toner exhaust yellow toner
samsung clp color leserjet printer writes this massage toner exhaust yellow toner. i have done the toner refil without the reset chips about two times now and i have been printing for some time now i get the message "toner exhaust yellow toner"
Oct 01, 2009 | Samsung CLP 315 Laser Printer
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Red light on suggesting replacement of parts
get geniune toners and replace waste toner bin.
Jul 05, 2009 | Samsung CLP 300 Laser Printer
We ran some aftermarket (non dell) toner in it and quit when the pages were coming out with color haze & streaks of various colors on them. Have vacuumed out old toner powder and installed genuine dell...
You need to be using dell toner for this printer not aftermarket becase the tecknolag it uses to do the printing will only work on the recamended toner catrages
May 02, 2009 | Dell 5100cn Laser Printer
Hello, I have a Minolta Magicolor 2490 MF, printer/copier. The display shows "low toner". My question is this: Is it possible for the machine to identify the seperate toner levels, so I can replace only...
hi,
if it has a 4 toners which color are separated (the cyan, magenta, yellow and black) then you can replace a low toner one at a time. for example if the black color prompt you that it needs a replacement then you can put off the black toner without changing the other color not until such time it prompt you that it needs replacement. For replacing it I believe it has an instructional manual or if it's still under warranty you can ask assistance from your dealer to help you how.
Dec 20, 2008 | Office Equipment & Supplies
REPLACING CARTRIDGE
You should be able to replace just the needed color.  Select menu, arrow right until "Engine" is displayed, select, select "Replace Toner" select color cartridge desired. follow directions on screen.
Jul 29, 2008 | Minolta magicolor 2350 Laser Printer
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Toshiba E-Studio 3511 Color Copier Logo
37 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
