My dvd player not working properly how to fix this problem
    Scholar:
  • 78 Answers
Try reinstalling the drive or update drivers.
1.Right click on My Computer
2.Go to properties in drop down menu.
3.Find Device Manager in tabs at top of window ( XP ) or on left side of window ( Vista, Windows 7 )
4.In the list of devices you should see your DVD player. Right click it and choose update driver.
5.Make sure to choose search Internet and auto instal driver when the option comes up.
Good luck and please rate if helpful.
Posted on Sep 30, 2010
Drt389h dvd recorder update fix
If error is gotten with all disks then the laser mechanism is no longer working properly. If only with some disks then the mechanism is picky and will only work with certain disks; if so, that is a unique characteristic of your gear and you simply have to live with it.
Oct 28, 2015 | LG DRT389H DVD Player/Recorder - DVD...
No Power?
see the cause and fix it : God bless you
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Jul 21, 2012 | NextBase SDV685 DVD Player
I got a new vitz, when i insert the a DVD to my NDDN W56 player, the audio is working but video is not working? How can i fix it? please email me the solutions? Arun_kandyguy@hotmail.com
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 24, 2012 | Toyota Toyota Cars & Trucks
I need a usr manual my toshiba rd18dt dvd recorder
This just a plain DVD player?Not worth fixing,plain DVD player u could buy it new around $50 dollars.Buying parts and put times in fixing the old one proper cost more than the thing worth.
May 06, 2010 | Televison & Video
My in dash screen is white when i turn it on?
My indash TV DVD is not working proper. DVD player will not play DVD and the CD player has trouble reading some CD'S. I live in La Puente California is there anywhere near by to get it fixed?
Nov 16, 2009 | Icon DVD100 -TV Car DVD Player Car Video...
Upon trying to remove a disk, disk remains in player and tray opens empty
This is caused be the "lift" part of the mechanism not functioning properly. A fix may be inexpensive or not, depending upon what is needed to make it rise and lower properly....accordianman
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Mintek dtv-265-d dvd broke
To fix this problem, the following assumes you have unplugged and taken the back off the TV, and removed the metal shield around the mainboard. Open the back carefully as there are a couple of ground straps that must be unscrewed before the back is completely freed. There are plenty of lethal voltages inside the TV, so do this all at your own risk.
I'm an electrical engineer and I just fixed a DTV-265-D that I got with the same problem. I'm not 100% sure what fixed it, but I located the problem and can hopefully inspire some other findings by others. All TV/DVD buttons, and remote control signals go into a small miicrocontroller (U75) on the bottom left corner of the mainboard. This button converts all buttons and remote signals into a decoded data signal with a 5V level (normally high).
Just above and to the right of U75 is a small 8-pin chip that appears to split and send the data signal to the DVD module and the TV microcontroller at two different voltages. Pin 1 of this chip is on the bottom right of U18 and the pins increment counterclockwise. The important signals I found were:
-Pin2: 5V Data input from U75 microcontroller.
-Pin3: 5V data signal sent out the red wire of the connector next to U18 going to the DVD player.
-Pin5: 3.3V data signal sent to the main TV microcontroller.
-The other pins may switch this signal back and forth somehow, but I have no way of telling without a schematic
I found on my unit that something was causing the signal not to get properly to the TV or DVD player. I resoldered U18 and things started working again. I'm not 100% sure this is the final fix, but U18 IS THE ULTIMATE CAUSE OF THE PROBLEM. Neither buttons nor remote signals are ever getting to the DVD module or the TV. Once I resoldered, both signals on pin 3 and 5 were clean and everything worked again. U18 may need to be removed and replaced with a simple voltage divider to get the proper voltages to the proper modules, but I haven't tried to go there yet.
A way to test if this is your problem is to remove the red wire from the harness next to U18 (the harness going to the DVD player). Somehow connect this wire to pin 2 of U18 (there's a convenient test point nearby), reconnect power, buttons, etc. and CAREFULLY test. Now, ALL the buttons for DVD control will work again but not the buttons on the TV side will work. You should be able to eject the DVDs and this may have unlocked this weird state. You would have to restore the red wire back to it's original position to have proper normal operation.
I used (and would highly recommend using) an oscilloscope to fix and debug this. There are plenty of lethal voltages inside the TV, so do this at your own risk and only if you at least kind of know what you're doing with electronics. So far it's been a week and everything is still working fine.
Jan 05, 2008 | Mintek LCD TV Progressive Scan DVD Player
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
