Question about Curtis Audio Players & Recorders
My curtis keeps cutting off when it isn't fully charged up and the screen stop working so its all white.
  • 64 Answers
Try to restart it. there is a reset button, its like a hole. use paper-clip or any pointed object to press it. Also try pressing it while its connected to your computer.
Posted on Sep 30, 2010
Android keyboard (asop) has stopped working
My Kl? tablet (old one) isn't letting me use the keyboard, only a white bar shows up at the bottom. How do I fix this?
Mar 27, 2014 | Curtis ProScan 7" Capacitive Touch Screen...
Computer powers up but only a grey screen appears
Use Recovery Disc to repair. You may lose everything.
Aug 26, 2013 | Apple MacBook Pro Laptop Computer with...
Philips sonicare essence 5500 doesn't stop blinking
Turn it on and put it on the charger while still on. This should turn off toothbrush. And it stopped the blinking!
Dec 11, 2011 | Sonicare Philips Essence 5500 Toothbrush
My jazzy is used but i bought new batteries for it but the key pad will only cut on when the charger is attached. and wont cut on at all with out the charger.
super hmmm new batteries? well I would check the battery connections because you should be getting power to the joystick. The charger is providing power thru your joystick to be able to turn it on. Now when you plug in the charger are you getting any movement on the meter at the rear of the chair? If not but staying at zero then the charger is not charging the batteries and your batteries are not hooked up correctly. You will have to remove the seat and cover over the base to have access to the batteries check all the connections and make sure that if the plugs are colored that the red and white plug is plugged into the red and white plug going to the front of the chair and that the black and white plug is plugged into the black and white plug going to the front of the chair. If the wiring is ok then get a meter and read the voltage across each battery they should read 13+ volts fully charged. Plug in the charger and read the voltage at the batteries again if charging then you should read 16+ volts. If the voltage doesn't change then the charger isn't working correctly and if reading a good voltage then the batteries are bad and need to be replaced. Hope this helps
Apr 17, 2011 | Pride Jazzy Select 6 Indoor Power...
I have a Curtis LCD1922A and it comes on and has white screen then goes black
The ballast transformer of the cold cathode on your monitor is overheating.. Replace this..If the monitor is on and keeps on changing from white screen to black. The cold cathode light is almost up. Replace this one too.
Apr 05, 2010 | Curtis CM19033S 19" TV
MY SONY DCR-SR190 HDD CAMCORDER LCD SCREEN KEEPS CUTTING OUT, IT
mine started like yours then stopped working at all .It's a flex wire that connecting LCD with camcorder. it's very common. I did by miself, bought it in repair shop. works like new. mine is DCR-SR32 wire is 1-871-457-11 known as 1-871-457-21
good luck.
Meggita
Aug 16, 2009 | Sony Handycam DCR-SR85E HDD Camcorder
Helio will not fully turn on!
Hi i have had the Helio Hero phone which is no longer carried through Helio for some tech reasons. But this phone is horrible i try and turn the phone on and a white screen shows up i have to keep restarting it and taking the battery out and its fully charged, now it wont even cut on all the way i cant get it to turn back on
Feb 20, 2008 | Helio Kickflip Cellular Phone
Problem with new mobile
If you can try another fully charged battery, in your phone and it works then it might be a dodgy battery problem. leave the phone off to charge the battery for 10 hours and see if its better.
Dec 26, 2007 | Sony Ericsson K800i Cellular Phone
256 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
