Question about Compaq TFT8000 18.1" Flat Panel LCD Monitor
My monitor has a vertical magenta line permanently interfering with the display. anything i can do?
  • 11,361 Answers
New LCD panel is needed, noting you can do to fix bad TFT driving circuits which is part of the LCD panel assembly.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Sep 30, 2010
Hi, NEC P221 W multisync has increasinly been displaying fine vertical cyan and magenta lines, most evident on white areas and grey areas respectively.
Your monitor is no longer in production but there might be some support for it. Go here to see what's available: Product Support You might need to upgrade.
Jul 28, 2017 | NEC MultiSync FE950 (White) 19" CRT...
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor displays wide vertical stripes/bands
That is the symptom of failed T-CON board (part of the LCD panel assembly, new panel will be needed), you can try reseating the ribbon connector on the LCD panel first.
This what T-CON board looks like:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Apr 26, 2010 | Planar PT1814NUV 18.1 in. Flat Panel LCD...
My Display has a permanent white 1" vertical line about 2" from left side on my monitor. Start menu is OK but when loading running anything it is always on the top and makes everythin hard to read,work...
dead lines can be an indicator of a failing LCD screen or inverter. I would take it to a certified repair shop. The inverter should be fairly cheap, the LCD probably not so much.
Apr 18, 2010 | Dell Inspiron 9300 PC Notebook
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Magenta vertical stripe sets plus grid dots problem
Try using a diffrent computer on this and see if its not the video card doing it or if not its the controller board inside that connect to the video card that would need to be replaced at this time, if there are no dead or stuck pixels it might be worth replacing rather then buying a new one.
May 14, 2009 | Acer P191WBD LCD Monitor
Vertical line in imac 17" core 2 duo intel 2006 model
Attach an external monitor (you may need to buy an adapter to try this) and turn on Display Mirroring in the Display preferences.
If the same symptom shows on the external monitor, then you've got a video card problem. If not, I'd say you're screen has some kind of damage of failure.
Sorry, but either one is likely going to require a trip to the Apple Hospital.
At least with the display problem, you could use the external monitor until repaired.
Mar 16, 2009 | Apple iMac G5 Desktop
Green line
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you.
Mar 10, 2008 | Acer AL2216WBD LCD Monitor
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Compaq TFT8000 18.1" Flat Panel LCD Monitor Logo
401 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
