Question about Technics SL-1210 Turntable
Tecnics SL-1210 MK 2 Spare Parts & Needles
Were can I buy Spare Parts for my Turntable & Needles here in Mexico.
Thanks for advice!
  • 515 Answers
Not sure about Mexico, but you can get them online here:
Posted on Jul 02, 2008
Technics Sl-1210 MkII spins backwards
As the turntable was hit hard then an internal inspection should be done to look for signs of phyical damage. It could be anything from broken parts to bad soldering or a crack on the PC board. I rather suspect it should be obvious what got damaged when you look inside.
Feb 28, 2013 | Technics SL-1210 Turntable
I have two 1210s, a mk 2 and a mk 5. When I let go of a record on my mk 2 it seems to take longer to catch speed compared to my mk 5, and feels 'slack'. Any ideas what this is?
Being the older model, the chances are that the drive belt on the Mk2 turntable has got worn and shiny with use. It may also have stretched a bit. If you are using the tables for 'scratching', the fact that you are holding onto the turntable when the motor is running is placing a strain on the belt that it is not really designed for. I would recommend changing the belt - you can easily find spare belts for sale on the internet
Feb 02, 2011 | Technics SL-1210 Turntable
Poor quality sound
Double check all your cables. The only 2 things that affect sound on the 1200s is the RCA cables and the tonearm. I would first replace the RCA cables to a better quality set.
Technics Repair Videos
Technics Turntable Repair
DJ Equipment Sales
Technics Parts Sales
Jan 16, 2009 | Technics SL-1210 Turntable
Pop up inspection lamps blown
The original equipment replacement part number for this lamp is SFDN122-01E and is in stock from for around $7 plus freight. These are in white only, but you may be able to purchase small, rubberized covers (like a little lamp condom) from an accessory/parts distributor such as MAT electronics or MCM.
To access the lamp first UNPLUG THE TURNTABLE. Lock the tonearm in place. Invert the turntable. Remove the 4 audio insulators, remove the 17 screws with spacer and then remove the other 11 screws. Remove the bottom plate. Remove the 2 screws that hold the lamp circuit board in place. Then remove the lamp screw.
Hope this helps!
Jan 14, 2009 | Technics SL-1210 Turntable
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
Jun 10, 2008 | Technics SL-1210 Turntable
1210 mk 2 strangeness
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
Dec 01, 2007 | Technics SL-1210 Turntable
Technic turntable SL-101
These guys are pros.
Nov 07, 2007 | Technics SL-1210 Turntable
Technics sl 1210 turntable
What sort of problem are you having with the cords?
Sep 04, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
1,056 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
