Question about Lexmark X7350 All-In-One Printer
Lexmark x7350 printer enable bidirectional support
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Printers
Right-mouse click on the icon for the Lexmark printer
Click Properties
Enable the support (double-sided?)
Posted on Sep 30, 2010
New laptop with windows 7 won't print to Lexmark x7350. says to enable bidirectional support - but that option is grayed out.
Make sure to use the correct printer driver version for your operating system. You may need to uninstall your existing printer driver first before downloading the new driver. Go to Start menu > Programs > Lexmark 7300 Series > Tools > Uninstall. After the uninstall process, reboot pc when prompted.
When your computer turns on, go to Start menu > right-click on Computer > Properties. Check the System Type. Note: Use Vista driver in Windows 7.
Use the links below to download and install the printer driver: - Lexmark X7350 Driver for Vista/Win7 32-bit - Lexmark X7350 Driver for Vista/Win7 64-bit
Follow the instructions on your computer screen.
Jun 24, 2011 | Lexmark X7350 All-In-One Printer
Keeps telling me to enable bidirectional communication
Hi:
When you first loaded the print driver there should have been a box to check to enable bidirectional communication. Most Lexmark printers require this to work properly
Andrew.
Feb 27, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
How do I enable the bidirectional communications for a Lexmark printer series x5650es
Follow these steps:
  • Go to Printers and Faxes(XP)/ Printers(Vista and Windows 7) in Control Panel. Right click on the Lexmark 5600 Series print object and click on Properties(note: image below is just an example).
  • In the Properties window, go to Ports tab.
  • Enable the bidirectional support as shown in the image below(must have a check mark). Hit Apply then OK to save the settings.
If bidirectional support option is grayed out or cannot be enabled, problem may need further troubleshooting. Contact Lexmark technical support for further assistance. Thank you for choosing Lexmark.
Sep 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
CANT ENABLE BIDIRECTIONAL COMMUNICATION X4550
I have tried to set up this wireless printer on my laptop (windows vista basic). I run through installation and get message - installation complete and the green indicator light is fully on. When I try and print I get message Printer cannot communicate with computer - please turn on 'Enable Biodirectional Communication' in printer properties. I go to control panel/printer/propertie/ports/ and I see Enable Biodirectional communication - the box is grayed out and I cannot enable it. Any suggestions?
Jan 22, 2010 | Lexmark X4550 InkJet Printer
I can't get my Lexmark X7350 all-in-one printer to work on my windows 7 computer from dell. I get a message telling me to "Enable Bidirectional communication".
Its a driver issue, you need to contact lexmark and ask them if they have a driver that will work with windows 7 (theres alot of issues with scanner and printer drivers with 7) good luck
Nov 27, 2009 | Lexmark X7350 All-In-One Printer
Lexmark 3500-4500, enable bidirection printer
Bi-directional operation is a facility of the BIOS port you might use. it usually refers to a parallel port which can be set in the bios as uni directional or bidirectional so in the bios under PERIPHERAL DEVICES you would set to bi-directional.. so it is not something you can set in the printer settings. when it connects to the port the printer tests to see if it can use bidirectional transfers or not. If it can't it just means its a bit less efficient so will take long to transfer data. A similar error message might be issued for a network/wifi connection if a FIREWALL prevented communications. Or if you had used an OLD driver meant for a different older parallel printer. your printer is too new and should be wifi connected. You may have used a wifi ad-hoc pc-printer direct connection which could be causing the issue. preferred method is always printer-router-pc non ad-hoc using tcp/ip ports. so check your firewall settings http://support.lexmark.com/index?page=content&id=SO3908&locale=en&userlocale=EN_US
Oct 03, 2017 | Office Equipment & Supplies
When trying to print says enable bidirectional communication
I came up with a work around solution and for $9.99 I'll tell youo how I did it......
Jun 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
My x5470 says enable bidirectional communication when I print
In this case click on start and then go to Control Panel on control panel click on printers and then right click on the lexmark default printer which has a check mark on it and click on properties.......... On the properties window click on "Port" Tab and then check the option which says enable bidirectional support..................
Good Luck............
May 27, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X2500 is giving Bidirectional communication error message
Make sure that the "Enable Bidirectional Support" checkbox is checked: Go to "Control Panel"->Printers->Right click on the print Object->Properties under "Ports" tab, enable this check box if not already enabled. If you using vista make sure you do this from an "Admin" account, you may also need to select the "Run as Administrator" option after you right click on the "PrintObject".
May 10, 2009 | Lexmark All-in-One Printer with PictBridge
What it means Enable Bidirectional Communication
To enable bi directional printing:
Open Printers and Faxes in control Panel
Right Click on the Printers Icon
Select PROPERTIES
In the Properties dialog box select the PORTS tab
Near the bottom there is a check box to enable Bi-directional printing
Make sure it is checked
Click OK to exit the dialog box
Feb 17, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X7350 All-In-One Printer Logo
244 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
