Question about Monte Carlo (5LCR52MW) Fan
The pull chain for the light on my Monte Carlo Ceiling Fan will not retract. now I cannot turn light off. Any ideas?
  • 490 Answers
Well, you can take it down and replace the switch. Most decent hardware stores have generic internal switches. You could unscrew the bulb a little every time you want it off.
You could mount a wall switch for the unit and live with the fan and light always being on at the same time.
The pull-switch is not too difficult to replace, just seems scary. disconnect the unit from all power and do the work at the table.
Keep all fasteners in order of removal, and make notes or label parts with tape as you disassemble. Take a picture of the switch when you get it open and show it to the person at the store. Bring home the new switch and swap it in one wire at a time.
Reassemble, remount, and sew on your DIY achievement patch:) Farmerbear at FixYa.com
Posted on Sep 30, 2010
Testimonial: "Thank you farmerbear. I will try to replace it myself. I'll update ya when I'm done."
  • farmerbear
    farmerbear Oct 09, 2010
    How did it go? :)
Blown bulb
Ideas? Yep. Shut down fan power at the source (fuse, breaker, etc.). Turn on fan power again. You should be back in operation
Jun 14, 2013 | Monte Carlo Manhattan Ceiling Fan
My lights will not turn on
If you normally use a remote to control the lights and either pulled the chain or had a power failure, do the following:
1. Turn off the breaker that supplies power to the fixture
2. Remove batteries from the remote and press all the buttons to eliminate your remote as the source of your problem. Reinstall batteries
3. Turn on the breaker and try remote operation
Jan 27, 2013 | Monte Carlo 5RDRRB Royal Danube Ceiling...
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
The chain came out when i went to turn it off. now i can't start it.
turn power off to fan, and replace the pull chain switch. you can buy a switch at any hardware store. but take old one to get the right one for your fan. sometimes wal-mart may have one. good-day ! maybe the chain just broke. if this is the case, then just replace the chain if need be.MAKE SURE POWER TO FAN IS OFF WHILE CHANGING SWITCH !
Jul 11, 2011 | Monte Carlo Fans Indoor Ceiling Fans
Our fan is going in the reverse direction...how do we switch it?
mcdevito75 here, Generally, The Fan switch itself is a pull chain type switch on the fan motor itself, this is a fan speed switch, NOW! also generally the reverse fan swtich is another shorter pull chain switch just about an inch away from the Fan Speed switch or the longer pull chain switch on the fan motor. This reverse switch can also be a toggle type or slide type switch but will be close to the fan speed switch on the fan motor itself.
Jul 18, 2010 | Monte Carlo Dryers
Only have 2 speeds on a 3 speed ceiling fan- replaced switch, no
no no the problem is with the switch u need to re programm the wires check the old switch
and make the same conection.
Feb 08, 2009 | Monte Carlo (5LCR52MW) Fan
Monte Carlo (5LCR52MW) Fan Logo
228 people viewed this question
Top Monte Carlo Dryers Experts
ka4iup
ka4iup
Tom Chichester
Are you a Monte Carlo Dryer Expert? Answer questions, earn points and help others
