Question about Nintendo DS Lite Console
Action Replay; problem starting
My action replay DS is not getting read by my DS lite, it just says insert DS card. I just put in a really long code just before the inccedent and I don't want to lose it, so how can I fix it without restarting or replacing it. Can I open it up, and fix it that way or something. Entering the code was long enough the first time.HELP!
  • 6 more comments
  • missariffic Jun 12, 2008
    my action replay forgot everything on my game it's happened before.But this time when i entered in the game i.d. and pushed next red and light blue lines showed up and they were moving down the bottem screen. I called my friend who knows a lot about action replay he said it wasent normal and it hadent happened to him before and didn't know what to do .I really miss having it.Is there anything i can do without geting a new one? Please help me.
  • zelda31 Jun 13, 2008
    Same, I let my friend use it and when he gave it back it said insert game even though the game was fine. and all my cheat codes got deleted so when i tried to add another, red and light blue lines just started going up on the touch screen.
  • tennisluvr55 Jan 31, 2009
    i was trying to set up harvest moon ds on action replay and when i entered the ID code red and blue lines started showin up on my touch screen
  • samir48 Mar 03, 2009
    i use action and press some codes thn i pres star and it doent work
  • pk1004 Mar 28, 2009
    my action replay dose not turn on its just white screen
  • master113 Mar 29, 2009
    i have the same problem when i do the AandB thing it still dosent work.
  • aggfds Apr 26, 2009
    well one day i was putting in one looooooooonnnnnnnnnnnnggggg code. then the next day i turned it on then all i saw was a white screen how do i fix it?
  • Anonymous May 19, 2009
    I hate It it doesent work
You need to reset the AR, just hold down A, B, select, and start when poering it on, hold them down until the "not liscenced" screen shows up. This will flash the memory on the AR and you will need to re-enter codes though
Posted on Aug 28, 2008
When entering id for games red and light blue lines aperr on the touch screen
Posted on Jan 05, 2009
Press aandb befor you turn on the ds and press startandselect befor action replay screen
Posted on Mar 28, 2009
All my codes are GONE, NOTHING
Posted on Jun 19, 2008
Same with me i have the same problem as you and how do you fix the problem
Posted on Jul 01, 2008
    Champion:
  • 268 Answers
Im afraid its a damaged card, you might have a chance for repairs at the gaming repair shop but high chances are you will lose the memory
Posted on May 27, 2008
3 Suggested Answers
Jack Dye
  • 268 Answers
SOURCE: action replay
have a good blow where you insert your card, if it still doesnt work take it back for a replacement, you dont need to set up any settings what so ever
Posted on Apr 26, 2008
SOURCE: Action Replay does not find DS Lite even though USB is connected
theres 2 little metal strips on the AR USB connector, you have to carefully snip them off their furtheest to the end on each side. that will fix your problem
Posted on May 04, 2009
Action replay not reading sd card
u have to get a micro sd card and then put it in the ar (action replay)
Dec 16, 2009 | Datel Action Replay for Nintendo DS
Will not read game in action replay
well there could be 1 thing that is wrong. 1 ur ds might no be able read the action replay or that there is
Aug 11, 2009 | Datel Action Replay for Nintendo DS
My action replay dosent read my games
I had the same problem as you, and the only way to solve it is to put in the game card, then take it out and blow on the back of the card and in the card slot. You gotta do this, like, 4 or 5 times (did I mention that THAT SUCKS!!!!!!) and then it should recognize the game card. Hope this helps
--Josh
Jul 25, 2009 | Nintendo DS Lite Console
Action Replay code manager wont read me action replay
Your replay needs re-setting....
  1. With your console powered off insert the Action Replay DS
  2. Hold down buttons A+B
  3. Turn your console on
  4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
  5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
  6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
You can tell if it needs re-setting by...;
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
Jun 08, 2009 | Nintendo DS Lite Console
My AR won't read the game! Help!
heres what i did i put the action replay in select the codes i want then i take the action replay out and put the game in it may sound crasy but it works
Jun 03, 2009 | Datel Action Replay for Nintendo DS
Ttds card and action replay
You can't put an action replay with a TTDS in the same slot. The action replay cannot read all of the games the TTDS has.
May 02, 2009 | Pokemon Video Game Consoles & Games
Put game into action replay and it says insert game card help
I had the exact same problem as you, and I solved it. The only way to do it is to keep inserting and taking out the game card, and blowing into the DS card slot and the gold things on the lower back of the game card. After doing this about 3-5 times, the action replay should finally get the message that there is a game card in the slot. Hope this helps!
--Josh
Apr 12, 2009 | Nintendo DS Lite Console
My action replay won't read pokemon pearl anymore
you are idiot gamer of pokemon bastard wew you are weak.....
Jan 15, 2009 | Nintendo DS Lite Console
PLEASE HELP ME ASAP My Action Replay DS won't load
well as you said before....maybe the flash memory inside of your DS AR is corrupted...or even bronken..
I Believe it´s a AR hardware Problem...You can open the cartridge... Try to Clean the contacts..,See if you can find broken soldering contacts inside the AR...
Try to Check if the eletronic circuits and see if it is a real "CI" installed or a dismissable Chip "clone"
if it´s clone it´s certainly damaged and there´s nothing you can do to recover it..
Good Luck!
Dec 05, 2008 | Video Game Consoles & Games
Action replay
Apr 26, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
610 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
