Question about Lenovo ThinkPad T42 Notebook
Wireless network connection says not networks in range, make sure wireless switch is on. Fn F5 doesn't do anything
Geekman
  • 32281 Answers
SOURCE: Problems to configue network controller in IBM T42
There are several different LAN, wireless, & modem devices that are installed on the T40 series laptops. For example, if one of the network driver or modem driver doesn't work then install a different one. Make sure you download all the various device drivers for your model laptop and the XP version of those driver.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP device drivers for your model laptop,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
Posted on Mar 29, 2009
tonyw514
  • 66 Answers
SOURCE: Inablitlty to connect to other computer in adhoc wireless network
if the network is hosted by the lenovo s10 try connecting from the other computer also it would be helpful to tell us what operating system you are running on both computers at any rate here is a link that solved the problem for me. http://www.vistax64.com/vista-networking-sharing/108893-ad-hoc-computer-computer-wireless-network.html if that doesnt help or pertain to your operating system do a search on the same site under your operating systems. good luck and hopefully if you dont fix it someone with more knowledge comes along to help
Posted on May 24, 2009
SOURCE: switch on the wireless device first?
PLease locate the slider switch at the edge of your laptop. there should be a small slider switch for your wireless. Try to look at the sides or at the front of your keyboard.
Posted on Mar 27, 2010
Testimonial: "right but very late..anyway thnx"
  • 50 Answers
SOURCE: Lenovo T61 Wireless not connected
To turn on the wifi card. Make sure that the driver is install the press FN + F5.
Thanks for using Fixya.
Posted on Jul 28, 2010
  • 55 Answers
SOURCE: i' using lenovo 3000 g430,the problem is my
try to instal the driver again...
dis amble the w lan module..
clean the golden the yellow area with thinner or alcohol wait until dry and plug in again to the mini pci-e slot
change the wi fi module..
i had lenovo 3000 g430 too but i had no Bluetooth installed there? i there any Bluetooth on lenovo 3000 g430?
Posted on Jan 12, 2011
Wifi does not find wireless networks.
Most Laptops have a wireless switch on the side or in front of the Laptop. Some have a Function key (Fn+F5) to turn on the wireless radio.
Nov 26, 2012 | Computers & Internet
Where is the wireless switch located on the Fujitsu Lifebook A series model AH531?
I'm not sure where the switch is but to enable the wireless connection, you could go to the control panel>network and internet, in the left hand menu choose, Change adapter settings, right click on your wireless network connection and click enable.
Mar 16, 2012 | Fujitsu LifeBook AH531
How to turn on the wireless switch on my IBM T42
There isn't a switch on the T42. (I'm using one to write this). the Function (Fn) key toggles the adapters but only if the correct utility is loaded. That is on the lenovo site called 1qkcb9ww or 8jvu12ww. Not sure which controls those features. If Fn+F5 doesn't do it...
You otherwise usually get that message when there is a network adapter conflict and sometimes if the driver has become inactive which it does not too often. Try first disabling any other network adapters like Ethernet and maybe even the infrared network adapter though I doubt that could be it. Mine is disabled anyway. Do this in 'Network connections' from control panel for the Ethernet or with Device manager (Systems>hardware>device manager) if you never use a wired connection. If that doesn't help try reinstalling the drivers from the Lenovo site.
Andrew L.
Nov 22, 2011 | IBM ThinkPad T42 Notebook
Need help with which Fkey to push on the Elitebook in order to turn on my wireless network capability. I was told it was the F5 key but having no luck.
It must had been hard unable to connect wirelessly with your device. It's ok, F5 is part of it. But just for me to make sure i'm leading you to the resolution kindly follow the instructions below.
  1. Check the wireless switch. Make sure it is switched to the icon of a computer with signal on both sides.
  2. Press FN (usually on the left side of the space bar on the keyboard).
  3. While holding FN down, Press F5.
  4. You should see a notification on the lower right hand side of the screen that wireless is enabled.
Check your wireless capability. Thank you for choosing FixYa!
Apr 07, 2011 | Computers & Internet
I HAVE A DELL INSPIRON 1525 & I DNT SEE ANYTHING WITH WIFI. HOW DO I CONNECT TO WIFI IF I DONT SEE THE ICON?
Click Start > on the Start Search type ncpa.cpl then press enter > right click on wireless connection > click connect/disconnect then there will be another window, click on connect to a network and then you will see there list of wifi networks, choose one the connect to it, if youre not able to see any network,that means that the wireless capability of you laptop is off, check the wireless switch or try to press Fn F5.
Hope this will help... Please rate YES...
Jan 20, 2011 | Computers & Internet
Lenovo y430 wifi adapter not found in device
hi there, you wireless network card driver is probably not installed. check in control panel if your computer has detectde your wireless network card. got ot control panel then system then device manager and look for network adapters.make sure that wireless network card is installed there withot exclamation mark. if not present then reinstall the driver by using the driver disk that came with the system or going to the website http://consumersupport.lenovo.com. if installed, then try perssing Fn+F6 to enable/disbale your wireless card.
please let me know if you need more help.
Thanks
Apr 13, 2010 | Lenovo IdeaPad Y430-3231U Notebook
Hi - VAIO vgn-fz21m - can't locate the wireless switch/function
HI,
when you try to connect to the wireless network, you must be getting a message " turn on the wireless switch on your laptop "
See there must be a sliding switch on your laptop. it could be on the side panel or on the front panel. Try to locate the wireless switch on the laptop.
it must be having a wireless symbol on it like TOWER or Wireless signals.
On some laptops it is a combination of keys like Fn+F2 or Fn+F5.
If you have the user manual you will find the information about the wireless switch.
Click Here for more info about how to connect to the network?
Oct 07, 2009 | Sony Computers & Internet
I can't get my Network Adapter to connect to my Local Area Connection on my laptop. It tells me to turn my wireless capability but every time i flick the swith for it to be on it doesn't say it's on.
check the bios of the laptop to make sure the network card is enabled (at the BIOS hardware level)
check the FN + (F#) switch to activate the network adapter. for example, IBM\Lenovo is FN + F5 to activate the bluetooth and network adapter cards. In many cases, these settings are separate from the driver and software settings on the computer itself.
Nov 17, 2008 | Computers & Internet
Wireless radio adapter
if ur sure that that it is the fn and f2 that u have to press simultaneously to turn on wireless capabilty. Make sure u press it long enough
Right click on wireless network connection item in ur system bar and goto view available wireless connection and check what message is displayed there
If it still says that " No wireless network were found , make sure wireless switch is on "
Contact COMPAQ
If ur not sure whether it FN F2 , then try to FN & F5 or FN & F2
Feb 19, 2008 | 2wire (1000-000057-000) Modem
Lenovo ThinkPad T42 Notebook Logo
43 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
