My ipso washing machine wont spin, the pump doesnt open. It works fine, only every after 15 washes this happens. It can keep going for whole day and showing LEU error message. Anything i can do to skip this to END?\r\nthanks
  • edge155c
    edge155c Jan 15, 2013
    see if you have a clog in the dump valve
  • 105 Answers
SOURCE: Miele W1903 washer skipping steps (not fully draining?)
check the motor brushes could be worn out
Posted on Mar 15, 2008
  • 3 Answers
SOURCE: Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Posted on Mar 04, 2009
  • 718 Answers
SOURCE: Washer is not washing the clothes properly. Skipping cylcles
If it's new - check if it's under warranty. Let them solve it. Save you money. You've already paid for it once.
Posted on Apr 11, 2009
  • 3230 Answers
SOURCE: Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Posted on May 19, 2009
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
We have a load in....it is full of water....it wont drain and spin...the cancel button doesnt work and door wont open....I checked for kinks in drain hose...none. I took off top panel and front lower...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 12, 2010 | Kenmore Washing Machines
Washer wont spin. It went thru the whole wash cycle, but now it won't spin, and there is no error code. It comes on and the time counts down, but it doesn't spin.
Hello,Hi, If it doesnt spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thanks
Jun 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FWX233RES4 washing machine won't work
Sounds like there's something such as a small sock that has gotten sucked into the pump. This will keep the pump from spinning, cause extra noise, and the belts may appear fine but it may be stretched... if you're willing to deal with a little disassembly, unhooking hoses, spilling some water, you can probably handle this.... Good luck and let me know if you need any more assistance..
K
May 10, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine has packed a sad
The problem is definitely in the lid switch. Your machine has a reed switch which is located under the hob on the right side of the tub. There is a magnet built into the lid which activates the reed switch when the lid is closed. You will need to replace the reed switch and harness.
Oct 06, 2007 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
248 people viewed this question
Top Washing Machines Experts
