Question about Panasonic CT-32G11 32" TV
My 8 yr old Panasonic T Tau TV will not turn on. Problem is definitely not the power source as I switched plugs and tried other equipment in same plugs, all work but the TV. When I push the POWER button, nothing happens at all. I have the TV hooked to a HD Cable Box and it was turning on and off with the remote, just fine. Sometimes I would have to push the Power button on the remote more than once or hold it for a second or two and it would come on. Now, I get nothing through the remote or manually on the TV. The HD picture has been perfect, no problems till this one. Thank you.
  • Panasonic Master
  • 19,396 Answers
Hi.
If the TV is completely dead , then it is usually either power cord, power outlet or PSU. Other faults are quite unlikely to cause no power.
Since you can start TV from remotem then the problem is not a dead TV with no powe.
In your case the TV is in standby and does not wake up.
Try first using the channel up and down in the TV panel (not remote), if they operate the TV, then problem is the remote.
If the TV does not start using channel buttons, then the TV is in forced standby because a fault is detected.
In that case the stand by indicates that an internal fault has been detected. In theory you will need to call the service number listed on the user manual to get a technician to test your TV.
If you can start the TV occasionally, then common faults can concern the button board including IR sensor from TV, PSU, convergence , flyback and more.
Try first leaving the TV disconnected for at least one hour and see if it does start after that.
Also do a test with no connected device. mark connection cables to receiver and optical unit as necessary, then start TV with nothing connected. You should get no signal but TV will start unless faulty.
If it does then it is probably PSU or convergence ICs. Repair will be no less than $150/$200.
The TV can still be repaired, if there is a fault however I suggest to passing to a flat panel TV, which is more efficient and less power consuming than the CRT TV.
Posted on Sep 30, 2010
Panasonic tv troubleshooting
Hello, what is the model number of your tv? You might try unplugging it for a minute and plug it back in and see if it will turn on. tks
Nov 02, 2013 | Televison & Video
Panasonic HDTV 10801 BBE TAU
Unplug it for a few seconds and
plug it back in if this doesn't
do it the call in a technician
may be HV or PWR Sply problem
Nov 29, 2007 | Panasonic CT-32HXC14 32" TV
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
No screen vision or sound,plugs checked,mains turned off / on.TV only turns on at source.Remote signals not accepted apart from standby to on. TV also turns itself off. What else can i try to solve? 42"...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
You can look at the sample of the power supply board, the picture with the soldering side has labeling of what you should have on the output of the power supply, yours may be labeled on the top side of the board, there are high voltage on the board so you must be real careful, if you are not sure, let the professional handle it if you do not have the basic electronics knowledge
Since you do have sound, that means you do have the 5v and the 12v but may or may not have the 24vdc for the backlight inverter.
Hope this helpout
Aug 11, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have a 3 yr old Panasonic 42" Plasma
it might be coming from the actual audio/video source. try hooking up a dvd player or gaming system and see if it still does it.
Jul 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Panasonic Television
if bulb replace bulb
to check try turn on if at least a sound comes on take remote and hit the menu see if comes on
if no power its the power house replace power house
these device capsitors sometimes blow out make sure this is not a fused tv this could be the whole problem
if the tv completly died it could be *********** board
May 19, 2008 | Panasonic Televison & Video
Panasonic TV will not power up when power button pressed
caps in power supply failed look for 1000 mfd 16 volte caps.
Apr 13, 2008 | Televison & Video
CT32SX12F 32" Won't power on
when mine it, i had to replace a fuse
Jan 05, 2008 | Panasonic CT-32G11 32" TV
Panasonic 36HX41E Tau 36" HDTV Won't turn on
i think line out put transformer is leaking high voltage.if u r nat an technetion then dont try to on tv agin because high voltages can damage several costly ic in the set.
May 25, 2007 | Panasonic CT-32HX40 32" TV
Televison & Video Logo
180 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
