Question about Nordic Track NordicTrack Treadmill, A2550
Walking belt on NordicTrack C1900 is to loose, how do I tighten it? When walking on it when u get to level 4 it just about throws u
  • Anonymous Mar 13, 2014
    when you hit any speed button it starts to run but then shuts off
    Problem Solver:
  • 13 Answers
Tighten the rear roller bolts evenly with the unit off. The correct tension is when you firmly lift up on the right and left edges in the middle of the walking belt and get 2-3 inches gap above the walking board. If one side is looser than the other, the walking belt may wander sideways. Turn the rear roller screw on the side that it shifted to in a clockwise manner(1/2 turn at a time). Test on a low speed and adjust as needed. (you may manually recenter the walking belt with your foot if it shifted too far to one side and is rubbing on the plastic edges.) You likely have a worn motor belt that needs changing or even a pulley on the front roller that is slipping and needs replacing. They all cause slippage.
Posted on Oct 03, 2010
Belt stops when stepped on
sounds like the belt is loose.there are bolts at the back on either side that tighten or loosen the belt.adjust with belt running about 3mph. tighten both bolts about 1/4 turn each while watching the belt to make sure it is centered. give it about 15 seconds after you tighten to see the adjustment that u make.the walking belt should only be able to lift up a little bit like 1 inch. you shouldn't be able to get ur hand all the way under belt (not running of course).
Apr 09, 2014 | Nordic Track NordicTrack A2750 Pro...
Squeaky Nordictrack C1900
see the video attached. lube the rollers bearing front+back . Test the drive belt motor for to loose or faulty belt, and fix it.
However if the problem persist, TIME to replace the old board deck.
God bless you
Oct 20, 2013 | Nordic Track Nordictrack C 1900 Treadmill...
How to adjust the running belt??
Check page 27 in the owner's manual:
"If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD. Using
the allen wrench, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly tightened,
you should be able to lift each side of the walking
belt 3 to 4 inches off the walking platform. Be
careful to keep the walking belt centered. Plug in the
power cord, insert the key, and carefully walk on the
treadmill for a few minutes. Repeat until the walking
belt is properly tightened."
Dec 18, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a NordicTrack EXP1000. The walking belt was so far to the left that the edge began to fray. So, I adjusted the belt towards the right and now it slips forward now and then when it gets up to 3mph or...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
If their is still slippage then the drive belt will need to be adjusted.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Find the set bolt(s) on the motor.
This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt but do not remove.
The drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described above. Tighten the bolt and test. If the problem is not corrected, if problem persist replace drive belt
Jun 11, 2010 | Nordic Track Nordictrack Exp1000 Treadmill...
My nordic track c2000 apears to start working but then the belt stops, if i step off belt it starts working again
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it’s the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can’t find it, a standard (not metric) allen wrench kit will work. It’s helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you’re tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn’t necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I’m showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
You should lube the belt a couple of times a year. You can get them from iconfitness.com
Good Luck!
Mar 03, 2010 | NordicTrack Exercise & Fitness
Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Feb 05, 2010 | NordicTrack Exercise & Fitness
Our belt is slipping on our nordic track c1900 treadmill, how do i fix it?
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Sep 17, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Treadmill, A2550 Logo
1,090 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
