Question about Toro Garden
When i squeeze the gas bubble ,it will not fill up with fuel
    President:
  • Toro Master
  • 1,545 Answers
It doesn't have to be full for the machine to operate.
Posted on Oct 02, 2010
Why my weedeater idle to high and why air bubble in the primer bulb?
Its not un common to have air in the primer bulb, Check for a possible air leak in the system. This will make the saw idle higher than normal if its sucking air from elsewhere.
May 19, 2016 | Garden
How to replace fuel lines craftsman 316.292620
Initially release any clips by squeezing with a pliers and pushing back along the line. Lines can be prised off using a snipe nose pliers or flat blade screw driver, pushing on the edge of the line. Don't pull the lines which can stretch them.Two fuel lines leave the tank of a two stroke engine. The primer bulb sucks gas from the tank via the line with the filter on the end, gas returns to the tank via the other line without the filter. When you replace a line, to check whether they haven't been mixed up, fill the tank but leave the line without the filter above the level of the gas. When you push the primer bulb, gas should eventually squirt out the line without the filter. If the lines are mixed up, air bubbles will flow out of the filter and no gas out the other line.
For a pictorial guide and more info on troubleshooting 2-stroke engines and carburetors, see my guide here:
String Trimmer Won Work 2 Stroke Engine and Carburetor Troubleshooting
May 14, 2014 | Homelite Mighty Lite Lawn Trimmer
Car stalls while driving but starts back up
When you fill the car with gas if you dont stop when it is full and you continue to make the tank take more, you dont leave any room for expansion. The fuel expands and can cause orings to fail when it gets warm. If you have trouble filling the tank because of the issue that you stated, the problem might be due to a collapsed filler hose. If you are running the engine when you fill it, the noise is from the fuel return line.
Dec 02, 2013 | 2005 Mazda 3
My 2003 Toyota Tacoma extended cab has a gas tank filling problem. I can only squeeze the gas nozzle with the tip as high on the filler tube as possible to put in about 1/4 gallon of gas per squeeze of...
Many vehicles have a rubber hose between the filler tube on the body and the gas tank. Check that it's not collapsed or that something maybe got in there and squeezed it partially shut. The rubber tube may need replaced. Please rate this answer, thanks.
Feb 04, 2011 | Toyota Tacoma Cars & Trucks
Try to fill gas tank, gas pump nozzle clicks off, sometimes as much as 10 times in 1 gallon pumped. Something wrong with pipe to tank?
There should be an air vent coming from the top of the gas tank back to the top of the fuel tank. Possibly kinked or pinched, try pulling the fuel nozzle about half way out and filling the tank on the lowest setting the fuel pump will let you.
Please take a moment and rate my answer...........Thanks
Dec 01, 2010 | 2003 Chevrolet Impala
Poulan pro 625 series Will not start. I have changed the spark plug. Tested the plug for spark (yes) Checked the primer- works , sprayed starting fluid in spark plug hole and intake -nothing. it act like...
1st: stale fuel...won't burn...regardless of spark...
2nd: watch primer when it comes back up, it must "fill" with fuel...a tiny bubble is o.k. If not, carb replacement...
3rd: Flood to hell and back...remove the plug, pull 5 or 10 times to clear the gas...dry off plug...install...hold trigger wide open, and pull..NO PRIMER
if this works, go back and review starting procedure
8^)
Apr 17, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Is there a gasket under the primer bubble;it won't **** up gas
the pick up tube in the fuel tank is probably bad
Sep 16, 2009 | Garden
Gas trimmer - not getting gas
the primer bulb needs to be replaced, if it has a small hole in it
Sep 09, 2009 | Garden
Fuel fill takes forever on 2003 Hyundai Accent
Sounds like the charcoal canister - replace it.
Apr 21, 2009 | 2003 Hyundai Accent
Garden Logo
59 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
