Question about Galaxy External Enclosure - Metal Gear Box II - 3.5in USB 2.0 + 1394 Hard Drive (3506UEP) Drive Case
I have a Galaxy Raid Pro that was setup as a Raid 5. The system appears to have lost its configuration and I am unable to access any of my data. I located a configuration file but am unable to load it onto the system. Any ideas on how I can get my data off of this POS??
  • 3 more comments
  • info88088 Sep 30, 2010
    The drives are on a NA System. Not on my physical computer. This program only appears to work on drives that are physically connected to the PC.
    I am unable to connect it to the compter because the NAS has no configuration and won't accept a configuration file. The program is looking for .imc, .img, .vim files which do not exist.
    I understand how Raid 5 operates. The configuration file on the Galaxy NAS is nonexistent. I am unable to load a configuration file. The data is still on the disk but, without the configuration file, I am unable to access the data. I have a old configuration file which the system will not accept. I am unable to connect the NAS to my computer to utilize the program you mentioned without a configuration file. The program you mentioned is looking for .img, .imc, .vim files which do not exist.
    No IDE or SATA ports available. Running everything from laptops.
    Any suggestions other than contacting a data recovery company?
  • 4,323 Answers
Hi
You can try recovering the data from your Galaxy harddrive by downloading and installing data recovery softwares from these link--
Data recovery softwares link 1
Data recovery softwares link 2
Data recovery softwares link 3
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 30, 2010
  • 857 Answers
The best way to do it is to use this sofware to recover it
you get a 30 days free trial :
http://www.runtime.org/raid.htm
to download the software go to this link :
http://www.runtime.org/raid.zip
  • 3 more comments
  • Jayant Jha Sep 30, 2010
    Thats not a problem i belive , you can connect it to the computer and use the program.
    Read a bit about rais 5 :
    How RAID 5 Works
    •RAID 5 utilizes three or more disk drives to protect data contained on any one of the drives. Data is spread throughout the array of drives. Furthermore, a computer constantly executes parity checking, a calculation performed on data bits to check for data errors. Unique to RAID 5, parity information is also stored on each drive, according to Seagate. This facilitates reconstruction of data contained on a failed drive onto the remaining operational drives.
    Replacing a Failed Drive
    •If a disk drive fails in a RAID 5 environment, simply replace the failed drive while the computer system continues to access reconstructed data on the operational drives. This procedure is called a hot swap. Once a new drive is installed, RAID 5 begins the process that reloads data and parity information onto the drive.
    Considerations
    •Additional levels of RAID exist. Review the data loss protection requirements of your organization to determine which RAID level is right for your environment. In addition, RAID 5 provides limited data loss protection. Therefore, off-site data backup storage is necessary to recover from a major disaster that destroys all disk drives.
    Follow these steps :
    1.Disassemble your NAS device (e.g. WD MyBook)
    2.Remove internals hard drive(s) from the NAS box
    3.Insert all of the hard drives into your PC, and connect them to available IDE or SATA ports
    4.Run DiskInternals Uneraser, Partition Recovery or Raid Recovery
    5.Perform the recovery by following prompts of the Easy Recovery Wizard
    Choosing the Right Product
    DiskInternals offers three different products that can recover data from NAS devices as well as repair the disks.
    1.DiskInternals Uneraser is the least expensive option. Use Uneraser to just recover files and data from the disk(s) you tool from the NAS device. Note that Uneraser will not repair the damaged system structures such as the file system and boot partition tables.
    2.DiskInternals Partition Recovery can do everything that Uneraser can do, as well as repair the system structures of the damaged disk(s). Note that while Partition Recovery can recover data from single disks and RAID arrays, it cannot fix system structures of a RAID.
    3.DiskInternals Raid Recovery is the most expensive and most advanced product manufactured by DiskInternals. Raid Recovery can recover files and data from single disks and RAID arrays, fix system structures of single disks and RAID arrays. Raid Recovery detects the exact type and configuration of a RAID completely automatically, which is important as there are numerous different NAT systems available.
    DiskInternals data recovery products, including Uneraser, Partition Recovery and Raid Recovery, fully support the Linux file system as well as all types of Linux RAID, including Linux RAID 0, 1, 4, 5,
    Well in that case it wont be possible to get that done on your own,
    keeping the importance of your data in mind i thisnk you should contact a data recovery company.
    Well u can use any desktop computer.
    Take it anywhere else where you can get a desktop system.
    Because its very difficut to do it through a laptop.
How to save a raid0 disk
Raid O is no RAID. Data is lost if the hard drive failed. Always use RAID 1 (mirrored) for OS and RAID 5 (striped) for DATA. That's 5 drives your server should shave been configured with.
Jul 16, 2012 | HP Compaq ProLiant ML350 G5 Server
Our Hard drive is failing due to reported mechanical error ---- not software problems. Two companies have been unable to retrieve vital scientific data and a third company has stated it is impossible to...
There is not much you can do except try some other data recovery companies.
If your data is very important, in future you should consider doing data backups on a daily basis and/or build a fail safe computer or server system using RAID hard drives configured as a mirrored hard drives or a RAID 5 system with hot swappable hard drives. Also consider installing a UPS (uninterruptable power supply) to prevent a computer and server shutting down from power outages as this can will corrupt your data.
I hope you will take this advice seriously.
Oct 20, 2010 | Computers & Internet
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
I can't get the RAID 5 array setup on my computer. Can someone help?
Can you give more details? What have you tried, what doesn't work ...
Aug 03, 2010 | MSI 880GMAE45 AM3 AMD 880G USB 30 Micro...
How to use sata raid
Open the links provided below to help setup an array; http://www.pcstats.com/articleview.cfm?articleID=830
And; http://www.pctechguide.com/tutorials/RAID.htm
Motherboards that support RAID will have a bios setting that will need to be enabled. The links above will help you setup an array.
Cheers'
Mike
Apr 08, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
How do I recover data from raid drive hard drivesrunning XP Pro ?
The failure of just one drive will result in all data in an array being lost.
What you really need to decide is whether continue with RAID (I DO NOT RECOMMEND THIS OPTION) or go with a more conventional setup where you can dramatically the reduce the risk of data loss and be better prepared if a drive happens to die. Did you have a backup?
Nov 28, 2009 | Computers & Internet
I fried one of my graid drives how do i get the other to work
The G-Raid drives use RAID-0 which splits data across both internal drives, so unfortunately the remaining drive will not be able to be used to recover any files as it will only have fragments of each file on it - the other fragments having been lost on the faulty drive. Also, you will need to contact G-Tehcnology to get a replacement drive - the drives used (from memory I think they are Hitachi) have special firmware on them and other drives will not be compatible and you'll start getting strange errors.
G-RAID drives are designed for high-throughput work like video editing, not for redundancy - they should be treated as a single drive where if the data is important you have a copy of it on another drive. Keeping data on only one drive is not a back-up, it's a problem waiting to happen. Sorry I couldn't give you any good news.
Oct 06, 2009 | GTech G-RAID 500 (90700501) 500 GB Hard...
Harddrive array sequence causing system in booting
If the only drive you changed was the drive that failed and all the others are in the correct sequence, then that's a good thing.
The next question is, did you have this system setup in a RAID Array and if so, what RAID configuration were you using (RAID 0,1,5, etc.)? Some RAID configurations allow you to replace a failed drive and not lose data, but I will need to know more about how you set the system up in order to help you more.
Jun 18, 2009 | HP ProLiant ML370 G4 Server
Raid w/ hard drive defunct
Well lets make some assumptions
1. You have a Raid 5 System
2. You only have 3 drives in the Raid ARRAY
3. Only 1 drive has failed
To fix the problem you should only need to Replace the Failed Drive
Then start the raid management software or bios
Rebuild the array
If you have more than 1 drive failed in a RAID 5, and still must recover the data it is possible. But very expensive. Still fixable however.
Sep 23, 2007 | IBM xSeries 226 Server
Help please to restore the failed raid
Well if your data is gone at this point, you mines well just proceed with rebuilding a new RAID 5 set with your replacement drive. Even if one drive fails in a RAID 5 set, your logical drive should still be accessible. Goodluck.
Jun 14, 2007 | Quantum Guardian 4400 120 GB Hard Drive...
Galaxy External Enclosure - Metal Gear Box II - 3.5in USB 2.0 + 1394 Hard Drive (3506UEP) Drive Case Logo
181 people viewed this question
Top Galaxy Computers & Internet Experts
Chance Miller
NOEL
NOEL
Are you a Galaxy Computer and Internet Expert? Answer questions, earn points and help others
