Question about Apple iPod MP3 Player
How do i unlock my 4gb ipob
I tried resetting it and everything..i was playing with the settings and i pressed lock ippod or watever it says and i dont have the orginal computer to unlock it ..what can i do ?
  • Apple Master
  • 13,433 Answers
My samsung mobil GT- i9003 is locked
Thank you for providing all the info! Greatly appreciated!!
Now on to a solution. You can try to do a factory reset. You don't need to log into the phone in order to do one. However, this WILL erase everything on your phone, and revert it back to when it was originally purchased. Not sure if the unlock will remain.
To do a factory reset:
1) Turn off your device
2) press the power button and the volume up button simultaneously until it takes you to a new menu.
3)Use the volume keys to navigate, and the power button to select (Exact directions are provided on the screen)
4) Look for an option to "Wipe/Factory reset" (Note: It might be located in a sub menu, and not actually on the first screen.)
5) Select that option and press the designated "OK" button. (usually the power button).
6) Phone will reboot and you should be able to get back in.
Hope this helps!!
Jun 22, 2014 | Samsung Unlocked i9003 GT-i9003 4GB Galaxy...
My Samsung GT-i9003 is locked fo pattern lock & email & password lock
  1. first press Up Volume Key on phone and hold it on lock screen.
  2. then press on the home button and hold it.
  3. Last the power button and after it starts up just release it.
  4. A menu will come up.
  5. just click on home button to select up and down in the menu.
  6. go to third option named as "DELETE ALL USER DATA".
  7. It can take up to a couple minutes.
  8. the phone will restart and the unlock pattern problem is fixed.
    *note this will reset phone to factory settings, but it will allow you to access it again.
How do i unlock a proscan plt8816k if i dont remeber the email and password?
Your problem doesn't make sense. You cannot try the password too often. Try a factory/hard reset.
Google search "reset android tablet"
May 10, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storage• : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
How to restore HTC One V T320e smartphone
Performing a factory reset using hardware buttons
If you can't turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V.
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
[img title="unlock HTC ONE V hard reset forgotten password" alt="HTC ONE V hard reset" src="http://www.hard-reset.com/images/htc_one_v_hard_reset.jpg" height="350" width="180">
will remove any applications you've downloaded and installed. Be sure to back up
any data and files you want to keep before you do a factory reset.
Performing a factory reset from settings
1. Slide the Notifications panel open, and then tap Settings.
2. Tap Storage > Factory data reset.
3. Tap Reset phone, and then tap Erase everything.Performing a factory reset via settings
The most convenient way to do a factory reset is via the settings.
1. From the Home screen, press MENU, and then tap Settings.
2. Tap SD & phone storage > Factory data reset.
HTC One V not responding?
If HTC One V frozen and does not respond when you touch the screen or press the buttons, you can still restart it by press and hold the POWER button for at least 10 seconds, and then release it. HTC One V then restarts.
Sep 26, 2013 | HTC One V T320e - 4gb - Grey Unlocked...
How to unlock a trio stealth pro 4.0 0S if forgot pattern lock
i got a trio stealth about a year ago but now my son lock it and cant find a way to unlock it pattern please any one help me with this thank you so much
Dec 26, 2012 | Mach Speed Trio 4GB 7" Trio Stealth Pro
My 4gb nano froze up on me can you help me get it unlocked?
ResetTo reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Apr 01, 2008 | Apple iPod nano
Forgot my unlock code!
i changed my unlock code and set it so my phone locks as soon as you turn it on. But I forgot the code.... And i cant acess anything in the phone without it.. Help me plzzz
Oct 30, 2007 | Motorola Mobility SLVR L7 Cellular Phone
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
Apple iPod MP3 Player Logo
26 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
