Question about Samsung CLX 3160fn All-In-One Printer
Smart thru scanner program is gone. (for Samsung 3175 CLX 3175FN/XFA) Cannot find driver. Every site showing it i a scam that forces yu to download their "driver" program that does not solve the problem. Running XP Pro
  • Samsung Master
  • 6,487 Answers
You should be able to download all driver for this unit from this link, just click HERE.
Posted on Sep 30, 2010
Samsung clx 3175 one toner is empty.how do i find out which toner is empty??
Dear
Kindly install a samsung smart panel software from samsung.com.
Alternately it will display on operation panel lcd of the printer itself.
Mar 15, 2012 | Samsung CLX-3175FN Color Laser All-in-One...
Hoe to enter mode service samsung clx3175n
Log into the service menu Samsung CLX-3175 without a numeric keypad similar tothe unit Samsung SCX-4623F/FN:
Consistent set of combinations of
"MENU" - "COPY ID" - "LEFT" - "RIGHT" - "MENU" - "BACK" . Samsung CLX-3175XX/X with a numpad press: Menu, #1934, Menu
The unit switches to English, if you installed any other.
In the menu appears TECH MODE.
In
Samsung CLX-3175 to enter the reset require a password 1934. The numbers by pressing "LEFT" - "RIGHT",
After each number press the "OK"
Good luck in the reset.
Have any questions, you here http://skit-ltd.narod.ru
Jul 10, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Hi, The printerfunction of my CLX-3175N works fine, but when i try to scan it says: not available. How can I fix that?
go to samsung download site and download the scanner driver for your printer after installation reboot your computer then try, it should work.
May 15, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I can't get my scanner clx3175n to scan to pc
Your computer may not have the correct drivers installed in order to detect the printer's scanner. Try downloading the correct drivers for your computer at this link. http://www.samsung.com/us/support/downloads/CLX-3175FN/XAA
May 12, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I need to downgrade to previous firmware for Samsung CLX printer. (clx-3170 0r clx-3175)
Unfortunately, once you install a firmware upgrade it is permanent. Driver updates can be reversed but not firmware. That is why you should always have a definite reason for upgrading the firmware.
Jan 06, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Mar 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
What toner does the clx 3175 take. Does it use a chip as well - which one?
Takes CLP 310
To use Toner refill you need a chip that solder to the main board. search Ebay for reset chip for CLX-3175
run around $40.
Service Manual Free
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Feb 12, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I changed wireless networks and the printer has gone offline. How do I get it back in ready mode? samsung color laser clx-3175
if you changed the wireless router you will need to make sure the settings are the same as you had them before you changed or reinstall it
Jul 21, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Sanner is locked!
Service Manual at
May 31, 2009 | Samsung CLX-3175FN Printer
Sanner is locked!
Look at scanner mechanism under glass. See if the clip has popped off of the slide guide "tube". Also, there is a scanner lock on this model. I believe it is near the back by the hinges but you can check the manual to be sure.
Apr 14, 2009 | Samsung CLX-3175FN Printer
Samsung CLX 3160fn All-In-One Printer Logo
233 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
