Question about Samsung DVD-Homecinema-Sound-Package HT-Z110R black
El home cinema systen ht-z110 samsung me dice hello protec y no me dejar funcionar ,que le pasa
ginko
  • 19396 Answers
SOURCE: When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
SOURCE: SAMSUNG DIGITAL HOME CINEMA SYSTEM MODEL HT-Z110
Maybe the audio amplifier Ic are damaged and need to be replaced
Posted on Aug 14, 2009
lscf150
  • 443 Answers
SOURCE: when i switch on my samsung HT-Z110 the word hello
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Posted on Nov 29, 2009
Testimonial: "well it matched your suggested solutions for my problem, i need to send my unit for service, thank you very much!"
SOURCE: samsung ht z110 says protect an then switches off
Audio amplifiers IC´s damaged need to be replaced
Posted on Jan 06, 2010
SOURCE: My Samsung HT-Z110 does not play any DVD's anymore...
check if the cds works if they work you need to replace the motor disc spindle
Posted on Jan 11, 2010
Arranca pero se apaga
Parece que se te dano el alternador, me parece eso por lo que decis, seguramente esta arrancando con la bateria, pero no puede recuperar la potencia usada (W) con el alternador. Podes intentar colocar un voltimetro a los contactos de la bateria, prender el carro y si el voltaje (DC) no se sostiene entre 10.5 - 12 voltios, puede que uno (o el unico) problema del carro sea el alternador...por que pasa eso?, por que los carros son asi y si te estas preguntando si el dejar las luces encendidas dana el alternador? pues no... y no tiene que ver nada lo uno con lo otro, pero te repito, los carros son asi.
May 04, 2014 | 2006 Honda Civic Hybrid
COMO DESBLOQUEAR LA CASETERA DEL DVD SONY DVP-SR320
prendo el dvd y cuando quiero sacar la bandeja me sale bloqueado que puedo hacer grasias
Apr 30, 2012 | Sony Televison & Video
AYUDA! hablemos ingles no quiere funcionar porque me dice que no puede inicializar el servidor del habla. que puedo hacer?
He encontrado la solución.
1-Instalar Hablemos Inglés en el Vista.
Hay que instalar una máquina virtual (Virtual Box por ejemplo), con el Windows XP, y crear una carpeta compartida (la que tenga Hablemos Inglés instalado en el Vista). Se ejecuta el programa desde XP, y se graba una palabra para que inicie el servidor de habla.
2-Se pasa al Vista sin cerrar Hablemos Inglés en el XP.
3-Ejecutamos Hablemos Inglés desde Vista, y empieza a funcionar.
4-Ya podemos cerrar la maquina virtual con el XP.
Es un poco complicado, pero funciona.
Ojo, si utilizas Hablemos Inglés desde el XP virtual, probablemente el sonido de las grabaciones no sea bueno, por lo que hay que utilizar la versión que corre en Vista.
Todo esto es para hacer que se inicie el servidor de habla, y vista pueda ejecutarlo.
Saludos y suerte.
R@in.
Apr 26, 2011 | The Learning Company HABLEMOS INGLES - VER...
Mi control de dish no quiere hacer nada quien me ayuda
Hola mi nombre es Kimberly Escobar con DISH Network servicio al cliente. Lamento escuchar que este teniendo un problema con su control de DISH Network, seria un placer asistirle proveyendole informacion que le sea de uso para resulusionar el problema. Si el control no esta haciendo nada primeramente debe asegurarse de que el control este en el modo de SAT significando que cualquier boton que oprima el control el boton de SAT en la parte de arriba se debe encender en rojo. Si ningun boton se enciende en rojo puede intentar poner baterias nuevas en su control, si no funciona significa que el control no sirve necesitaria uno nuevo, si el boton de SAT se prende en rojo puede intentar reprogramar el control a su recibidor. Para hacer esto tiene que accesar la pantalla de System Info en su televisor, puede hacer esto oprimiendo el boton de Sys Info enfrente del recibidor. Despues en el control va a oprimir el boton de SAT hasta que los demas se enciendan rojos cuando vea que se encienden rojos ingrese un numero entre 1-15 seguido por el signo de numero (#) y el boton de record una vez. Trate el control deberis funcionar. Tambien puede entrar a nuestra pagina web http://www.dishnetwork.com/SupportSection/remote-control aqui encuentra ayuda en como arreglar el control y el procedimiento. Si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH gracias espero esto le ayude.
Feb 09, 2011 | DISH Network IR Remote Control
Hola, mi pc; la prendo y al pricipio enciendie la luz verde y en unos segundos pasa ea quedar la luz roja intermitente. lo que paso fue una descarga electrica cerca de la casa y desde ese momento quedo...
ok, antes que bayas al link de abajo me gustaria que abrieras el case de la computadora y le desambles la RAM memory. son dos o una tarjetita larga que esta al centro de la motherboard. no toques nada mas. solo desamblela por 30 segundos y pongala para atras. y si no ve al link este para que veas el problema de la luz roja (inglish version) ve al final de la pagina donde dice.
Computer Diagnostic LEDs (on front of computer)
http://www.dectrader.com/docs/set1/265763-003.pdf
de acuerdo a el compaq manual dice que tu CPU podria estar da?ado.
espero esto te ayude de algo.
Dec 15, 2010 | Compaq Evo D500 PC Desktop
Mi problema es que al amanecer enciendo mi f150 modelo 95 se comienza a sacudir sufriendo aceleracion y esaceleracion del motor el tablero se pone loco el indicador del alternador sube y baja y yega el...
Sugiero revisar sistema de envio de combustible, presion de bomba, asi como componentes que mantienen el minimo (ralenti) del vehiculo. Descartado eso, verfificar sensores IAC y oxigeno.
Oct 19, 2009 | 1995 Ford F150 Styleside Regular Cab
Tengo una liberti sport 2002 y de repente se le
PUEDE SER UNA CABLE DE TIERRA QUE ESTE HACIENDO FALSO CONTACTO CASI ES LA MAYORIA DE LOS CASOS QUE PASA ESO. CHECA TODOS LOS CABLES DE TIERRA AL CHASIS QUE ESTEN BIEN CONECTADOS POR QUE HABECES CON UN BRINQUITO ES CUANDO LA TIERRA HACE FALSO CONTACTO Y SE APAGAN LAS LUCES
Aug 10, 2009 | 2006 Chrysler Executive
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Samsung DVD-Homecinema-Sound-Package  HT-Z110R black Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
