Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have a problem with my red convergance - RCA D52W20 52" Rear Projection HDTV-Ready Television
  • RCA Master
  • 5,138 Answers
With off press and hold at same time Vol- and CH- hold untill TV comes on ,then release ,You should now be in Factory Service Menu, try adjusting Red then.
Posted on Sep 30, 2010
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Where are the convergence chips located on my 60PP9202 for the red
There are 2 Convergence Chips: 1 for Horizontal (it includes Red, Green and Blue Convergence channels) and 1 for Vertical (it includes Red, Green and Blue Convergence channels). Horizontal Convergence Chip is 7044 and Vertical convergence Chip is 7045 (both STK392-120). They are fixed in same "big" Heat Sink, with a 2 metal black clips, from Video Inputs board side.
Oct 19, 2009 | Philips 60PP9202 60" Rear Projection...
My RED Convergence is OFF and giving me a RED Blurr. When I try to adjust it manually with my remote, the RED doesnt respond, only the BLUE responds. Does anyone know how to fix this issue? Is it WORTH...
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jul 19, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Mitsubishi VS50805 Serial # 102718 No red in picture
Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
http://servicemanuals.vstore.ca/
Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Convergance
you need to have both convergence ics replaced STK392-040 (2).resistors 3.9 ohms they will be open.
Jul 27, 2008 | Samsung HCN4727W 47" Rear Projection...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Red convergence will only move up or down
Stk392-110 red convergence IC is bad...normal procedure===
1) pull chassis   2) replace both Stk's for reliable repair
3)re-assemble  4) re-align convergence
If you hire a technician, 400.00 is ave. price.
Oct 16, 2007 | Toshiba 50H72 50" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
