Question about Samsung SCX 4200 All-In-One Laser Printer
When i print, the paper is always streaked with smudges and streak lines that don't meet. The cartridge is new and when i insert in another printer it work perfect. So i thing it is printer problem and how do solve it?
  • 67 Answers
Well , if the same set of cartridges are working in another samsung printer .. then it ought to be the printer problem. You can call the tech support of Samsung printers .. and get the printer replaced..
Posted on Sep 30, 2010
Streak along edge of paper, Canon MF8380Cdw
Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
How do you clean the copper parts of the cartridge
Turn the printer on and then fill the paper tray with paper.
If this is an HP printer, press the "Setup" key until "Tools" is shown on the control panel display screen. Follow equivalent steps for other printers by reading the user manual.
Press "OK." If your printouts continue to be faint, show white line streaks or smudges, go to the next step to clean the contacts on the print cartridge.
Open the print cartridge access door. Wait until the print cartridge moves all the way to the right side and completely stops.
Remove the power cord from the electrical outlet.
Press down on the top of the cartridge and lift it up toward you holding it by its sides. Avoid touching the copper area when you lift it out of its slot. Sit it down on a flat surface, such as a table.
Wet a lint-free cloth with water and squeeze out any excess.
Pick up the cartridge by its sides and avoid touching the copper area.
Gently wipe the copper contacts of the print cartridge with the dampened, lint-free cloth. Be careful not to wipe the copper nozzle part on the bottom of the copper cartridge.
Let the print cartridge dry for 10 minutes and then plug the power cord back into the electrical outlet.
Reinstall the print cartridge. If your printouts continue to be faint, show white line streaks or smudges, go to the next step to clean the nozzle area (copper bottom part of the print cartridge.).
Repeat steps 4 through 7 and then gently wipe the nozzle area with a clean, dampened lint-free cloth.
Let the print cartridge dry for 10 minutes and then plug in the power cord back into the electrical outlet.
Reinstall the print cartridge. If the ink is faint, or streaks or lines show on your printed pages, the old print cartridge may be defective and cannot be cleaned. Replace the old print cartridge with a new one.
*If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 26, 2013 | Dell 966 All-In-One InkJet Printer
Use a hp deskjet 35200(3500). when unit is printing all lines are blurd and paper gets black streaks all over. The printing is unreadable and smudged.Is there a manner to clean this up?
Streaks:Cleaning interior
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it
Feb 06, 2011 | HP Office Equipment & Supplies
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
My printer streaks ink across the paper when i print
just replace toner cartridge. I think the cartridge drum is broken
May 21, 2010 | Samsung SCX 4200 All-In-One Laser Printer
It prints vertical lines where the text is.
check your drum unit. The toner cartridge mounts into the drum which can be permanently charged causing a constant streak to occur.
Solution:
Remove the toner and drum unit. Clean them off with a non-fuzzy non-rough cloth or paper towel. Pay particular attention to where the streaks are in relation to the toner cartridge and drum. If you clean it off and you still get streaks check whether they transfer from the toner or just from the drum.
There may be a way to discharge the drum, otherwise you need a new drum.
Feb 27, 2009 | Dell 946 All-In-One InkJet Printer
Print page on SCX4100- streaking lines
Clearly bad toner cartridge. After long periods of time, the cleaning blade dries out. This cleaning blade works just as the wiper blades of your car. When they wear or dry out, you get streaking water lines in the windshield. Most manufacturers print an expiration date on the consumables wichi you can check before purchasing. Also try not to stock more consumables than those you plan to use within 6 months.
Nov 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
96 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
