Question about D-Link AirPlus DI-524 Wireless Router
Validating identity Hi all i was on my wireless broadband as normal on a di-524 everything ok and fine this was Saturday 24th May and the next day i went to connect, it would not connect it says validating identity. Also says windows can not find a valid certificate to log me on di-link network and yet everything was fine 8 hours ago. Nothing has been altered so now i can not get on internet unless i connect the ethernet cable straight to my laptop from the modem. Please help has this is so anoying as i know everything was ok. Why has this happened and how can i get back wirelessly.
  • 1 more comment
  • Graham Anderson May 25, 2008
    Hi sorted now i tried both of the solutions but failed so i re-installed network settings for my d-link and kept the same key and everything works fine now.
    PS.so far anyway
    Thanks
  • sandeep shrivastava Jun 04, 2008
    i had similat problem this solution solved the issue
  • milesloretta Jan 02, 2009
    I have the same issue with XP machine. I set up a new router with the same network name and its giving me the same warnings and won't let me re-enter the network password. It thinks its still connected and yet the network is new. Is there a way to completely remove the network information?
  • 59 Answers
It is just that the network key which is stored in the computer is not working so the 1st thing u need to do is verify the network key for that go to 192.168.0.1 from internet explorer enter the user id & password of ur dlink ( default id: admin password : admin) the go to wireless check the WEP or security key which is present their. reenter that key the computer & try to connect.
If it didn't work then go to control panel >> system >> hardware>> device manager
look for the network adepter & unintall the wireless network card
restart the computer
once restart it will automatically reintall the wireless card driver
then go to control panel>>Network Connection
right click on wireless network connection
select view wireless network connect
select ur network name & connect it will ask for the key provide the key & once u do that it will get connected & work fine
if in case u have the same problem replay back & i help u out with it & also provide all the details like which windows & network card etc
Posted on May 25, 2008
I had experience same problem before and what i did was reset the router by pressing the reset button for at least ten seconds to restore default setting and after doing that it solved my problem.
I hope this may help you..Have a nice day
Posted on Jan 04, 2009
I Have a D-link DI-524 wireless router and verizon Broadband modem w/USB conection the G router only has ethernet connections .How can I make this Combo work?
If your Broadband modem is only with w/USB connection you have to change modem/router, you won't connect it with usb to di-524.
Jul 05, 2009 | D-Link AirPlus DI-524 Wireless Router
I have a d link di-524 wont work with comcast
how is your comcast connected to di-524?
make sure you have wireless enabled in router config.
type in to your web browser 192.168.0.1
login should be admin
password leave blank unless you have set one
then go to wireless section and check if it's enabled etc.
Jul 01, 2009 | D-Link AirPlus DI-524 Wireless Router
I cannot connect to my router via the IP in the browser
Check first the cables and connections, and the broadband filter.
You need to connect through cable to configure the router.
To access the router panel you need to input the router IP address on Internet explorer bar.
default IP is http://192.168.0.1
If IP is not default, you find out IP by opening the command prompt from start menu>>all programs>>accessories>>system tools (that kind of dos mode). On command prompt type ipconfig/all.
The default gateway is router IP.
On the router access panel default settings are :
User Admin
Password leave blank
See all procedures on manual below.
Copy and paste the address below on your browser address bar.
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
Dec 08, 2008 | D-Link AirPlus DI-524 Wireless Router
DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Nov 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Oct 31, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
D link router 534up and samsung usb printer
I'm confused, you said usb printer and this is a router question. Your computer should recognize the printer if you hooked it up. What OS are you using?
Sep 14, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
D-link di 524
You can find all the information on routers on the web link given below.
http://support.dlink.com/supportfaq/
I hope this should help you will the router information and troubleshooting on your own.
Have a great day.
Feb 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Aug 17, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
8,931 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
