Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp mx5001n...what is error code c4-02 and is
Sharp mx5001n...what is error code c4-02 and is there a reset code
  • 2 more comments
  • aqueen191 Sep 30, 2010
    is there a reset code to try?
    what is ptc?
    can it be disabled temporarily to continue copying?
    what is the ptc..what does it stand for
  • aqueen191 Oct 01, 2010
    thanks for the info, maybe my machine is a little different, but I was able to bypass it. The message still pops up, but now I can say ok and continue to use the copier/scanner/fax machine. My rep has ordered the parts to fix it.
  • 857 Answers
This is the problem with the PTC unit,
in order to get this problem fixed you need to get the ptc unit replaced.
To do the same you will have to call sharp.
Posted on Sep 30, 2010
  • 3 more comments
  • Jayant Jha Sep 30, 2010
    There is no reset code as such,
    This is a prolem with the PTC unit, event resetting the ptc unit may not solve the problem thats why replacement of ptc unit is nedded.
    No it is not possible to disable it as it is a hardware component.
    It is Printer terminal control.
  • Jayant Jha Oct 05, 2010
    Thats good to hear, hope everything will be fine.
  • Joel Twilley Dec 11, 2013
    The code C4-02 refers to the Primary Transfer Cleaner (PTC). A technician will have to check it out. The one time I saw that code, I merely had to reseat the unit.
Mx-5000n error code f2
Hi Saman,
Usually there are other numbers after the F2 part of the code. If you let me know the full number I can tell you what is wrong. However the family of F2 codes indicate a wide variety of sensors usually in relation to the process of making color copies.
You should call on your local dealer for service.
Apr 15, 2016 | Sharp MX5001N copier w/ 36 Month Warranty
How to remove a Sharp MX-FR11U Data Security Kit from a Sharp MX5001N?
The data security kit is designed to be permanent. The only way to remove it would be to replace the data security kit ROMs with the stock ROMs and then flash the firmware back to stock.
It would be a process that your servicing dealer could probably handle.
Why do you need to remove it?
Jun 29, 2014 | Sharp MX5001N copier w/ 36 Month Warranty
Blank streaks on color copies
You need a calibration most likely. You can try to clean the internals with the wands on the inside of the front cover.
Check out my video explaining how to do this:
How To Remove Lines from copies prints on Sharp copier
Apr 17, 2013 | Sharp MX5001N copier w/ 36 Month Warranty
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Jun 19, 2009 | Sharp AR-5320 Black and White Copier
Needs simulations steps on how to reset a E8-000 code
Hello sir; This error code have no way to reset, the ptoblem is icu or pcu main board .
Apr 27, 2009 | Sharp AR-C150 Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
May 22, 2008 | Sharp AR-M237 Digital Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
3,478 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
