Question about OEM Systems Car Audio & Video
1992 Lincoln towncar 10-disc cd changer in trunk seems to work however there is no volume the display on the radio displays disc 1... then disc 2 ... ect. but it doesn't play anything????? please any advise would be great, the radio works fine thank you
Eagleeyes
  • 199 Answers
SOURCE: Clarion CDC1235 CD Changer
hi Its Error 6 no focus. could be dirty cds. dirty laser. or faulty laser. regards Mark www.carradiospares.co.uk
Posted on May 03, 2007
SOURCE: Kenwood Cd Changer KDC-C467
clean cd laser lens with distiled water
Posted on Aug 24, 2007
SOURCE: Jeep 10 disc changer; now only error message on dash.
I had this same problem on my 2000 Jeep GC Limited. Today I decided to open it up after looking all over the net and found no help, but spend $500.00 on a new unit. I removed the unit and used canned air inside all the areas I could. I hooked it back up and was finally able to make the CD cleaner disc work. Once that was done I loaded it with 10 cd's and it is working again. I'm so happy! I saved my hubby 500 big ones.
Posted on Sep 10, 2008
SOURCE: Clarion 6 Cd Changer 1999 Ford Expedition OEM - NO CD DJ on display
plays and changes song fine just no sound
Posted on Jun 12, 2009
SOURCE: 2005 GMC Yukon Denali Bose CD inop
04 yukon denali bose system c.d. are stuck nhon will play gives me code E.Q.-4
Posted on Sep 03, 2009
Becker radio displays WAIT
to get it working again when the "WAIT" comes on it may take 10/15 minutes before the "WAIT" to go off and then i turned the volume control to the first code number, then push am/fm button to lock it in. repeat until all the code numbers are in and the radio will start normal operation. There is a code number card that comes with the radio, if you do not have it, go to the mb dealer with your vin number and they will give you the code number.
Jul 22, 2014 | OEM 1993 Mercedes 300D Radio / CD Player...
I HAVE A 5 CD CARTRIDGE IN TRUNK, IT DISPLAYS NO CD, IS THE CARTRIDGE OR SHOULD I GET ANOTHER CD PLAYER FOR THE TRUNK?
check all of your connections going into it may be corroded at electrical connections or the cd may need replaced
Aug 09, 2012 | 2001 Lincoln Town Car
I get E-01 error of my cd changer
The fault is actually inside the CD changer, when one disc is selected the changer moves the gearing inside to slot from one CD to the other.
While this operation is happening the selection arm jams !!
Then giving an error at the radio display..
To fix the problem, disconnect the CD changer from the trunk of the car,
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again,
grease the moving parts with light lubricant
Good Luck
Feb 24, 2011 | Mercedes-Benz C-Class Cars & Trucks
Where can I find a replacement cartridge for the in-trunk 10-disc CD changer for my '97 Lincoln Town Car - Cartier model?
this people still have the 10 disc cd changers and also other units that you can use in that vehicle
www.oemautosound.com
Nov 20, 2010 | 1997 Lincoln Town Car
1999 Ford SE digital display reads ''NO CD'' and changer is stuck
Magazine-type CD changers are prone to jamming with a disc in transit between the magazine and the player. You may have to resort to disassembling the trunk unit to get access to the jam.
Apr 15, 2017 | 1999 Ford Taurus
I just bought a car and when i popped open the trunk there was a 12 disk jvc cd changer, its all hooked up i just don't know if it works because there is no remote and the changer won't open.
Look for a cable from the disc changer that heads towards the front of the car. Generally if you pull one of the kick rails beside the seats you will find the wire. It will be grayish black and almost the size of a USB cable 10 to 12 gauge. Follow it under the dash, if your lucky you will find a silver box which is the fm converter then a small LCD display about 1 1/4" tall and 2 1/2" long. That's the Receiver/Display. Then you need the remote, if you don't have one, go to any car audio shop & let them know what you've got and they can get you what you need and make sure the unit is ok. Hope this helps
Jun 23, 2009 | JVC CH-X1500RF 12-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Car Audio & Video Logo
122 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
