Question about iRiver iFP-995 MP3 Player
I need ifp995 usb driver. because install was failed.
Why did smart card interface failed to install?
ur smart card has no problem, problem have with ur system's USB Drivers , reinstall or update ur system's usb driver ur smart card will easily connect
May 12, 2014 | Sunpak USB 2.0 72-in-1 Card Reader
Dwa 140
Next, open device manager (Click Start Menu and type in "Device Manager", right click and run as administrator). Then find your device in the list, and uninstall it. Immediately, unplug the wireless USB from the computer. Now, restart your computer with the USB unplugged. Insert your driver disk and install the driver, when prompted plug the wireless USB back into the computer. Hope this helps.
Jul 01, 2013 | Computers & Internet
When installing the USB2106S Ethernet Adaptor I get the error "Failed to copy files to MosUmac folder" The installation then fails.
Hi Chris,
I see that you are having problem installing the driver for your USB Ethernet adapter. You can try to download the driver using another computer in the link that is posted below. Save it on a thumb driver and double click on the application. You might wanna make sure that you have an extractor for compressed files (rar) like winrar. If you don't, you might want to include downloading Winrar in the thumb drive as well and install it in your computer.
USB Ethernet Driver
Winrar
Jul 07, 2011 | StarTech.com USB2106S USB Network Adapter
My printer won't print due to the fact that the troubleshoot says I'm not connected to a computer....but I am. How do I download a new driver to make it work. thanx
Hello Sir, Hi, that is common error with printers today, but this error can be fixed, here are some of the thing you need to do, they may help.
for usb interface. 1. If you are using a USB interface, you need to install first the driver software, along the setup, you will be prompted to power on the printer and plug in the USB cable to your computer and the printer. make your connection here. If the connection fails, do this several times. 2. If the 1. fails try using another USB port.
for centronics parallel printer cable. 1. Make the connection of the printer to the computer before installing the driver software. 2. Power on the printer. 3. Power on the computer and install the driver CD.
If you do not have the driver cd and you did not mention what printer you have. do a Google search, type the printer make and model and search for the driver. download the driver, usually from the manufacturer's website.
Oct 17, 2010 | Computers & Internet
Where can i download driver for hp v165w USB flash
The USB driver installed by default. U need not have to install it separately. If it is not recognised then try to use it on another system, see whether it gets connected or not
Apr 19, 2010 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
The usb driver installation fails on my system. I
have u installed the latest service packs
if not then download and install them from the microsoft website
if still after this problem persists
make sure your device is plugged in correctly and try to use another usb port
still problem persists
>> probem is with your device not the computer or os
Jul 11, 2009 | Samsung Pleomax PKB-7000X
Connexant Modem, Sigmatel Sound and USB fail to work or install
I had the same problem with a dell m1330. Dell did not provide the xp drivers. I used various programs to identify hardware and then try to hunt them down on the internet. I finally gave up and bought driver scanner from uniblue for $30. Solved all my problems. It also sounds like your chipset driver maybe the wrong one. Also you can download "PCWizard" it will tell you the details you need to know to find the correct drivers.
May 27, 2009 | Dell Inspiron 1150 Notebook
The Realtek EAPPkt Protocol Service failed to start
Try this..1.Try to uninstall the USB adapter and re install it again. To do this go to Add/Remove Programs under Control Panel and find the usb adapter your install in this case its Alfa Wireless USB Adapter and uninstall it and restart your computer after uninstallation. 2. Remove the USB adapter while restarting and insert it again until windows already loaded and all windows startup program have all been started.
3. System will look for the system driver of USB adapter and it will prompt you for the driver location in this window do not choose the recomended instead click browse and locate the driver cd and look for driver folder and select the applicable driver for your operating system such as WinXP if your using XP.
4. If there is no driver folder in cd, go to my computer, explore cd and run setup or install this will install the pending driver installation.
Nov 19, 2008 | Computers & Internet
Failed to install
Belkin drivers are a bit of a pain, uninstall the drivers again and remove the usb adapter, and follow exactly as per instructions, normally driver first, but ignore the pop up about the driver not being a signed windows if it does, just click install anyway. toward the end of the installation you should be prompted to connect the usb adapter, the hardware should be found and then the installation should complete. If driver installed ok but the adapter cant find the the driver plug it into a different usb port and again the found hardware should pop up then install driver popup should show and you should select install automatically.
Sep 10, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
iRiver iFP-995 MP3 Player Logo
44 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
