Question about Foxconn 6627MA-RS2H Motherboard
Need to find the right memory ram to upgrade to 1gig as i only have 256 stick in it.i need to know the right specs and module number
  • 3,247 Answers
The details of your motherboard are available from this site.
Download the manual from the site to check how to upgrade the memory. You can go upto 2GB with DDRII memory.
Hope this helps. Please rate this solution to enable fixya to serve you better in future.
Posted on Sep 30, 2010
  • 6,487 Answers
Since you're planning to upgrade the RAM of your computer here are the 3 different type of RAM that you can use for this motherboard.
400MHz(PC2-3200)
533MHz(PC2-4200)
667MHz(PC2-5300)
I have this ASUS P4GE-MX Motherboard. I want to upgrade my ram from DDR 256 MB TO DDR 1 GB. For temporary purpose, I tried another 256 DDR ram with 400 MHZ, but I had some problem with booting my system....
Hello, The Motherboard's specifications mention that it uses DDR Ram, while the FSB runs at 400MHz. That means that any kind of DDR memory will work up to the maximum of 2 GB (it has 2 slots, so it's up to the max of 2x1GB DDR sticks).
There's no issue with the speed, actually the faster you can get the better results you will have. Try looking for 1GB DDR 400MHz (preferably two of them, if you want to max out the capacity and since it's kind of cheap to do so).
The one you tried and didn't work, might be due to a faulty RAM module.
Mar 13, 2011 | ASUS P4GE-MX Motherboard
Cannot upgrade memory on my Gateway MX3215
Use Corsair Value Select VS1GSDS533D2.
Aug 17, 2009 | Gateway MX3215 Notebook
I want to upgrade my RAM on my eMachine t3504. I currently have 256 in each of my 2 slots. Can I upgrade one of the slots to 1 GB and leave the 2nd at 256 or do I have to upgrade both slots?
Yes you can upgrade 1 of the slots to 1GB, as long as 1GB stick of memory is the 256MB stick then you can have both, to check the memory you will have pull them out of the slots and have a look on a little sticker on one side of them. You are looking for i.e DDR400/333/266 if the 1GIG memory matches one of the values mentioned above, say it is a DDR400 and the 256 is a DDR400 then they are compatable if not you will have to just leave the 1GIG stick in by it self in DIMM socket 1.
Apr 03, 2010 | E-Machines T3504 PC Desktop
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
Dell dimension 4550
Dell has a habit of using proprietary memory in their machines, if it isn't proprietary you can near guarantee that cheaper memory sticks will not be recognised.
Play safe and use the memory configurators at crucial.com and newegg.com
I bought two DDR2 1gig sticks at crucial yesterday for $50.00 for both with free shipping.
Jul 24, 2008 | Kingston 1GB PC2700 DDR DIMM Memory
Compaq Presario M2000 PC Notebook
The Bios on the laptop motherboard only will recognize a total of 1gig Ram. So the 256 stick would be removed and 2- 512 sticks installed.
May 22, 2008 | Compaq Presario M2000 Notebook
Memory upgrade
The memory should be DDR II Ram. To find how much ram you have simply click on Start then right click on "My Computer" and click properties. Chances are you have 512 ram. It will tell you in the lower right hand side along with your processer and windows version. Once you have found out how much ram you have, turn off your computer flip it upside down and pull out the battery. Then you should see a cover with one or two screws in it that measures about 3 inch by 4 inch. Remove the screws and take the cover off. This is where your memory goes. If there is 512 memory in your computer you will either have 1 512 memory stick or 2 256 sitcks. Remember that any time you upgrade memory it is best to take out the old memory and replace with either one stick of higher ram or two of equal ram. Never mis a 512 and a 256 or 512 and 1gig ect. Take the ram stick/sticks out and bring them down to the store with you just so as to get the correct memory. Also, remember when you replace the memory, if you are just upgrading to one 1gig stick to put it in the A DIMM slot. This is the primary ram slot.
Apr 29, 2008 | HP Pavilion dv6000z Notebook
Dell dimension 3000 memory card
if your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
Memory upgrade problems
Hmm if the pc takes DDR Ram , it should deffently take 512 sticks, have u tried booting the computer with just the one 512 stick ? or try putting the 256 stick in and 1 x 512 stick , test it that way with both sticks , some older computers there is a bios setting for upgrading to higher amount of memory, but in your case with DDR ram i dont think so , i mean it may be worth a shot going into bio's and load optimized defaults , press f10 to save settings, try one stick at a time after that , if still no go , there is a jumper pin on the mother board that u can move over a slot which will restet the bios, if u dont know this jumper pin or where it is, just remove the round battery on the motherboard for 30 seconds , then put it back in , try your new ram then , u will be asked to save settings on boot up , if it still dosent work the ram is either faulty or incompatible, alot of the time with Dell , HP /Compaq desktops there fussy with the type of ram they take, but if u ordered from dell it should have worked !! whats the brand name of the ram u have is it hynix? /HP this brand of ram has alot of issues with compatibility,
Nov 21, 2007 | Dell Dimension 2350 PC Desktop
Foxconn 6627MA-RS2H Motherboard Logo
63 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
