Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
I need to change the page count after replacing the formatter on an HP M1522nf MFP. I used a PJL file to change the serial number but that didn't work for the page count.
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
SOURCE: download driver for Window 7 the HP Laser Jet M1522nf MFP
go to folowing link you will get drivers for windows7
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3442754&lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&taskId=135
Posted on May 04, 2010
  • 223 Answers
SOURCE: hp laserjet m1522nf mfp, when printing multiple
This is a problem with either the formatter board or the dc controller, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
Posted on Sep 30, 2010
puertobori
  • 7733 Answers
SOURCE: Can I print out a
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
Posted on Nov 11, 2010
seeker5211
  • 1089 Answers
SOURCE: I get a page that has this on it everytime I print
Delete the printer drivers and go to hp.com and download the PCL5 drivers.
Posted on Jan 04, 2011
Hp p3005x - how to replace formatter board
This is a known issue that cannot be addressed through menus. What you need is a PJL (print job language) file that programs the formatter activate the duplex function. Does your configuration page show the correct serial number and page counts? If not then likely the formatter you purchased was used. If you provide serial number, page count I can provide you with the correct PJL file that will restore your duplex function.
Sep 16, 2014 | HP LaserJet P3005x Printer
Tip
What is a Scanner Error 5 Hewlett Packard M1522nf
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M1522
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
Contact Hewlett Packard for possible Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
Parts Required as follows:
Formatter CC396-60001 M1522N Printer
Formatter CC368-60001 M1522NF Printer
Scanner/Flatbed CB534-67903
on Feb 04, 2011 | HEWLETT-PACKARD Hewlett Packard 53A...
HP laserjet M1522nf initializing
continue initialising please replace the formatter card
Jan 21, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
HP Laserjet M1522NF MFP Scanner adf
Please try to use scanner glass and see the resultSecondly try to scaan to PDF for multiple files.If the issue still persists clean the rollers on the ADF and if not working, replace the ADF
Apr 20, 2012 | HP LaserJet M1522nf Multifunction Printer...
Need to reset the page count after changing out the formatter board.
The page counts and serial number on these units cannot be adjusted or overwritten. You are stuck with the zero count if you installed a new formatter, or the page count on the formatter if you installed a used one. Just put a label on the back that says, formatter changed at XXXXX pages.
May 31, 2011 | HP Laserjet M2727nf Multifunction Printer
Hp laserjet m1522nf mfp, when printing multiple pages, may print one page fine and the next page full of garbage, and then fine again. Have uninstalled the software and reinstalled it with no difference. ...
Al
Sep 17, 2010 | HP LaserJet M1522nf Multifunction Printer...
When i start my printer hp m1522nf mfp printer ,its shown me the erorr your firmware is curropt
Turn the printer off, hook up the USB cable and try making a firmware update, you can find the file for making the firmware update from support and drivers section under www.hp.com, finally turn the printer back on
If this does not fix the problem means that the formatter board is damaged, call 1800 334 51 44 (hp tech support)
Mar 04, 2010 | HP LaserJet M1522nf Multifunction Printer...
Laserjet 2727
Why would you offer a smart *** comment to a potentially legitimate question? I have the same issue after replaceing the formatter board, the printer is reporting SN12345678 as the serial number.
Feb 08, 2010 | HP Office Equipment & Supplies
How to change the serial number in hp laserjet 3055n after replace the foprmatter board.
I dont have the answer; however the closest I could find in teh 3055 service guide was the following statement:
"Printer job language (PJL) software commands Many PJL scripts are available for restoring parameters such as paper size and page counts after the formatter has been replaced. For comprehensive instructions, see the Printer Job Language Technical Manual and the Printer Job Language Technical Manual Addendum"
I do not have those two manuals but it would seem that is the direction you need to head in order to solve this issue. Many of the HP laserjet's have an easier method than using PJL commands, however this model does not provide such ease of use.
Aug 29, 2009 | HP LaserJet 3055 All-In-One Printer
I'm wondering where the serial numbers for an HP 4350 are located
Source: => http://crackmonkey.org/pipermail/printers/2005-October/000026.html
Hewlett Packard printers can have their serial numbers reprogrammed in the field, from the front panel of the printer, with very little special knowledge and no special tools. Any electronic page showing its serial number afterward would be divergent from the actual serial number for the machine. It can be changed back again, too - an unlimited number of times.
Yeah, I know - you'll never trust the page count on a used printer again, but there you have it.
This is only true on some of the newer models, and on the larger ones - not the smaller machines like the 1200, but the larger ones like the 5Si, the 4500, etc.
Canon builds the print engines (basic mechanical arrangements of components) for Hewlett Packard, which only really engineers the firmware - which could be used to implement the hidden codes you're investigating. But I would not be surprised if Canon and HP codes look the same and are implemented at a level common to both brands of machine. It is odd to me that you did not publish any pictures of the test prints from the manufacturer which dominates the industry, though...
Since you can alter the serial number (at will) on an HP machine, that could make your decoding task that much easier, if you have access to one. Set to all 1's, all 2's, etc. and compare test prints.
On the other hand, it also makes the entire schema a joke, since I could program my printer to say it is your printer (copy your serial number), print up some phoneybux, and then set it back to innocent_serial and whistle while I watch your office get raided.
The serial number information is soft-coded to allow the formatter board to be replaced if it fails, while still supporting the configuration page's reportage of that printer's vital stats. You can even load the new formatter with the page count from the old formatter, so that the mechanical parts can be maintained on schedule as they wear out.
Now, this is not true of the Formatter Number, which is the serial number of the formatter card itself. If that is the basis of HP's system of Identity, then the workaround would involve a physical removal of the formatter and its (temporary) replacement with another formatter. For someone engaged in producing phoneybux, this is not an economic hardship.
Dec 13, 2008 | HP LaserJet 4350 Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
408 people viewed this question
Seeker5211
Seeker5211
