Question about Sony VAIO VGN-UX280P Notebook
Hi, I have a VGN UX280P and tried to install windows xp from scratch and does not boot from the CD or from USB I've configured the bios and nothing
    Scholar:
  • 78 Answers
You will have to go into the bios and change the device boot order if you haven't done this already. Google ( how to change boot order )
if you don't know how and you will find many tutorials.
Good luck and please rate if this was helpful.
Posted on Sep 30, 2010
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
How to Fix NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
    Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
    Try replacing the IDE cable cable if you suspect it might be faulty.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will
Jan 22, 2014 | Belkin Basic Wireless Router
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
  12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
How to install new windows in sony vaio laptop vgn-ux280p it has not having dvd writer i have tried from the usb but it is nor booting pls suggest
If you have enough room on your drives, copy the Windows disc complete to the hard drive and run setup from the hard drive.
Jan 18, 2011 | Sony VAIO VGN-UX280P Notebook
I have toshiba dyna notebook ss 2000m. My windows xp corupted by a virus. all .dll files became .exe files. now i want to install a fresh copy of win-xp. but when i can't be able to boot from a usb...
There are two possible reasons why, First, maybe the legacy onboard usb is not enable from the BIOS. I believe that you know how to check it, just look for the legacy USB or legacy onboard.
Second, it is possible that your windows XP disc is not a bottable version, meaning the disc will be read as a data cd only and not an installer.
But try to check for the first, that is closer to resolve your problem.
-Theory of a Bum-
Oct 19, 2010 | Computers & Internet
I have a sony vaio vgn ux280p that i bought at a sale and i cant get it to restore to factory specs ive tried alt+f 10, f 11,f 8 and nothing works,what can i do?
Try letting it boot, and look for restore from your start menu. Some makers put it there, others, when you try to access the D:\ drive, it invokes program to ask the user questions on restore....
Do be aware that you need Windows and all other programs' access codes, after a reload. Another option is to create a new user, give that user admininstrator rights, and delete any unneeded users. Also on the boot up, watch the screen carefully, each system tells you how to access the bios, did you try delete? All of the keys you mentioned, try without alt, not sure that works at that boot stage.
Oct 17, 2010 | Sony VAIO VGN-UX280P Notebook
HOW TO ENTER CMOS SETUP OR BIOS SETUP OF SONY VGN-FW290E OR HOW TO INSTALL WIN XP IN THIS NOTEBOOK
To enter the CMOS setup BIOS you hit f2 during the power on. After you enter the bios to the boot up screen and select first boot up = CD ROM. Save the configuration and reboot. Now pop in your windows XP cd into the CDROM, your computer will bootup from the CDROM. You can now reinstall windows.
Dec 11, 2009 | Sony VAIO VGN-FW290JTB Notebook PC
Will try to make a long story short...Attempting to install Windows XP Prof. on a friend's IBM NetVista 6645 Model W2U which he purchased from someplace. It already has XP Prof. installed, but my friend...
Can you get into the BIOS configuration to enable the CD and USB drive?
If so enable these devices.
Check the interior of the desktop to see if the CD drive and USB connectors are still connected.
Nov 02, 2009 | IBM NetVista PC Desktop
When try to install winows xp on dell optiplex 270gx i choose the CD but nothing appears on the screen, is there any bios setup needed or any configuration needed befor installing windows xp
Hi..
before install it the OS, you need to check if the system's booting priority is set to boot from C-ROM,
They you can Install the OS
Mar 23, 2009 | Dell Computers & Internet
NTLDR is missing
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
The notebook can not enter windows
You probably have a problem with your operating system and will need to install windows again. You need to find the Windows XP installing CD that came with your laptop and also the drivers CD.
If you have found it, put the XP CD in and restart the computer and when the message says "Press any key to boot from CD" appears, press a key.
Then follow instructions to install Operating system.
If you format your Hard drive, all your data will be deleted so it might be good to backup your data by removing the Hard drive and buy a 2.5" HDD reader and get all the data off before you format or reinstall windows
Oct 08, 2008 | Sony VAIO VGN-UX280P Notebook
Sony VAIO VGN-UX280P Notebook Logo
360 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
