Question about NewAir ACP-1000E Portable Air Conditioner
The air conditioner is blowing hot air, there is no water to drain
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
If it is also blowing cold air out of the other vents you need to vent the hot air its blowing outside
Posted on Sep 30, 2010
2 Suggested Answers
  • 659 Answers
SOURCE: wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Posted on Apr 01, 2009
PTAC UNIT BLOWING HOT AIR IN COOLING MODE
Hot or warm? Sound like float switch shuts compressor off. Vacuum the drain and clean the pan
Aug 24, 2016 | Heating & Cooling
A SMALL AMOUNT OF WATER IS FOUND UNDER THE INSIDE UNIT ON WINDOW LEDGE. WE TURNED THE UNIT ON. iT WAS A HUMID DAY AND 2-3 HOURS LATER WE SAW ABOUT 1 TEASPOON ON WATER ON LEDGE. THE WATER WAS CONCENTRATED...
check the filter first and then check the drain line to the outside . If you can blow some air up against the hose to the isdie don't balst it just blow it and it will clear it . If you can access it from indoors clean it out and run some hot wather and soap inot the pan and down the drain hose.. shuld clean it up Let me know will ya hope this Helps.. Jon
Jul 25, 2011 | LG Art Cool LA181CNW Split System Air...
My window a/c is blowing hot air what do i do
It should have a tiny rubber hose that you drain Water from the unit into a bucket
Jun 29, 2011 | Whirlwind FH-778 Air Conditioner
01 dodge 2500 v8. Air conditioner started out strong, blowing cold air..temporarily would start blowing warm and then back to ice cold...Noticed when stopping and turning corners a hissing noise coming...
Hi. Have your car aircon evaporator cleaned. Check also the drain hose. All water should go out of the car through the drain hose. There might be something clogging up the hose that is why water will run out the floor and that causes also the aircon to work intermittently.
Have a good one!
Aug 13, 2010 | 2001 Dodge Ram 2500 Truck
Blows hot air
If your machine is an air conditioner then the little hose needs to drain condensation to the outdoors. Most of the time there is a pump that the hose is attached to inside the unit. If the overflow switch is open the compressor contactor will not operate but the fan will.
Jun 19, 2010 | Maytag M6P09S2ACOM Air Conditioner
Goldstar 10000 blows water out front
Two possible problems.
1. High humidity in the space being cooled
2. Drain line that runs from the front (where the water is blowing out) to the back where it is sent to evaporate. Clean out the drain line and condensate pan under the fins where the water is blowing out.
Jul 10, 2009 | LG Goldstar GWHD5000 wall/window Air...
Everstar mpm1-10cr-bb6 blowing luke warm air-no water to drain
It shouldn't harm it but give the unit a good cleaning.
May 03, 2009 | Danby DPAC8020 Air Conditioner
Wont no water to empty or drain
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Problems with my bonaire evap
air con keeps shuting down takes about an hour before its cranks back up.
Nov 11, 2007 | Heating & Cooling
Blowing hot air
Water in the pan is normal, this is the humidity removed from your space. Pan must be emptied regularly. If the unit shuts down after 15 minutes, you may have a blocked hot air duct. Make sure it is flowing freely. This includes makeup air from outside the room to replace that blown outside by the AC.
Jun 24, 2007 | Sunpentown (EHW10268) Air Conditioner
NewAir ACP-1000E Portable Air Conditioner Logo
316 people viewed this question
Top NewAir Heating & Cooling Experts
gbob59
Tom Chichester
Bill Boyd
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
