Question about LG 47LG50 47 in. LCD HDTV
No volume on television - LG 47LG50 47 in. LCD HDTV
Can not turn volume up. working but at 100% very hard to hear
Hi Janet, Is you television hooked up to a set top box like foxtel? and if so does it have a volume control as well as your television, I have foxtel with volume control as well as the television volume control.... What I do is have the television volume turned up full and control the volume through my foxtel.... Hope this helps... CHEERS...
Mar 22, 2016 | Televison & Video
Is there a way to set the volume so i dont have to keep changing them all the time
hello, are you referring to the volume of the TV set when you change channels? to reiterate every time you change channels the volume also changes? in this case I do not want to speak too much but I'm almost certain that television providers are required to adhere to a volume leveling standard which would require television broadcast stations to broadcast at a certain volume level for unity. Are you watching cable television? I happen to know that not all cable television providers level they're broadcasting some do.I notice that you are using a CRT unit are you attempting to use a converter box with the unit? If you are using a converter box there may be a chance that volume level is one of the options in the menu, I can not say there is much at all you can do about this.
As an alternative your television set maybe damage and the volume maybe adjusting randomly or in a way other than intended.
Good luck and thanks
Questions? Just ask!
Nov 25, 2015 | Televison & Video
Television volume down button sticks.
spray windex or 409 on the button n press it as you spray it n around the button. Loosen the grime in and around the button.
Sep 24, 2012 | Magnavox 32MF369BF7 32 in. LCD TV
Mitsubishi WS-65511 volume control has gone crazy. All of a sudden volume went to full blast and now with manually pressing volume button it is either full volume or lowest volume. We have DISH and...
Mitsubishi WS-65511 volume control went crazy after a storm. Now we don't having any volume. None of the controls are working on the front of the panel with the exception of the device control.
Jun 02, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Volume too loud
Very likely the volume setting on your cable is set too high. The cable volume is separate from the TV volume. Once you lower the cable volume, then you can adjust your TV volume to find a happy medium that gives you more range between numbers. Have you already tried this?
Apr 18, 2009 | Sceptre X42GV-Naga 42 in. LCD Television
Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Apr 11, 2009 | iLO 3200 32 in. LCD Television
Tv volume
try to put it on menu and check if the volume has set up to the higher volume.i think somebody touch yhe settings of your television.
Oct 23, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Volume
confirm that volume contro plus (+) button does not stuck inside.
try to apply good contact cleaner in volme button and press it many times until it released.
Mar 08, 2008 | Akai CF2791 27" TV
Volume button
check volume control circuit and change the volume control ic or transistor.
Dec 18, 2007 | Panasonic CT-32SL14 32" TV
Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Nov 09, 2006 | Toshiba 55H70 55" Rear Projection...
LG 47LG50 47 in. LCD HDTV Logo
49 people viewed this question
Computer Repairing
Computer Repairing
