Question about Car Audio & Video
I have got no power on my amp yet all cables connected properly, checked checked n checked again, and still no power its a 2001 ford focus with a pioneer head unit with american legacy la890 amp and 1000w jbl sub. Any help with this would be greatly appreciated Thanks Gareth
  • Rommel Cana
    Rommel Cana Sep 30, 2010
    have it disconnected , check components like MOSFET on the power supply
    check for possible shorted power transistors on the Main amp
    check for preamp supply rails
    New Friend:
    Problem Solver:
  • 15 Answers
If u checked all ur fuses and u have a good ground(paint removed solid connection) u could have a problem inside ur amp. Have a local repair technician check it out
Posted on May 31, 2014
    Problem Solver:
  • 8 Answers
Check all your fuses and make sure your ground wire is properly grounded you can put it right on the neg side of your battery to test.
Posted on Sep 30, 2010
When stopped gears sometime grind when shifting into 1st gear(2001 Ford Focus)
Then the clutch is not releasing properly & the continual
grinding will wear the gear teeth & you may also have worn
syncros, that will require you to pull the trans & go thru it, as well
as do a clutch replacement
Mar 09, 2014 | 2001 Ford Focus
On 2001 Crown Vic, radio lights are on, channels change,etc but no audio. Fuse issue or any other possibilities?
sounds like your speakers aren't connected properly. check your speaker leads coming from your radio and make sure they are positive to positive and negative to negative. if you're using an external amplifier,check your RCA cables and your speaker outputs on the amp. make sure thr remote turn on lead is connected, otherwise the amp won't even power on.
hope that helped, good luck
May 31, 2012 | 2001 Ford Crown Victoria
My 2000 ford focus will not start. It does not make any noise but the lights go on. It doesn't even turn over. My mechanic disconnected the remote car starter and that seemed to help but now I'm...
If it's not a dead battery, it could have bad connections. Check battery connections for tightness
Check the battery cable connection on the start solenoid, usually very near the battery. Check all wires on the sloenoid.
Check solenoid cable to starter for tightness at both ends.
If starter & battere are good it has to be one of above'
Good Luck
Jun 30, 2011 | 2004 Ford Focus
I have accidentally locked the sterio of my Ford Focus 2001 Car while inserting a pin code. How do I unlock the sterio so that I can insert the correct pin code
disconnect + battery cable for 5 minutes and re-connect. that should reset the system completly so you can start all over again
Jan 13, 2011 | 2001 Ford Focus
I have a ford focus 2001,when the headlights or any of the other lights are on they will flicker , ihave changed the alternator but thats made no differance
You probably have a loose or corroded connection somewhere. Clean the battery cables thoroughly, check for a loose connection where the negative cable bolts to the engine, and any other ground cables you can see.
Feb 21, 2010 | 2001 Ford Focus
2001 Ford Focus - radio turns on and off. Power
You either have a loose power connection, or have upgraded your stereo speakers and have not grounded them properly or they are drawing too much power and may need an amplifier
Jul 07, 2009 | 2001 Ford Focus
Speedometer Stops
Most cars Speedometer cable connect to one of the front wheels, but you said your speedometer sometimes stop then your steering wheel will go stiff, I think you should fix or change your speedometer cable, maybe the cable broken inside. Fix it as soon as possible for your safety.
Speedometer cable has two parts, one is outside cable, mounted and connect to both speedometer and wheel.
The other one is an inside steel cable, outside cable protects the inside cable, because the inside cable turns as soon as you move the car. It is directly connect to the wheel gears and the speedometer inside.
If your car has speedometer cable, I think you need check it right away.
Your steering wheel sometimes stiff, you also need to check your power steering fluid level, sometimes cause this kind problem.
Hope this can help you and if you have more questions, please use whatever the Fixya allowed, contact me to discuss this matter and others. Thank you.
Jun 24, 2008 | 2001 Ford Focus
Car Audio & Video Logo
136 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
