Question about Whirlpool Duet GHW9150P Front Load Washer
Drain problem f21 f02
Need to check the drain filter, but do not know where it is?
  • 21 Answers
you might follow your drain line back to your machine. Carefully remove panels, and peer in. sometimes going as far back to the pump itself will help. Clear out all debris in the pump hoses, and see if this helps.
Posted on May 26, 2008
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
I keep getting error code F21 on my kenmore elite which is a drain error the drain is not clogged and the drain hose is not clogged any ideas on what I could do?
The error code F21 is similar to F02 which both pertains to a draining problem. The usual cause is a blocked drain filter or a clogged/kinked. But since those areas are found to be not the source of the problem, the problem must be somewhere else. It is either the drain pump is broken particularly the impeller if the pump just hums/whirs or the pressure switch contacts are stuck/welded together and is, therefore, not tripping. The link below provides the detailed troubleshooting instructions the problem of this kind after the drain filter has been cleaned out.
Error Code F02/F21 on Whirlpool Duet and Kenmore Elite Front Load Washers (Filter Cleaned)
Aug 21, 2011 | Kenmore Washing Machines
What's F-21
This error code F21 signifies a drain problem and usually caused by a blocked drain filter. Check to make sure that the drain hose is free from obstructions then remove the three screws securing the bottom front panel to the cabinet then pull the panel down and off the cabinet. You may prop up the bottom front edge of the machine with a 4X4 block of wood or cushion the top rear edge and lean it against the wall for easy access and removal of the screws.
Once the bottom front panel is off, you'll find the drain filter knob. Turn the knob counterclockwise to remove and clean the filter. You may need to lay a towel under the filter to catch residual water before removing it. Manually drain the water, by gravity, from the tub if significant amount of water is still present by placing the end of the drain hose as low as possible into a basin or bucket.
Click on the link below if cleaning the drain filter doesn't solve the problem.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washers
Jun 20, 2011 | Whirlpool WFW8300SW
My whirpool duet front loader and when my washer get to the last 2 minutes it Flases F. What is this and how do I fix it???
This is a fault code but the F flashes alternately with a number or another character depending on the model of the machine to indicate the fault code number. Since the fault happened at the last two minutes of the cycle, it is likely associated with a drain problem and the fault code is likely F02 or F21 depending on the machine's model.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, you'll find a knob which is the drain filter. Turn the knob counterclockwise to remove the filter and clean it. You may need to lay a towel under the filter to catch residual water before removing it. Manually drain the water, by gravity, from the tub if significant amount of water is still present by placing the end of the drain hose as low as possible into a basin or bucket.
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore HE2Plus - it is 6 years old. All of a sudden two days ago I got up to a load of laundry not done, full of water and the code F21. We have gone through most all of your suggestions. At...
The Sd code appears when sud is detected but it may also indicate draining problem such as blocked drain filter or broken drain pump as signified by the long drain error code F21. The drain pump impeller may be broken or restricted resulting in poor draining or no draining at all or the drain pump motor is faulty. Since the drain hose and filter have been cleaned but the error code still persists, the drain pump likely needs to be replaced. Click on the link below for the detailed troubleshooting instructions.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing
Jun 18, 2011 | Washing Machines
It is FO 2 its happpend twice no papper work for it?
Hello there and thank you for choosing fixya
Depending upon the type of washing machine, you may notice an "F21" or "F02" error code. An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
Please feel free to post me a comment back if you need help with the dissasembly of this ok?
best regards Mike
Mar 28, 2011 | Washing Machines
I got a F21 error, went through and pulled out the drain filter. And tried to start again continued getting F21 error. Bought a new water pump and still getting the F21, also backfilled some water into...
sounds like you have covered all the bases --- the next thing that I would try is to simply unplug the unit from the wall and let is sit for a minute or two and then plug back in. if this does not solve your F21 code, then I would say that the problem is at the sensor or main circuit board.
let me know if you need further help with this issue,
c...
Feb 03, 2011 | Kenmore HE2 Plus Front Load Washer
Rinse cycle stops. F02 error code. Tried to solve the problem by cleaning the drain pump strainer but no luck. I assume that if the drain pump filter is not clogged then it's probably a problem with the...
Hello, Welcome to FixYa. The "F02" on your model of washer indicates the machine has detected a fault or obstruction in the drain process as you obviously already know. Chances are the pump itself is the fault based on your post, at least it can`t be ruled out...yet. Here`s how to check it and clean it... Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation. If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way. Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose. **Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first** 1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws. 2) You will immediately see the drain pump in front of you with a large removable filter. 3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter. 4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now. ( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ). 5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks ! Now You should be good to go. Re-attach the lower panel and you`re back in business. **NOTE: if this still fails to remedy the F02 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc. **This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.** If you'd like the benefit of this solution with pictures, visit my profile page and look for similar "F21" or "F02" postings they are one and the same just different eras. Let me know how it goes and if you require further assistance. Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today. Good luck. Regards, Macmarkus :)
Oct 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Were is pump filter
The following link explains how to access the drain pump on a Whirlpool Duet front loader and clean it:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If you are experiencing problems with the washer draining and/or reocurring error codes of "F02", "SUD", or "F21", these are all indications of a drainage problem.
It does not take much to cause irreparable damage to the drain pump. If these preliminary measures do not correct the problem, you will need to replace the drain pump. Since any error codes are associated with drain times that exceed 8 minutes, if the pump is damaged in any way, these error codes will continue to occur until the pump is replaced.
NOTE: Double check the electrical connections to the pump, as well, by unplugging it and reseating it.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Oct 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
