Question about Rockford Fosgate CPCD05-03 Capacitor Car Audio Amplifier
Rockford capacitor question
I recently installed a rockford capacitor RFC1 and it says it needs charged. it comes with a a little chip which is suppose to be inserted under positive and negative. when i first hooked it up it the green light never came on. now it says it suppose to shut off when its charged. does that mean it came fully charged or what? everything works but just wanted to make shure it won't mess up. plus how often it all do you need to charge it and why is it necessary
    Problem Solver:
  • 8 Answers
I think the "chip" is actually a resistor for DISCHARGING the capacitor. If its hooked up right it should charge and the light should go out.
I dont think the "chip" is supposed to hooked to it when it is in use, but check the instructions..
Make sure the wires are right, and try it without the extra device attached to it.
wezmiester
Posted on May 27, 2008
04 Nissan Sentra recently installed remanufactured OEM Rockford Fosgate stereo. Problem: CD player does not play, displays "error 1"
Sometimes CD players come with a plug that keeps the reader arm in place during shipping. If you don't remove this plug it doesn't allow the arm to move, thus a code. You might recheck this. If that's not the case, check your warranty papers, you might need to use them.
Aug 22, 2011 | Rockford Fosgate Car Audio & Video
How do i charge it
To charge a capacitor:
connect it to a power source that has less voltage than the capacitor's tolerance.
Wait for it to be balanced with the power source's voltage.
The source must be DC.
Feb 20, 2011 | Rockford Fosgate 1 Farad Capacitor Cpc10...
What number of cable should use on rockford fosgate 1 farad capacitor thanks
If good brand name wire, jl rockford monster kicker, the 8 gauge wire will be fine. if buying it at walmart or somewhere, then use 4 gauage wire
Jul 19, 2010 | Rockford Fosgate 1 Farad Capacitor Cpc10...
It's beeping when turned on. Why?
I have read that if the polarity is reversed, or the connections are backwards, the Capacitor will beep. If this is not the case, it may need to be replaced.
Audio cutting in and out protect light turning on Rockford fosgate p4004
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping. Try adding a capa A thumbs up would be greatly appreciated if this answer is helpful to you. audio-cutting-in-out-protect-light-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Jun 20, 2010 | Rockford Fosgate Punch P4004 Car Audio...
Rockford Fosgate 801s Amp
depending on how good you are with electronics and soldering,you may be able to.i used to do warranty repair for rockford and they use mosfet semiconductors in the power supply.it is probably repairable cheaper than a new one,but by someone that knows how to do it.
Jun 12, 2009 | Rockford Fosgate Punch 801S Car Audio...
Will my car handle a rockford fosgat 801s power load?
Hello dreww1005,
If your alternator and battery are in good condition, you probably don't need a capacitor. At maximum output, the 801S will need to draw a little over 30 amps at 12.8V. The specifications call for 8-gauge power and ground wiring and a 40A primary fuse. The Vibe's electrical system should be able to handle it OK.
Hope this helps.
May 08, 2009 | Rockford Fosgate Punch 801S Car Audio...
I have been having trouble with my car stereo system
First reinspect your power and ground connections, vibration may have loosened them.
Then be sure that amp location has proper ventilation, (overheating will cause shout down)
A 2400 in a closed space will definitely need exhaust fans to help circulate cool air around the amp.
The cap should be mounted close to the amp and properly charged before use. It is connected in-line with the main power lead paying close attention to the power in and power out terminals.
Power in = from the battery
Power out = to the amp
Good luck
Aduz
Mar 15, 2009 | Rockford Fosgate Punch 801S Car Audio...
I have a Rockford Fosgate 1 Farad capacitor, power cap how do i wire it in to my car. i know one side is what about the other side is it or -
hi there installing a capacitor is at your own risk as they charge up and hold a lot of power if hooked up wrong can give you the shock of your life and blow your sterio and computers to bits i learnt my lesson any way remember to take off positve before installing here is a diagram how to install it,,,, ok the positive goes to the battery and the amp on one side and the other to ground .....take a look at this easy to use diagram i found for you hope all goes well http://www.caraudiohelp.com/images/car_audio_capacitor_installation.gif
Jun 30, 2008 | Rockford Fosgate Car Audio & Video
Car Audio & Video Logo
118 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
