Question about Lumiscope Health & Beauty
Hi, machine starts but doesn't finish reading the pressure, gets to around 100 then stops
2 Suggested Answers
  • 500 Answers
SOURCE: hi. I have a kenmore Washing Machine model
Hi xochipiliti,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Posted on Sep 05, 2011
Washing machine doesn't stop after time allocated
Possible suspect of the inlet flow, the pressure sensor or the program controller.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Mar 08, 2013 | Washing Machines
Do you know where can i find the rubber gasket that goes around the brew head of my Cuisinart EM 100 espresso machine ?
It sounds to me that your group seal is bad. Since this machine is a 15-Bar unit, it puts out quite a bit of pressure causing water to leak out around the portafilter when making espresso if your seal is old or damaged. The pressure doesn't build up as much when you are running just water through the machine - hence the reason why the machine works ok without grounds. I sell a LOT of parts and accessories for various manufacturers of espresso machines. This particular seal is extremely difficult to locate fom Cuisinart, but is rather easy to replace. Through extensive testing, I have located a replacement gasket produced by another major manufacturer that fits the Cuisinart EM-100 & EM-200 machines perfectly. I sell them for $10.99 each (or two for $19.99) which includes shipping in the continental US and I accept Paypal. If you would like to contact me via email (cowboy_romeo@yahoo.com), I will be happy to help you out.
Mar 20, 2012 | Cuisinart EM100 Stainless Steel Espresso...
Washer doesn't spin drain
remove the drain hose at the back of the washer and check that the filter is not blocked.
Feb 24, 2012 | GE Washing Machines
Loose boobin winding
You need to ensure that the thread is going from the thread spool at the back of the machine, through the eyelet, then around the silver tension disc on top of the machine, then to the bobbin when you are winding it. Also, pull the thread tail up through the hole in your bobbin to start and hold the tail so the thread starts to fill smoothly and doesn't loosen.
I've marked the disc in red on this image
Please read my Tip on bobbin winding; its really important to get a good wind and you can add more tension yourself by applying gentle pressure to your thread spool on the back pin as you wind off it.
Link is http://www.fixya.com/support/r10598580-winding_bobbin_correctly
The stopping when full is possibly because your bobbin is winding unevenly but I never run it until it stops itself anyway, and do the winding at 3/4 speed, not flat out. You want a really smoothly tensioned even wind onto the bobbin so your thread comes off the bobbin when stitching with even tension, not stretched, then loose.
Hope this helps you with your problem.
Dec 14, 2011 | Elna Quilter's Dream 6003Q
Hi. I have a kenmore Washing Machine model 27062601 It doesn't finish the cycle. stops wen is washing, then I have to open it and start the cycle again. some times this works, some times don't. ...
Hi xochipiliti,
Kind Regards
JEDEMEYER1
Sep 05, 2011 | Kenmore Washing Machines
I have a Quantum XL-100 I am having trouble getting it to start, I plugged in the Embroidery bed, threaded the machine done all that the manual instructs to do...but can not get it to start...I have pushed...
I have a Quantum XL-100 and have owned it for 10 years. When I bought this machine, I did get a 1 year warranty from the Dealer if anything went wrong. As you would know it, the machine did stop working. As it turned out, the Dealer had to cannabolize another machine to make mine work again. It has been awhile, but I think I was trying to do the Embroidery Function when it stopped working. Sorry about that.
Randee
Randee1976@hotmail.com
Aug 12, 2011 | Computers & Internet
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
I have oil pressure until i stop , then it drops to below 10 psi
Increase the viscocity of your oil. If you're using 10W30, go to 10W40. If you're using 10W40 switch to 20W50. Don't use single weight oil.
Sep 19, 2009 | 1998 Jeep Wrangler
Health & Beauty Logo
27 people viewed this question
Top Lumiscope Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lumiscope Health and Beauty Expert? Answer questions, earn points and help others
