Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Red went to one side & green went to the other side
  • The tv's model # was #61SBX59B rear projection 57F500 57in. was incorrect, please advise as the info doesn't apply that I paid for and would like to try to get my moneys worth! Sincerely ~ KM
  • 10,594 Answers
I hope our talented expert would have given you helpful and correct info in chat session from related service manual, feel free to ask further help if required.
Thanks.
Posted on Sep 30, 2010
Testimonial: "Thanks for the help so far:-)"
  • 12 more comments
  • Shahid Electronics
    Shahid Electronics Oct 04, 2010
    OK, I'll try to help you, can you replace/ solder parts in circuit board?
    We are sorry if our talented expert couldn't advise properly, can you mention what action was advise to fix the tv issue?
    Thanks.
  • Yes he said it would be to costly to repair and should get a new one....
    I'm sorry for that incorrect advise by previous expert.
    Hitachi 61SBX59B is rear projection tv and questions shows tv got problem of convergence output chips failure, there are two STK392-110 ICs utilized as convergence output chips, relace them to fix tv problem. It is rather easy to replace these ICs for handy person who knows soldering work. Required ICs are available in part store.com, copy following link in browser search bard to view IC image and price info. [http://www.partstore.com/SearchResults.a...
    Due to limit of words, given link become incomplete..
    again I see incomplete website link, ok, go to partstore.com and put STK392-110 in search box at top right of page to see results.
    Thanks.
    all the mess happens with URL is due to low rating that you gave my assistance offer because I do not find proper window to respond in low rated answer.
  • Thank you I will give this info to my husband, tonight.
  • okay I'll have hubby do it tonight! :-) I hope! Thank you!
  • I don't understand..... he was very nice I couldn't find the model # at the time later hubby found it.... sorry!:-j ... thanks ....
    Shahid Electronics Oct 05, 2010
    No problem, let me know if you have additional question to fix this tv.
  • Ok the part # you gave me is no longer available they gave me a chose between 3 different parts to replace the part which one should I use and will it work properly? Partstore.com and search STK392-110 of part...
    Condition: New (This item is an alternate to part #CZ00433)
    More Info
    See 25 50 Per Page Page:1
    Thanks again!:-)
    Shahid Electronics Oct 07, 2010
    STK392-110 is available in PartStore.com , put that part number in search bar at right side of page to get results and if they offer any alternate part, that can also be used to fix your tv issue.
    Thanks.
  • Hi again! Sorry to be a bother, I just wanted to be sure this is the only part I will need to fix the red
    Hopefully Yes, just look for faded color/ having burn marks big resistor nearby these STK chips, found just in case then replace with same value. You can ask as many questions as you wish to solve tv problem, I'm sorry that you had been advised incorrectly by previous expert. Good luck
1995 Mitsubishi mirage 1.5 motor isn't getting any spark
several things cause no spark with a logic probe 2 led version (red & green) with ignition on test both sides of the ignition coil they should be red if positive side green power problem to ignition + side red and - side green internal open in coil both red then place on - side and crank engine flashes red green then coil is bad does not flash then remove distributor cap and test magnetic pick-up coil if flashes replace module does not replace pick up coil.
May 08, 2014 | Cars & Trucks
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I have a kicker dx 500.1 amp and a kicker cvr12 sub. When I first hooked up worked perfect for a few minuted. Adjusted settings ont the side and it went out. Now When I power on it the protection light...
check the fuse on the power wire (+) not the ground wire .. i had a kicker 1500.1 on 2 l7 15\'s and when the bass would hit hard the fuse would vibrate and cause the amp to go into safe mode.. after re wireing the whole truck i then found out it was the 150amp fuse holder
Aug 07, 2011 | Kicker Car Audio & Video
I need to know what the six wires that are on one plugin goes to by the color of each seperate wire for the drivers side electric seat. The Colors are: Black, Red & Black, Yellow & Green, Yellow...
That connector is for the lumbar support in the seat. The wires are as follows:
Black - Ground, ends at left side under the dash.
Red and Black - Power to circuit fromk fusible link
Yellow and Green - Lumbar support, Push out
Red and Yellow - Lumbar support, Release in
Yellow and Blue - Side lumbar support, Spread out
Yellow, Should be Yellow and White- Side lumbar support, Close in
Hope this helps. Good Luck!
Apr 29, 2011 | 1994 Mitsubishi 3000GT
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
The color of the picture shows only blue and yellow the red and green just disappeared. Is this a fix I can do myself??
your green is acutally there because you had yellow, so your problem is most likely the RED CRT od Video amp ic on the crt board you should have a tech check it out if it went off suddenly then i would lean mostly to the amp
Nov 30, 2009 | RCA R56WH76 Projection Television
Still having amp problems
Hello lilmario,
After eliminating wiring problems and possible shorts, grounds and low impedance in the speakers, most likely the amp is failing internally. A partial failure of either the output MOSFET's or the thermistor. In either case, the repair requires removal and replacement of components on the circuit board. Depending of the age and original cost of the amp, such repairs are sometimes expensive.
I'd recommend having a professional audio shop test the amp and provide an estimate for repair.
Hope this helps.
Sep 21, 2009 | Car Audio & Video
LCT50HV black screen and blinking red/green lights
Replace your Bulb which is located on the side panel. U can do it yourself and save some money.
May 19, 2009 | Syntax Olevia 50" Rear Projection...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
286 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
