My infoprint 1570 MFP is getting an error 201.22 paper jam
flopez
  • 161 Answers
SOURCE: Dell 1600 paper jam 1 or no cartridge
Your unit is actually manufactured by Samsung. Most probably you have a bad paper sensor. As a technician, you will find these sensors on the power supply board (SMPS)or main board. If your are receiving tech support from Dell, please illustrate those guys on how to do their job.
Posted on Oct 02, 2007
SOURCE: Lexmark c510---201 paper Jam helps empty my wallet
The problem with my 510 was that the length of the plastic tab that the paper actually touches was a tad too long and so it got caught. I took the entire arm out, cut ~1/20 of an inch off of the end of hte plastic tab, and viola it works just fine now.
Posted on Oct 14, 2008
SOURCE: IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Posted on Apr 17, 2009
SOURCE: lexmark E 342 n paper jam with error code 201
I have a lexmark 342n that the paper jams before it reaches the fuser what could be the problem.
Derek Walters
Posted on Jan 12, 2010
SOURCE: phaser 3200 mfp LSU ERROR over heating
Lsu error after installing Print-Rite cartridge ?
Posted on Dec 06, 2010
HP Color Laserjet CM6040f MFP
Hello Desmond,
You will find all your answers regarding paper jams on this printer at the following link:
HP Color LaserJet CM6030 and CM6040 MFP Series Jams HP Customer Support
This should help you with this issue.
Good Luck!
Rich Lilja
Aug 02, 2017 | HP Office Equipment & Supplies
ERROR MESSAGES ON HP LASER JET 1536DNF MFP jam in cartridge - there is no jam
Check to see if the paper is feeding, should be feed some what into machine, if not paper is not getting to cartridge and showing a jam... some times clean wheels with water or windex
Mar 28, 2017 | HP Office Equipment & Supplies
13.4200 jam in side open the left door
Open the door and you may need a flashlight to search for the paper. Check your feed rollers also. If they are not feeding the paper you will get this error
Jan 06, 2014 | HP LaserJet M5035 MFP Printer
Hp laserjet m3035 mfp does not take up the paper squeaks and reports paper jam - no papaer is jammed
The most common cause of this type of Phantom paper jam is worn pickup rollers and separation pads in the paper trays. When these rollers get worn the gripping surface can not grab the paper correctly so no paper is fed into the printer and the printer gives the paper jam error. The rollers are very easy to replace, it takes about 20 minutes total. Here is a link to more information about the roller maint kit:
www.ccl-la.com/catalog/product_info.php?products_id=172
Mar 18, 2013 | HP LaserJet M3035 MFP Printer
Infoprint 1634 repeatedly jams
It may be time to replace the Fuser.
There is no certified way to repair a Fuser with purchasable parts, the assembly it self must be replaced.
May 22, 2009 | IBM Infoprint 1634 Laser Printer
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
IBM INFOPRINT 1352
check for paper jam in duplexer - or it is not seated correctly. power cycle printer after reseating to re-init printer.
Nov 17, 2008 | IBM Infoprint 1352 Laser Printer
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
Infoprint 1570 MFP (RICOH)
try accessing the machines web page( browser --address= ip address )
Jun 24, 2008 | IBM Infoprint 1570 Laser Printer
k24674
jasbo
jasbo
