Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
My Brother MFC-490CW will not acknowledge the new cartridge. I keep getting the error "Cannot Detect" "Reinstall Slowly" . I have performed this function no less than 50 times to no avail with multiple cartridges. Any suggestions?
I don't know if this will solve your exact "cannot detect" problem, but it solved mine.
Problem: Cannot detect
Like other posters in this forum, I replaced all four of my ink cartridges at the same time when my MFC-490CW said they were all low. After I installed 4 (third-party brand) cartridges, the display said something like "Cannot detect ink cartridge, re-insert slowly" and indicated the cyan cartridge. Like many others, I tried this many times. I tried turning the power off, unplugging the power plug from the wall, different sequences of cartridge insertion, etc. None of this helped.
Solution: Clean the sensor
Much has been written here and in other places on the 'net about the trick of using electrical tape on the ink cartridge in the ink-level sensor window. I remembered seeing a good deal of ink on the outside of the cartridge as I removed it. This leaky ink cartridge had somehow coated either the sensor or it's associated light with blue ink, rendering it unable to detect the presence of a cartridge. I was able to clean the sensors with some Q-tips and isopropyl alcohol (not the optimum technique, but it was effective). Just to be sure, I swabbed the other sensors as I had removed all the cartridges to make room for my fat fingers. All sensors swabbed clean. The cyan was the only one covered in ink. I swabbed the cyan sensors with the alcohol until they were clean (maybe 20 Q-tips all total). I carefully dried the area with the Q-tips and let the alcohol evaporate for a minute then re-installed the ink cartridges...and printed a document. Yay!
As I said, this may not solve your particular "cannot detect" issue, but give it a try. It is a little messy but I'm back in action and hey, tattoos are hip. I just won't tell anyone why they're all the same color of blue and why I tattooed my fingers.
Posted on Jan 28, 2011
Thank's got the same problem on my Brother MFC-6490CW, I follow your trick I used isopropyl 70% half and half water, but I unplug the unit first, it's took me 8 qtip and I also clean each extension ink thank with the same solution and not only now it's detect back the cartridge but give back the right level of ink! Thank's was a cheap and quick fix work perfectly now!
Cebuman
Posted on Mar 07, 2013
  • Thank's got the same problem on my Brother MFC-6490CW, I follow your trick I used isopropyl 70% half and half water, but I unplug the unit first, it's took me 8 qtip and I also clean each extension ink thank with the same solution and not only now it's detect back the cartridge but give back the right level of ink! Thank's was a cheap and quick fix work perfectly now!
    Cebuman
MFC 9440CN does not detect yellow cartridge!!! it
THERE ARE A COUPLE OF SOLUTIONS HERE.
1) With a clean cloth or compressed air clear the sensor are on both cartridge and area around where cartridge plugs in.
2 Check for blockage in cartridge
3) Try a new Yellow cartridge
Oct 10, 2013 | Brother MFC-9440CN Multifunction Printer
BROTHER MFC 490CW my printer after 3 months I haven't used got crazy, do not recognize the cartriges and says are empty... to reinstall them etc etc, I did but nothing to do, the printer see them...
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Jun 05, 2011 | Brother MFC 490cw Color Inkjet...
I installed a new black ink cartridge(lc61bk) on a brother mfc-495cw and now nothing is printing.
Check out if you've installed it correctly. Also check out other ink cartridges, are they empty? If yes you won't be able to print anything. However, if all ink cartridges are OK then try to reset the printer or reinstall the drivers. You can find help in MFC 495cw users manual
Feb 27, 2011 | Brother MFC 490cw Color Inkjet...
Black wont print after new cartridge and cleaning. Model MFC 490CW
make sure the plastic is peeled off the cartridge that covers the tiny hole on the cartridge
Jul 27, 2010 | Brother MFC 490cw Color Inkjet...
My Brother MFC-495cw will not print. It pulls paper through but nothing prints.
This is due to the ink...Check you ink cartridges if they are still full of if the ink has dried out thats wht printing is not working
Jun 11, 2010 | Brother MFC 490cw Color Inkjet...
Brother MFC 8660DN "Toner Error Reinstall Drum I got a new drum, new toner and still printer isn't working and show the error reinstall drum unit please help
Pull the drum/toner out and look into the machine, at the wall on your left. There's a little plastic lever there that pivots to detect a new toner cartridge. Sometimes the lever gets sticky; wiggle it to free it up. If you feel brave enough to remove the outside cover of the machine on that side, you can put a dab of grease on the lever's pivot.
Apr 04, 2010 | Brother MFC-8860DN Printer
I have a new LC61 and just replaced the blk
Leave the machine on with ink installed, unplug power for a few seconds and then plug in while you hold the stop button for a few seconds. Should clear the error for you, if not you may need a new ink sensor board.
Jan 08, 2010 | Brother Multi-Function Center MFC-240C...
Installed software and tested but keep getting "Off line" status
you have lost your printer driver .
delete the original in add and remove section in your control panel and re install it .
this should fix it
Sep 28, 2009 | Brother MFC 490cw Color Inkjet...
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
2,442 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
