Question about Dishwashers
Changed the start switch but won`t run.You get blue line when you press the on button ,at times it just blank. This is what was happening befor changing the switch.-What`s the problem? Kenwood KS474S
  • 17,130 Answers
The problem can be the program controller is not responding and is defective.You will have to confirm the power to the panels and the voltage to the mP of the board , if the mP is showing no result this can be the fault , if so thenit must respond to all the inputs to deliver the output and the display.
If possible try to get a board to swap and test to confirm.
Posted on Sep 30, 2010
Dryer intermittently not starting.
The rat chewed up the power line and caused it to short out. Kill the rat!
Jul 14, 2013 | Whirlpool Dryers
My kenmore dryer will only run if i hold down on the start button. this has happened to me before but i cannot remember the steps to take inorder for it to reset.
first check the door safety switch,, if its bad the dryer won't run,, if that checks out ok, its time for a new switch for the start button, to check these, and do the door switch first, unplug the door safety switch and place a jumper wire between the 2 wires leading to the switch, try starting the machine making sure your away from any moving parts , if this works, replace the switch, if it stays the same, do this same procedure to the switch for the start button
Jun 21, 2011 | Kenmore Dryers
Triumph Daytona 600 will not turn over
Hi, Jordan_x_tur before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bike won start Not battery think
04 Daytona 600 Won start please help
Triumph 2003 Daytona 600 Service Manual
Hermys Tire Cycle Inc 2004 Triumph Genuine Tools and manuals Motorcycle...
Triumph Daytona 600 Owner Handbook Manual
Jul 04, 2017 | Triumph Daytona 600 Motorcycles
Dell 3008WFP monitor cut out after 2 or 3 hours use
sounds like a over heating problem, if there is any fans make sure they are tunring , make sure no vents are coverd on back, hover any dust from any of these areas. if continues you might be looking at a repair job.
Nov 29, 2009 | Dell 3008WFP Monitor
Power on/off problem
If possible go for a repeareing.
Feb 18, 2008 | Computers & Internet
Laptop Screen is Blank
there is a hole on the back usually goldish inside take a pen push it in there hold for a couple seconds and press the power button
Jan 26, 2008 | Toshiba Satellite M35X-S349 Notebook
Wiring color code for xr-c5100
I am about to sell one on eBay - here are the connections from the installation paperwork and connector that I have:
Top row, left to right:
White - Front Left (+)
Green - Rear Left (+)
Purple - Rear Right (+)
Gray - Front Right (+)
Blue/White strip - AMP REMOTE (Max 0.3A)
Blue - ANT REM (Power Antennta Remote) (12V, Max 0.1A)
Red - Power (Accessory)
Black - Ground
Bottom Row, left ot right
White/Black - Front Left (-)
Green - Rear Left (-)
Purple - Rear Right (-)
Gray - Front Right (-)
BLANK
BLANK
BLANK
Yellow - Power (Battery)
One of the BLANKs is for the "Light Blue - ATT (attenuation for car phone)", but it is unclear which one. This wire is not on my connection block...
The circular BUS line to the right of the terminal block is apparently for linking to a CD/MD unit (cable supplied with unit)
The Blue 3.5mm socket is for the RM-X45 Rotary Commander (which attaches to the indicator lever)
Important notes:
If there is no ACC power line in the car, do not connect the red lead.
Ensure the power select switch on the bottom of the unit is in the B position, then press the RESET button (behind the faceplate).
This means that the display will be off when the unit is not in use - avoiding a flat battery risk.
(Posn A is for normal use, with red line on ACC)
The RESET buttom should be pressed after installation, before initial use.
Hope this helps.
Jan 08, 2008 | Sony XR-C5100 CD Changer
3230 try another battery
Dec 18, 2007 | Computers & Internet
Printing blank pages
Did you run the cart initialization?
Try this: (use new carts because it consumes some ink)
press menue then start mono (blue) then fourtimes arrow up button (tel-index). machine will be in maintenance mode and lights will flash. press 7 then 6 then 4 then start mono. machine will refill tubes and ph with freh ink and do some cleaning.
Leave maintenace by pressing 9 then 9. Do run a quality test print by pressing ink etc. Iy you cant see the letters and colored blocks well the ph has to be replaced.
I guess your machine is a 2.5 years old. Unfurtunately brother ph didnt last longer than that time when useing generic ink.
Nov 28, 2007 | Brother MFC 420CN All-In-One InkJet...
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
