Question about Dual Car Audio & Video
AFTER HAVING MY BATTERY DISCONECTED 4 2 HOURS IN MY 2003 FORD F150 I CAN'T GET THE UNIT TO TURN ON,ONLY A RED LIGTH ON THE VOLUME CONTROL.
  • Dual Master
  • 17,129 Answers
If the power is coming to the set without any fuse blown , the switched and unswitched +12, then it is possible that the code is reset , if this is the original set in the Ford.
If so contact dealer for code to be entered to set this to work.
Posted on Sep 30, 2010
I have a 2003 Ford F-150 FX4 5.4 and the AC only blows out of the defrost and help
Dustin, Sound like vacuum loss to position switch. Defrost is the default position when vacuum is lost in vent control system. Check any and all vacuum lines and connections under hood first, especially any that run through firewall. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2001 F150 V6 4 2 AC Heat Stuck In Defrost Easy Repair
Heating Vent Control Issue Page 2 Ford F150 Forum
2003 150 heater auto climate control Defrost Only Ford F150 Forum
Fixed the EATC defrost only Ford F150 Forum Community of Ford Truck Fans
Apr 13, 2016 | Ford Cars & Trucks
Why does my air blow only thru the defrost on my 1995 f 150 truck ?
The vaccume line that switches it is disconected or broken,,,under hood or dash,,,,, under hood location ,,,pass side,,,,,firewall,,about 10" down and 12" over will be close near ac/ heater hoses,,, either black or red plastic line,,,under dash loaction,behind glove box or ,, maybe back of temp brokin or undone you will have to track it down,,,, the temp control unit could be bad aswell
Aug 11, 2014 | 1995 Ford F150 Styleside Regular Cab
Engine turned off and heater fan is still on with no key in ignition
disconect the positive on battery to turn it off before it runs youre bat down then you will want to replace the fans relay
Dec 12, 2010 | 2003 Ford F150 Regular Cab
How do I reset the computer on Ford 2001 F150 6
disconect the l;ive from the battery for 3mins that dose it for me
Nov 23, 2009 | 2001 Ford F150 Styleside SuperCrew
2002 F150 v6-4.2L I have a service engine soon ligth on. Install a reader and the code is P1518 manufacturer controlled vehicle speed, Idle control & auxilliary inputs.
YOUR DIFINITION IS INCORRECT, HERE IS THE CODE FROM THE FORD REPAIR MANUAL
P1518 Intake Manifold Runner Control (Stuck Open)
CHECK FOR DISCONNECTED INTAKE RUNNER CONTROL VALVE LINKAGE AT UPPER PLENUM CHAMBER
Oct 09, 2009 | 2002 Ford F150 Regular Cab
My 2003 f150 v6 is putting out a 1299 code for service engine soon light, coolent is at full capacity, drive belt is okay, whats the chances of a cylinder head temp. sensor going bad, and where is said...
might need to be burped (serious) take radiator cap off jack one the of it up with ith running hold up 30 seconds let down do the other side of the truck repeat 3 or 4 times, cap it shut it off dissconect the battery for a haf hour see if it goes away
Sep 10, 2009 | 2003 Ford F150 Regular Cab
2002 explorer radio not working
From LustyKid:
Steve:
Suggest you read th manual on the radio. Some radios you have to push in the on off button until the enter code window appears.
In other words push in to turn radio on and hold it in that position until the code window appears in the screen. Then enter code.
Never heard of disconnecting the battery to clear the code. All that does is tells the radio that an attemp was made to steal it, thus regenerating the lock 10 code. What it does clear is the ECM Module codes. Who was the dumbwit at the dealer that told you that? He needs to be sent back to school.
Dec 07, 2008 | 2004 Ford F150
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
2003 F150 4x4 will not engage
also locate the GEM module should be locate at firwall on pass.side . disconect negative battery post , pull gem wire plug, 8mm bolt-- clean and fill with dielectric- grease. at least that won't cost to much, alittle time and fewn bucks for grease.--this happend to me exact problem ,maybe same solution . good luck!
Jul 01, 2008 | 2003 Ford F150 Regular Cab
Car Audio & Video Logo
65 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
