Question about Whirlpool Dishwashers
Hello, dishwasher whirlpool ACP 4738 display fault code fb (f6 ?) after 3 minutes run. Do you know what fault code means ? Thank's DT
5 Suggested Answers
  • 641 Answers
SOURCE: My dishwasher has a fault
I am not familiar with your dishwasher, but could you explain the problem you have (does it stuck, on which stage etc..)and maybe this information will allow us to help you.
Posted on Jun 25, 2006
SOURCE: Whirlpool ADP5966 fault code F8
just choose another prog setting and hold the start button in for a few seconds.
Posted on Sep 30, 2007
SOURCE: whirlpool dishwasher fault code f6
get a Maytag
Posted on Sep 05, 2008
SOURCE: Whirlpool dishwasher ADP5962 F7 error code
emmanuelr is spot on with this advice. The dishwasherr had been idle for a few months so as advised disconnected and reconnected the connection to the water flow meter and job done. My friend you are a scholar and a gentleman thank you so much. You are not an apprentice to me.
Posted on Apr 06, 2010
I have an error code on my Electrolux dishwasher EO?
Hello Judy, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "EO". The error code "EO" means that you could have a possible issue with the flow controller. I would recommend performing a reset on your dishwasher and this could help clear out any potential miscommunications. You can reset the dishwasher by disconnecting power from it for at least ten minutes. If the reset does not help correct the error code I would recommend having a professional technician out to perform a full diagnosis. Hopefully this information is helpful to you. -Matt
Feb 03, 2016 | Electrolux Dishwashers
My dishwasher FDB2510LCC1 get a cl code while washing and stays running on the wash stage until it is shut off
Hello Randy, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher is displaying an error code of "CL" this means close door. The dishwasher may not be sensing that the door switch is closed. The "CL" means that you could have a possible issue with the main control board or door latch. I would recommend checking to make sure the latch does not have any visible damage. This could also be a miscommunication within your dishwasher and a reset may help clear it out. In order to reset the dishwasher you would flip the household circuit breaker off for at least ten minutes. We hope this information is helpful to you. -Matt
Jan 28, 2016 | Frigidaire Dishwashers
What does 01 error mean?
Hello Ned, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "01". This error code means that a leak has been detected. Have you noticed any water coming from the bottom or near the dishwasher? This could also be a miscommunication within the control of the dishwasher and a reset may help clear that out. You can reset your dishwasher by disconnecting power from it for at least ten minutes. If that does not help to resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful to some degree. -Matt
Jan 22, 2016 | Electrolux Dishwashers
What is error code no. F6E5 mean in Whirlpool Dishwasher (ADP 6776), and how to solve this problem?!
The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error persists, the display board has to be replaced.
Sep 27, 2013 | Dishwashers
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
Whirlpool Electric Range Model # RF369LXPB. Self cleaning function does not work. A code displays after self cleaning function has been on for about 3 minutes. The code is F5EO. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.It means the door lock and door switch dont agree. Check the door switch does the oven light go on and off? does the door lock? It is either the door lock or oven door switch that controls the light.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Whirlpool RF369LXPQ Electric Kitchen Range
Fault F02
F02 means Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank You
Sep 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error F dT. washer won't start.
There is no such error in whirlpool fault code libraries as "F dT".If it is "F dL" then it is explained as follows.Please do clarify.Thank you.
FdL - Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Please do rate my solution if accepted,else will await your further comments.Will be glad to help you out.
Apr 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
366 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
