Question about Accessories Alarm Siren
I cannot turn the key on my 1997 ford F150 after having gotten into my vehicle. It looks like the security system still has it locked out. I used the key faub to get in and also the key but it still will not let me turn the key. I did what the book has told me as far as I can see. HELP
  • 139 Answers
It sounds like the steering wheel is binding up the ignition. While turning the ignition key, turn the steer wheel back and forth. You will need to apply a bit of force to turn the steering wheel to overcome the binding.
Posted on Oct 01, 2010
Testimonial: "THxs for the help. It did the trick"
This car is very good in mailage but in this car feul pump is not given .
Posted on Mar 16, 2012
I have a 2000 Ford F150 I had to break the lock can you bypass the security system
No, but if you have the key and hold it close to the lock as you start it, it will start. Other wise you are looking at around $400 to fix it. The lock, 2 keys, and programming the keys.
Apr 03, 2016 | Ford Cars & Trucks
Why wont my truck start using the ignition but it will from the relay box?
The start wire , to the key is bad, Find and fix open. It is most likly broken or disconnected at the relay
Sep 07, 2014 | Ford American Muscle 1997 F150 Xlt Ford...
F150 turn chiped key, but engine won't start jumped star and it starts
Hi Trinity, If the vehicle starts with a jump, the security equipment is working correctly. Have the battery and charging system checked. Regards John
Apr 21, 2013 | Ford Cars & Trucks
I had my battery change and now when I turn off the vehicle and lock it a few minutes latter the horn and the light start going off. WhaT can I do I have a 2004 ford f150 extended cab
It sounds like you have a factory security system. Even if it is aftermarket they sometime t need to be reset. First find out if the security system has a balance system. This will set off a horn or alarm if the vehicle is rocked or moved. If not, try resetting by unlocking all the doors with remote. Disconnect the negative cable and leave it off for a few minutes. Then reconnect it and start the engine, turn it off and lock the doors and wait. Beyond this I have nothing further
Aug 22, 2011 | Ford F-150 Cars & Trucks
Need to find a way to disarm alarm for Ford Contour Sport, 1996. Also it will not start
Many Ford trucks, vans and suvs use PATs (passive anti-theft) keys. These keys prevent someone from copying your key to a blank and using the blank. There is a small chip in the key which the vehicle must recognize before it will start.
PATS is Ford Motor Company's passive anti theft system. In 1996 it started showing up on select models of Ford and Lincoln Mercury vehicles. The keys for these vehicles have a tiny radio frequency transponder imbedded in the plastic Head.
pats_key.gifWhen you attempt to start the vehicle, the onboard computer sends out a RF signal that is picked up by the transponder in the key. The transponder then returns a unique RF signal to the vehicle's computer, giving it the ok for the vehicle to start and continue to run. This all happens in less than a second, and is completely transparent to the vehicle operator. It is a very effective system that does its job without the vehicle owner having to think about it, or modify his / her usual routine.
The PATs key is used on the following Ford family trucks and SUVS:
1998-up F-150
1998-up Expedition
2000-up Excursion
1998-up Explorer
1998-up Ranger
1998-up Lincoln Navigator
1998-up Mercury Mountaineer
Additionally, PATs can be found on the follow Ford family cars and mini-vans:
1998-up Contour
1997-up Crown Victoria
1999-up Escort
2000-up Focus
1996-up Mustang and Taurus
1998-up Windstar
1998-up 2000-up Lincoln LS
1998-up Lincoln Mark VIII, Lincoln Continental and Lincoln Town Car
1997-up Mercury Grand Marquis
1998-up Mercury Mystique
1996-up Mercury Sable
Following are the instructions for programming a blank key (you must have at least one working key for this procedure).
The PAT
1. Make sure you have both keys.
2. Turn on car but don't start. Watch "theft" indicator untils it goes out.
3. Turn off and repeat procedure with second key.
4. After "theft light goes out, insert new key and turn on.
5. Wait until the theft indicator goes off and then turn off switch.
6. Wait thirty seconds. New key is now programmed into security module. Repeat for any other keys.
1. Erase any old codes by entering the factory code.(buttons will light up)
2. Press 1/2 button within 5 seconds.
3. Press 7/8 and 9/0 buttons at the same time within 5 seconds.
To set new code:
1. Enter factory code (numbers will light up)
3. Enter personal 5 digit code(decide beforehand) within 5 seconds of each previous one.
To unlock all the doors,press the 3/4 button within 5 seconds of the driver door unlocking.
To lock all doors and set alarm system,press 7/8 and 9/0 at the same time.
To disarm or reset a triggered alarm,just enter personal or factory code.
Do not set a code with five of the same consecutive numbers. It's too easy for thieves to figure out.
Deactivating and Activating Autolock
To deactivate the "autolock":
With all doors and tailgate closed but NOT locked,and ignition OFF.
1. Enter 5 digit code
2. While holding 7/8 button in, press and release the 3/4 button.
3. Release 7/8 button
The horn will chirp once if the "autolock" was deactivated
or two times if "autolock" was activated.
To reactivate the system,repeat steps 1 thru 3
Alternate Method To Deactivate And Activate Autolock
Do steps [1] through [5] (below) within 30 seconds or you'll have to do it over. If you have to do it over, wait 30 seconds between attempts.
Close all doors securely.
1.Turn the ignition key to ON.
2.Press the power door UNLOCK control THREE times.
3.Turn the ignition key from ON to OFF.
4.Press the power door UNLOCK control THREE times.
5.Turn the ignition key back to ON .The doors should lock and unlock.
6.Press the power door UNLOCK control. The horn should chirp ONCE to confirm successful switching of the autolock system.
Hope this help you (remember comment and rates this).
Apr 04, 2010 | 1996 Ford Contour
1997 chevy cavalier ignition key will not turn
hi, steering might be locked try to turn the steering going to the left while turning the ignition key. hope this helps, have a nice day
Feb 11, 2010 | 1995-1997 Chevy Tahoe Ignition Starter...
1999 Ford f150 aftermarket ignition disabler problems
sounds like a good theft proof system. I would trace all the wires and see where they go befor removing anything see if the thing disable breaks a circut when you turn it on it complets a circut. thats what i would be looking for.
Feb 02, 2010 | Vehicle Parts & Accessories
Replaced engine & battery, security system locked us out
sounds like the immobiliser, like you did,nt connect the immobiliser block,a cable with 3 wires,look carefully you may not have noticed & plugged it in. all the leads connected to the battery may not be correct. car thinks it,s being stolen.with fords you need to use the original key(red dot on it)to activate security settings,good luck leave key out of ignition,that may work
Jul 27, 2009 | Ford Escort Cars & Trucks
Ford explorer v6 ohv 1995 VIN 1FMDU34X2SUA16318
problem is nobody can fix this issue for you your vehicle needs to have the key/computer programmed so the vehicle will start.
the security system thinks that you are using the wrong key to start the vehicle.
there is how ever a quick solution if you have other keys on your key ring, remove them as they may be interfering with the signal.
if it still does not start you however will need to find a dealership to fix your issue as ford is the only one that can program keys/computer.
May 13, 2009 | 1997 Ford F150 Regular Cab
97 Jaguar XJ6 No Start (good battery- no click)
when you battery goes dead, the security system locks the car. When you charge the bathery, use the key to lock the door and hold until the alarm activates. open your door and you can now start your car...dmakia@gmail.com
Mar 16, 2009 | 1997 Jaguar XJ6
Accessories Alarm Siren Logo
248 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
