Question about Dewalt Round Head Framing Nailer D51845
As soon as air hose is connected the firing rod extends, stayes extended, and air continues to come out the vent holes at the top of the gun. this problem started after i replaced all the o-rings and trigger valve assembly.
  • 2,176 Answers
Check for a stuck firing valve or pinched o ring in the cap area, usually this is caused by the trigger valve but look in the cap, Did you lube all the o rings before installing??
Posted on Oct 03, 2010
Dewalt D51822 trigger goes 1/2 way without depressing the piston. The result is the piston does not get depressed enough to fire the gun. Tried oiling piston, and goes to end of stroke--that is, fully...
Dewalt nailers use some orings that are made of vinyl (clear to yellow in color instead of buna or viton). These orings fail by getting soft and sticky. The gun may not leak but will not work correctly. The trigger should fire the gun when depressed about 1/2 way in. The oring repair kit has the same orings. I use generic orings in the gun to solve the problem. There are two orings inside the gun that should be changed and at least two on the trigger valve stem. In time the gun may fire a nail when you connect the hose. Check the internet for recall on some of these guns. The orings in the gun that should be replace make contact between the white cylinder spacer and the cylinder (smaller is standard oring # 141 the larger is 74.4mm x 3.1mm). The two rings on the trigger stem are 2mm x 1.5mm . If you do not have a source for orings then just replace the trigger valve. You also might try setting the depth adjustment all the way down. Good luck.
Aug 19, 2013 | Stanley Bostitch Coil Framing Nailer
Nailer drives nails too deep
n80 coil nailer is a very powerful nailer used for hard wood. If the driver is setting nails too deep, adjust safety foot to the lowest level. Install safety foot no-mar boot to lift the gun even higher. If still too deep, most likely the lower bumper inside the gun is worn-out or cracked. Easy test. Remove nails and connect air supply. With trigger depressed, push and hold the gun against work (I use an old rubber hose tightly coiled up). This will fire the gun but keep the driver down allowing you to examine the tip of the driver. The driver should extend out past the nose less than quarter inch. If the driver is extending too far, most likely bumper is worn out. If a large quantity of air is leaking out the nose of gun during the test, indication that lower bumper is cracked. Good luck.
Apr 06, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
I have a magnum air 33degree gun, i removed the head cap to replace blown gasket, when i put it back on the gun will not fire.
Check the alignment of the of the gasket in reference to the small hole on the sealing edge(gasket has four bolt holes and one vent hole). This small hole allows air to vent from the upper part of the head when you depress the trigger casuing the gun to fire. If the gasket seals the hole or if air is leaking past the orings in the head vale the gun will not fire. If you hear air leaking from trigger when you attempt to fire the gun, most likely orings are not sealing. Remove the headvalve and lube the orings. If no air leaks from trigger when your attempt to fire, vent hole blocked. Good luck with your repair.
Aug 27, 2012 | Magnum Air 8 10 Gauge Framing Nailer
Nailer will shoot a nail, but will not foward the next nail. Gun is new maybe 15 lbs of nails or so.
If the nail will not advance, easy test will determine problem. Open door and remove the nails. Lightly tap the nose of the gun against coiled rubber hose or soft wood with door open. If the driver falls to bottom, the piston oring needs to be replaced. The driver should stay at top of cylinder. Next pull back the feeder to rear position and check for tension. The feeder should spring back towards you when you push. Finally, the check paws on the door should return to extended positon when you push on them. Replace springs as needed. Connect air to gun and rapidly bump fire the gun against rubber. The feeder should move back and forward just as quickly as the driver moves. Good luck
Aug 25, 2011 | Hitachi NV45AB2 78Inch to 134Inch Roofing...
Gun will not shoot nails completely;no matter what wood,thickness,etc.they drive all but 1/2"
May be due to broken tip. Easy to check. Remove nails and leave door open. With door open, lightly tap the nose of the gun against coiled rubber hose or soft wood. The driver should stay at top position. If driver falls to bottom of the cylinder, replace piston oring. Now press nose of the gun against old coiled up air hose or soft wood and squeeze and hold trigger. The gun will fire and the driver should stay in the down position untill you release the trigger (if not single fire trigger, if single fire trigger remove trigger and press the trigger pin with finger). While the driver is down, make sure that the tip extends past the nose about 1/4 inch (if air leaks past the nose in this position, replace lower bumper). If the driver does not extend past the nose, replace driver. Good luck
Jun 24, 2011 | Stanley Bostitch N75c1 Coil Sheathing...
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
It is leaving the staples sticking up 1/2 " with
The driver blade breaks very easily on 18 and 22 ga nailers. I would suspect that the tip broke off. Easy to check. Remove the nails, connect airline and press the gun against rubber hose while holding the trigger. The gun will fire and driver will stay in the down position allowing you to check the tip. The tip should extend past the nose about 1/8 inch. When you release the trigger or pick up the gun, the driver will retract. Order parts as needed from www.toolpartsdirect.com
Apr 15, 2011 | Porter Cable Cable 18 Ga 1" Narrow Crown...
The Newair acp 1400h puts out a lot of heat and the manual says not to extend the exhaust hose. Is there any way to extend the hose so that I can exhaust where I want to?
The longer hose will increase the heat in the room and that is why they recommend the short hose…addition to that it may overheat…if you are going to extend the hose you must use one as the dryer hose that insulated and fire proof…let me know if that help
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Sep 17, 2009 | NewAir ACP-1400H Portable Air Conditioner
DeWalt Frame Nailer 51844 extends firing pin when air hose attach
Check whether the trigger is working properly, and whether the air valve is not leaking.
Jun 13, 2009 | Dewalt Round Head Framing Nailer D51845
Remanufactured unit
The problem that you describe occurs when the headvalve is not contacting and sealing against the cylinder. Mosty likely the gun is suffering from a lack of lubrication from sitting in some hot warehouse. You could try following the instructions in the manual as to lubrication but hold the gun in a position that would allow the oil to fall into the head area. Secondary problem, if the nailgun appears to be well oiled already, it could have swollen orings caused by using too much of the wrong kind of oil. If the orings swell in the headvalve, the headvalve cannot travel freely. ENJOY
Dec 05, 2008 | Dewalt D51844 Framing Nailer
Dewalt Round Head Framing Nailer D51845 Logo
365 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
