Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
F 10 code comes on when using oven - Kenmore 46123 Stainless Steel Electric Kitchen Range
  • Kenmore Master
  • 1,711 Answers
F10 Motor Control Unit (MCU) heat sink thermal trip If the thermal protector on the MCU heat sink gets too hot, it will open the thermal protector on the heat sink which will stop motor functions and an F10 will be displayed.
Potential Causes
• Check for Proper Installation, verify the unit is not located near a source of heat and has proper ventilation.
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check Motor
Replace failed component.
Posted on Oct 02, 2010
Can oven cleaning products be used in a Whirlpool "Steam" Clean oven. My oven did not come clean, baked on stuff did not come clean.
Yes they can be used, but rinse them off and run the oven at 450F to after to burn off any residue. 10 minutes of oven time should do.
Nov 11, 2016 | Whirlpool Ovens
What does it mean when F-10 shows on oven display frigidaire range
Good Afternoon friend, thanks for your post!
Based off the information you have provided your range is displaying an "F10" error code. "F10" typically means that your wall oven has detected an issue with the runaway temperature (overheating).
Sometimes resetting your appliance can correct this issue but in the case that it does not and you still receive that error code I would recommend having a professional come out to properly diagnose and repair. At that time you could be having an issue within RTD (Resistance Temperature Detector) sensor probe or the EOC (Electronic Oven Control) having a professional come out would reduce the cost of unnecessary parts. I hope this information is helpful. -Matt
Oct 18, 2014 | Frigidaire Kitchen Ranges
Lg lre30453sw f3 code
An F3 code is usually a bad oven sensor code. Try turning off the breaker to the unit for 10 minutes, then restarting. Might just have been a glitch. If it clears and stays away, you just had a glitch. If it clears and comes back, or doesn't clear at all it will be a sensor needing replacement.
Mar 05, 2012 | LG LWS3081ST Stainless Steel Electric Oven
The oven has a code that comes on of F-10 and F-30.My husband replaced the circuit board and then this started.
Hello, Thank You for using FixYa. I will be helping you today.Both error codes are to do with a runaway temperature or not sensing temperature correct. Make sure the oven sensor is plugged into the board correct or one of the wires wasn't damaged.Since the control was replaced i would make sure it was wired correct.The oven sensor or rtd probe is the short rod coming through the back oven wall in the top section. If all the wiring is correct and plugged in correct the probe is shorted or the relay on the control.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Frigidaire FGB24L2A Gas Single Oven
What is the se code that comes up on the oven, and it wount work? How can we fix this error code?
Hi longislandlu,
SE stands for "Sensor Error". This appears if the keypad is held down for longer than 10 seconds but if not held down this means that your humidity sensor has shorted and needs to be replaced. You will need to uninstall the entire unit and remove the outer shell to access the sensor that needs to be replaced. It will be mounted somewhere around one of the vent on the cavity of the microwave. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Mar 31, 2011 | Samsung SMH9187ST Microwave Oven
Oven shuts off 10 minutes into self clean cycle or while broiling
check for loose connection on the door sensor or micro switch you ay need to change the micro swich if faulty
Jul 28, 2010 | GE 30" Built-In Single Electric Wall Oven...
Error Message
The problem is the oven temperature sensor has failed. This is located inside the oven near the top back. It is long thin tube like.Remove the 2 screws and remove the sensor. Check with an ohmeter you should have approx 1100 ohms within 10% if not replace. This is easy to replace. Enter your model 3 for diagrams and illustrations at www.appliancehelponline.com All parts come with installation instructions.
May 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Frigidaire oven F-10 error
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
May 24, 2009 | Frigidaire FGB24S5A Gas Single Oven
F 10 code when I try using oven
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Please rate and have a great day:)
May 18, 2009 | Kenmore Ovens
Error code on my oven, what does it mean?
I have a Whirlpool oven that is 10 years old or so. The oven stopped working today. The code that came up was E3 (in green) and F1 (in red). I would like to know what is wrong with the oven? Please send me a solution. Thanks
Nov 15, 2008 | Whirlpool RBS305PDS Electric Single Oven
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
201 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
