Question about U-Line Icemaker
Water runs over ice maker but, ice doesn't form
U-line ice maker model # u-clr2060s-01
the water seems to run over the ice maker but, doesn't seem to form ice.
there was dust and cat hair in front of the vent last night that i cleaned off and after that it made one batch of ice. but, hasn't made any in 12 hours.
  • 2 more comments
  • cseattle May 25, 2008
    there is no ice frozen on the metal ice maker if that is what your suggesting. it is free and clear of ice and the water just runs over it.
    the metal is cold though
    do you still think its the same problem?
  • Anonymous Mar 21, 2014
    What Kind of Freon do I need for my U Line Model # CLR60B ice maker?
  • Anonymous Mar 27, 2014
    ice maker calls for water before last water has frozen
    ice maker fills with water before the last load freezes
  • 1,031 Answers
The majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3). water runs over ice maker but, ice doesn't form - 3193_1.gif
1-Begin the repair by unplugging the refrigerator and shutting offwater runs over ice maker but, ice doesn't form - 3193_3.gif flow to the icemaker. 3193_3.gif
2-The icemaker's water valve is attached to the refrigerator cabinet by means of a bracket. Remove the bracket screws. To test the solenoid valve, use a multimeter (also called a volt-ohm meter). Set the meter to the RX-100 scale. Touch the probes to each terminal on the solenoid coil (Fig. 4). The meter should read in the range of 200 to 500 ohms. If the meter needle does not move, the coil is bad. You may be able to purchase the coil separately from the valve. If not, you will need to replace the entire valve. An icemaker valve costs about $30 to $50 from the manufacturer or an appliance parts distributor. If the coil tests okay, the inlet filter is probably clogged. To clean the filter, first remove the large brass nut on the inlet side of the valve. Then gently pry the screen out with a small screwdriver. Clean the screen using an old toothbrush (Fig. 5). Rinse the filter clean, reassemble the valve and install it. Before installing the back panel on the refrigerator cabinet, test run the icemaker. Look for leaks, and tighten any leaky connections. If necessary, use Teflon tape or a similar product to ensure tight connections. Discard thewater runs over ice maker but, ice doesn't form - 3193_4.gif cubes that are produced because they are likely to have sediment in them. 3193_4.gif
3-Two wires supply power to the valve. Gently disconnect the wires to test the solenoid coil's resistance. 3193_5.gif
4-The multimeter will read 200 to 500 ohms if the coil is good. If the meter's needle does not move, the coil is open. 3193_6.gif
5-If the solenoid coil is not malfunctioning, disassemble the valve and gently clean its inlet screen using an old toothbrush.
Posted on May 25, 2008
  • 3,037 Answers
Have you tried defrosting it?
With this situation, try defrosting it, clean it out, and wipe it down and then let me know if it starts working again or not.
If not, I will let you know what else may be wrong but right now, you probably just have some water frozen up in the machine so do the above and get back to me and I would be glad also to answer any other questions or concerns that you may have.
good luck
  • Benjamin Patri
    Benjamin Patri May 25, 2008
    you could have a clog in the hose if the pressure seems high and the water seems to shoot over the ice maker
  • Benjamin Patri
    Perhaps an internal component is frozen and defrosting the system should take care of any such problem so please give it a try
U line ice maker, the water doesn't shut off after filling the tray.
Change the water inlet valve if it is off and water continues to bypass the valve when off...Sea Breeze
U-Line Refrigerator Parts
Water Inlet Valve 2552A
Mar 25, 2013 | U-Line Icemaker
Emerson ice maker not freezing ice, making small cubes and they are soft and mushy.. seems to not freeze ice solid and takes forever to drop ice
When was the last time you cleaned it by running ice machine cleaner through it. After a period of time algea, or slime will form on the chill plate where the ice is made. Sometimes its invisible to the eye, but it doesn't mean its not there. When this happens the machine will freezse the water, and when the ice tries to slide forward to the cutting grid, it catches on the chill plate. There are no sensors in the machine to tell it that this is happening and so the machine moves forward and starts running more water across the plate, which in turn runs across the ice caught on the chill plate melting it and using it as a ramp to fall into the bin melting the ice there as well. So, try cleaning it before taking any further steps, then if the problem persist feel free to get in touch.
May 15, 2012 | Emerson Im90 Portable Ice Maker
My Whirlpool Gold Side by Side (counter depth) [model# GC3PHEXNS00] refrigerator stopped making ice. Water dispenser is still working, doesn't seem to be an obstruction in the line. What do I do?
Can be clogged water passing line or faulty water valve.But if you have already checked the water passing line and it seems clear, then its most probably the water valve.---------
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Sep 18, 2011 | Refrigerators
I have a 12 year old Sub Zero model 624. The ice maker has completely stopped producing ice. And actually, when opening things up we can see ice cubes have formed but they just haven't dumped into the...
This is the procedure but yours seems to be a faulty Icemaker and needs to be replaced since your freezer is cold enough to make ice rapidly.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Sub-Zero 642
Hi, My Bosch Model B20CS50 SNI/01 side by side
It sounds like the fridge is in need of a regas, but that seems unlikely after only three years, although not impossible. An indication of that would be if the compressor could be heard to be running all the time. If it cuts out after running only a short time it could be the thermostat that has gone faulty.
Mar 23, 2011 | Bosch Appliances 20.19 cu. ft....
I have water leaking in the freeer apparently down the back wall and pools on floor to form ice. Water has also accumulates under freezer on hard wood floor but not all the time. Model MSD27326R There is...
Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
Mar 27, 2010 | Refrigerators
Water wont go all the way into the ice maker
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Or
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Oct 08, 2009 | Kenmore Refrigerators
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice maker
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
U-Line Icemaker Logo
243 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
